Pair Zwift Controllers through KICKR Core 2 [January 2026]
Wahoo and Zwift have enabled the Sensor Bridge feature for KICKR CORE 2 to allow pairing of your Zwift controllers. This requires you update your KICKR CORE 2 to firmware version 2.5.4 or 3.5.4 using the Wahoo app. Here’s how.
Also check that your Zwift controllers are using the latest firmware. Instructions for Ride are here, and Click controllers here.
This enables your Zwift Ride or Zwift Click 2 connection to be bridged through the Wahoo KICKR CORE 2 and relayed over Wi-Fi.
  • Eases Apple TV’s Bluetooth connection limit.
  • Helpful for devices with poor Bluetooth connectivity
  • This is configured through the Zwift pairing screen only, do not use the Wahoo App. The Wahoo app will show you that there is a controller connected, but this is just a visual.
  • Bridged controllers will show a trainer icon, like this:
  • Enabled in KICKR CORE 2 firmware version 2.5.4 / 3.5.4 or higher
  • Enabled in Zwift Game version 1.104 or higher.
Known bugs:
CORE 2 v.2.5.4 / 3.5.4 firmware + Zwift game version 1.104
  • When connecting - disconnecting - reconnecting a bridged controller you will see the controller get stuck on connecting. (Don’t disconnect and reconnect the controller)
  • Slow initial bridged connection in some cases.
Play controllers are not able to use this feature?
@GPLama says no
Thanks, Paul, I saw that a few minutes ago.
Kind of a shame, since Zwift sold a bunch, and gave many of them away for reaching a certain level, too.
Not at this time. To overcome Apple TV’s Bluetooth connection limitations, we recommend you pair your Play or Click v1 controllers by bridging the connection with the Zwift Companion app. Here’s how.
I paired Click 2 paired through the Kickr Core 2. I have seen during a few rides that shifts will jump up or down 2 gears. I don’t recall this happening when it was paired via BT. The jump isn’t every shift and some rides all shifts are normal.
Why not the OG Play controllers, too? There’s a lot of them out there, I’m sure.
While I got the Click 2 with my Core 2, I much prefer the Play controllers, both for the way the ergonomics and the fact that I won’t have to fiddle with the tiny screws and change batteries.
