We appear to have a small number of outliers currently.
Part of the fix is reliant on their logging back into the game for the first time after the fix was made.
Well done on your sprint win.
You do not need to restart your machine.
Are you going to reinstate Racing Scores for these events?
I was in an event that didn’t have any glitches in race results, but it’s still showing all zeroes for points gained/lost
Yes, probably in the next 24 hours.
So are results only corrected if users on old versions log in again? That’s not ideal for those who took part while running the latest version.
If you’ll just send me the adresses and bank details on the outliers, I’ll drop by and restart their machines, and maybe see if they have some snacks
They should be presented with the log in screen after 30 minutes of activity so it should catch those people.
None of this is “ideal”.
My point was more along the lines of: if someone participated in any of these races on an old version and never logged in again, the results would never be fixed. Is that correct? i.e., it seems that their logging in is the only way for the fix to be applied.
Yes, correct.
I’m going to pull all the results from Monday and Tuesday (my time) from the leagues.
The remaining events (for the vast majority) should now be correct with currently a small number of outliers. Our engineering team are still looking into what else they’re able to do.
I have now reenabled Racing Score changes on all of the remaining events this week (I hadn’t turned this off for subsequent weeks.
This issue is largely fixed, with some outliers as noted above. Our engineering team are continuing to work to see if there are any further changes they can make to mitigate this.
I have also removed events from the ZwiftPower leagues that took place on Monday or Tuesday.
Hiya, I participated in the 10:10 (UK time) Mech Isle race which went smoothly, this was after you said racing score had been re-enabled. However, that race has had no racing score attributed. It could just be timing, but so you know. Thanks
Thanks Graeme, I suspect the race had started after I made those changes, which will probably explain why your score didn’t change. I’m glad the race went well.
Will these be updated retrospectively? All good if not but so the race knows. Thanks
I’m afraid not.
Okay thanks, I put a couple comments in the race to let folks know. ![]()
in conclusion, whats the suggestion? I have raced the “long” distance.
to have a complete and correct GC result after this series, should i re-do this race until Sunday as my previous result will get deleted? (as of now, its not deleted. I can see my time of 29:09 in that GC overview).
When was your initial race? Standings should be updated.
My race was Monday 18:10 (swiss time). Time 29:09 with Rhino.
Those events should be removed from the league now. In order to register a time for the league I am afraid that you will need to race again.
Im afraid im too daft to understand. On the GC leaderboard im on rank 610 and those on the top ranks with the shorter course are still listed.
I guess the corrections are still about to happen?
I believe @James_Zwift is referring to the Zwiftpower GC league, not the Zwift.com GC?
