Purchased new Kickr and it is making a very loud knocking noise! I tried to upload video but it wouldn’t allow. Anyone have this issue and know the fix?
A Kickr Core?
A noise like this?
This is mine, and it was collected today to be replaced as faulty. Hopefully the replacement will be ok.
I believe You can find some useful info here … Wahoo Silent Kickr/Kickr Core Faults | CycleChat Cycling Forum
it’s known problem and can be “easily” fixed by user (using a fix-kit provided by Wahoo) … more info in link above …
Hope it helps …
The knocking is from the drive pulley under the plastic cover the drive key is imperial 3/16 and should be 5mm once that is changed that stops the play in the connection also the washer holding the pulley is not thick enough which does not help a 3mm thick washer or 2 together is better.
After this is all done things will be fine shame it’s just small part that costs vertually nothing that causes this
