Hi all,
Im having quite some issues with getting Zwift to work (pairing the sensors etc) but when i get it to work, the amount of watt just feels way too low.
Just now i did the short FTP test, giving my absolute everything, getting an average of 96W and a max. Of about 140W. When cycling on the road i get about average 120W without trying even hard.
My setup is:
- Samsung Galaxy S7 for the companion app
- Tacx Satori T1850
- Wahoo speed and cadans sensor
I tried searching this forum, but couldnt find anything to solve the issue. Hopefully someone can!
Ok, what do you have the resistance set to?
What do you have your tire pressure at?
Resistance right now at 1. Tire pressure will be around 8 bar.
OK, I think the resistance for that Satori needs to be set to level 4
The Satori Smart t2400 is set to level 1.
Just out of curiousity, how does that makes a difference? The Tacx isnt a smart Tacx, so not connected to anything. Its just the Wahoo cadans and speed sensor. It has a manual resistance selector.
It makes a difference in the power curve.
Great, thanks so much Paul! I havent actually checked it just yet, but i definently will soon.
Good afternoon, the same thing happens to me but using a Tacx Flux 2, my power ranges are much lower (around 30%), do you know what it can be? Thank you all
Hi @Albert_Valiente
Welcome to the forum.
With what do you compare your power numbers?
Hi, thanks for asking.
In real life I use PowerTap on the rear wheel and a Garmin Edge 520.
The power of the Tacx may not measure well or is it a calibration problem?
I have updated to the latest version, I have a good internet connection…
help me
Try calibrating using the tacx app.
If I feel that the measurement is also below, it must be a problem with the Direct Drive Trainer, could it be a factory fault?
Anything is possible. IF you know someone with power pedals you can test it that way. and if it is off, you can contact the manufacturer.
Good advice. I will try it
Hello Paul, i was able to test it out today and sadly enough it didn’t help putting the resistance to 4, i was barely able to get the wattage above 100. Is there anything else i can try?
I have exactly the same issue with the Tacx 2 Smart , only reading around 75-80 watts when I’m regularly 125 on the road .
I have the same issue with power on Zwift 40-60w below the Stages on Garmin output. Did anyone find a solution? I’m using the Tacx Flow, which I calibrate each time I ride.
