No female voice for female account
Hello everybody,
In case this has been asked before, my apologies. I did search for this, but did not find a solution.
My girlfriend and me are both using Zwift on Apple TV. One app, two accounts that we change between. Hers is female, mine is set to male.
Whenever she shouts out a “ride on” or a hammertime it’s in the same male voice that I hear when using my account. I did see on these forums that there are female voices, she just doesn’t get to hear them. We did check and her account really is set to female.
Is this happening because we share the same app with two accounts or is this related to the Apple TV version of Zwift, a bug maybe or do we need to change some settings?
Anyone who can shed some light on this, we’ll be much appreciative of!
Ride on!
I have the same exact problem. Any solution? I tried to remove the app and reinstall but the problem still persisted.
I also have the same problem! Did you ever find a fix?
I have no idea on this, as I only have a single account on my ATV, but have you ensured that you are force-quitting the app after each use? My thought would be that force-quitting might would cause the app to boot up from scratch for the next use and might then pick the correct ‘voice’ for the user chosen, whereas it might retain the legacy voice if simply reopened without a force quit. I have zero idea if this would work, but it might be worth a shot.
Never found a fix for this. Completely restarting the Apple TV doesn’t help as well. I should probably be happy she didn’t link her account first.
Only option left was to ditch the girlfriend, decided against that.
I have not found a fix either. I have tried the following:
  1. Complete reinstall on same computer.
  2. Login with different account, log out and then log back in with “female” account.
  3. Change gender within game to male, exit Zwift, reenter zwift, then switch back (repeating same process)
  4. Change gender on the website settings. Start Zwift and update gender again (a few other combinations I have tried here).
In all, I am just hoping that an update will eventually correct this. Another idea is to try and determine where the sound files are being accesses and then replace those files with the female sound files. Therefore, regardless if the profile is female or male, the audio will be female.
Frustrating :frowning:
