I have, several times, executed a U-turn by mistake. Usually while climbing Alpe du Zwift, which makes the whole climb null and void…
Currently the keyboard shortcut is the “down arrow”. This button is also used to pan the camera down in view “0”. So, if I think I’m in view “0”, but I’m actually in another view (usually “9”), and I try to pan down, I U-turn instead.
Unintended U-turns also happen when I think the computer’s focus is on another application, but it’s actually on Zwift.
Could the keyboard shortcut for a U-turn be changed to “U”?
Be reasonable! You want the “U”-turn keyboard shortcut to be the “U” key?!
That makes way too much sense. It would be too intuitive.
In all seriousness, what does the “U” currently do? Is there a keyboard shortcut for U-turn? I do not use the keyboard for anything. I find the Companion app controls sufficient.
Is it? I can’t think of anything. Maybe navigation within menus or dialog boxes, but I’d assume it doesn’t trigger a U-turn in that situation. Maybe it does!
If I ever used the camera, I’d still prefer the mouse while riding. It’s much easier for me to use while on the bike. All depends on where you have the mouse and keyboard though.
