No game mode Android Companion app
The last couple of days the game mode doesn’t open in the android Companion App.
It seems I’m not the only one with this issue, because I see far less mobiles depicted next to the riders names.
However, I don’t see it mentioned in the ‘known issues’ section, so here 's a post in hopes you can fix this.
Jolanda
I’m not aware of anything to fix in the Companion app related to this right now. The way it works is rather fragile, but it does work. When it breaks, it usually has something to do with the design of your home WiFi network or settings on the things you use to run the game and Companion, so if you can share details about all that we might be able to figure it out. You should not expect a bug fix to address this.
Thanks Paul, for your quick response.
I checked everything and found the problem.
I accidently had my VPN turned on.
It’s working perfectly now.
Kind regards,
Jolanda vd Hoek
