I just got my smart trainer and have set it up. Do i need to get a power meter that cost $500 or more to get this function on swift or is there a less expensive way ?
All suggestions would be appreciated.
Sincerely,
Mike
Sincerely,
Mike
Which smart trainer did you buy, it might already have a power meter e.g. Kickr? if not then I guess you need Stages of something that might be cheaper in your region.
There is a list available in knowledge base articles here on Zwift what trainers are supported. The differences in power are listed as well. For example, a Kickr is a controllable trainer.
You can also use powermeters that are separated from the trainer like Tim suggests.
It is the Elite Quobo Digital Interactive Trainer.
I just orderer the Garmin Speed and Cadence meter below.
Will this work ? Also - if i dont use a power meter - is there any benefit to the “Smart Trainer”. I have a good regular trainer that i like - would it make sense to return the smart trainer and just use what i have.
Your thoughts are appreciated.
Thanks,
Mike
Garmin Speed and Cadence Sensor Bundle
The Garmin Speed and Cadence Sensor Bundle provides a simple, straightforward means to monitor your speed and pedaling cadence as you ride. Both sensors are wireless, ANT+ compatible units making them easy to install, maintain, and move between bikes. There are no magnets to worry about and nothing to line up – just install the sensors, pair with a Garmin ANT+ compatible device, and enjoy the data provided during your ride
With the Elite Qubo Digital you don’t need a power meter, the trainer will give you the wattage and all the data automatically, as it adjusts gradients and therefore required power along the route. The smart trainer makes a big difference, you will notice the difference once installed. Good luck…
