New user..2 issues having problems with on trial
I am using a Tacx Vortex and am connected via AppleTV.
  1. When Zwift is connected and in use, I notice burning smell coming from tire shedding some of its tread.
  2. Wattage is significantly low no matter how much effort i put in.
Any info to help would be great.
Thank you
Are you using a trainer tire?
No sir. Using my standard road bike tire. Thank you
Maybe you should put some more pressure against your wheel/tyre.
If it smells burned and no power readings, maybe the tyre is too loose against the trainer so no grip, no turning flywheel?
I hope you know how to setup your trainer and hardware for communicating with your devices.
You really should consider a trainer tire.
I agree with this assessment - you CAN use your actual tire but you’ll add significant wear to it pretty quickly and trainer tires are designed for the purpose. There are a number of brands who make trainer tires (I think the last one I had good results with was Continental which came in a sort of ugly-ish brownish orange/yellow tread color). The downside is you’ll have to swap tires back and forth since riding outdoors on a trainer tire isn’t recommended. Since I live in Minnesota where it shows half the year it’s not too bad for me. Good luck!
I’ve always been training on rollers with old/used tires and the only downside i’ve found is that i use them till they fall apart. So it happens that while you’re training you gotta go change a tyre but hey…talking about recycling or waste solutions. This is the best way to completely use your tires. The ones that are too worn for outside, at least i can get quite some hours roller training out of them indoors…and it’s free! :wink:
I’ve never had that problem of overheating, slipping, etc. Yes, just control the tires that they’re clean. You might get a puncture! No kidding. With a pressure wheel on the tyre you could pinch it if there’re already some stones or debris in it.
