Like making my own routes instead of just using the programed routes all the time for the past year. Made a list of turns of the turns with distance, climbing, and how much non pavement on a word doc that is not translating to the forum well. So it being copy and past. Hope it shows well. There is about 20 to 30 routes. Waiting for the upcoming addition make more. A mix of short to long rides, easy to hard. Most routes on watopia and makuri islands/yumezi expect for first few.
Zwift personal routes
Temps09
Astoria Skyline 8 NYC map
Modified Astoria line 8 with the glass sky roads above the park. About 50/50 pavement/glass
Lead in to arch form Astoria line 8 spawn point to arch just up the hill. (About 0.3km or 0.2mi)
Event/race leaving starting start pens area line just past the normal S/F arch
Select Astoria LIne 8 route:
(Straight) up East Dr from Cats Paw Hill arch/start pens
(L) baseball fields then (R) up the hill then (R) to keeping heading downhill
(Straight) onto Glass road at north end of park over the city rooftops.
(R) at next junction to other side the lake over the connecter rise
(L) Over the lake
(2 straights) to pass by Metropolitan and KOM turn off and down to ground level.
(L) off the glass road into the Sprint
(L) Bethside Plaza
(R) To Finish at Catspaw hill arch or more laps
Distance = 12km; Climb = 164m
Trois Boucles (Three loops) France map: Flat with few rollars first 2/3 of distance. 2/3 of vertical in last third of distance, two climbs of the switchbacks of the petit Kom Three interconnecting loops into one ride with two big hill climbs towards the end after flat and rolling terrain with downhill at the end.
1km lead-in: Start pen/spawn point to marina S/F arch, flat
RGV route
Casse Pattes route with (R) turn before finish to Balloon fields
(R) to Petite climb (R) to Marina Finish arch
Distance = 62.5 km; Climb = 483 m
Richmond Pretzel Richmond map
Richmond UCI course in both directions one ride. Flat warm up before one lap of the course in reverse and finish with the climbs in the forward.
Select: UCI worlds course:
Start to Fan Flats forward then keep going
UCI course reverse onto cobbled climb reverse then into Fan Flats reverse.
Cobbled climbs forward to finish.
Distance = 33km; Climb = 257m
Watopia Classic Watopia map
A classic style course with a steep punchy hill, cobbles, dirt /wood with between rolling or flat pavement sections.
Start and Leadin: Downtown pier to Hilly Forward Hilly Kom arch (S/F) 1.8km 57M
Select: Hilly route
Down Reverse side to (R) Sprint connector
(L2x) Italian Villas/waterfall to (R) Marina
(L) to Sequoia Circle then (straight 2x) to (L) Hilly Forward
Climb to arch for finish or doing more laps
Distance = 11.6km; Climb =90M; about 10% dirt/cobbles/wood
Watopia “W” Watopia map
Start: Volcano arch, no lead in on free ride mode
Race/Event lead in: Downtown pier to (R) Glass tube to (L) volcano circuit and arch (S/F) 2.7km 20m
Select Tour of Fire and Ice route or Volcano Circuit if under level 6
Down and Out of Volcano (L) to Italian Villa to (R) to waterfall (R) to Marina
(L) Sequoia Circle then (straight 2x) to (L) Hilly forward
Down the reverse to (R) Sprint connector
(R) Esses to (L) Glass tube to (L) Volcano circuit and arch for finish or more laps
Distance = 16.6 km; Climb = 135m (one lap)
Rolling rings Watopia map:
Flatter and rolling roads around lower Watopia
(R) onto Volcano Circuit loop for one loop;
Second time at land bridge Junction to (L) Italian villas.
(L) Italian villas/ sprint to (R) Connector to (L) Hilly reverse
(L) Cutoff to (R) Hilly Forward and loop around to (R) Cutoff to (L) Down the hill
(R) Ocean Blvd to (Straight) Sequoia Circle to (R) Wind Farm/Marina to
(L) Italian Villas/waterfall to (R) to Sprint
(Straight into) Essses to (L) Glass tube to (L) Volcano circuit and arch for finish
Distance = 22.3 km; climb = 161m
5 rings Watopia map:
Second time at land bridge Junction (L) to Italian villas.
(R) Waterfall to (R) Marina to (L) Sequoia Circle
(R) Epic Rd. to (L) Desert Rd. Junction, over Col de Saddle Springs
Fuego Flats Rev. to (L) Ocean Blvd to (R) at Wind Farm/Marina to
(Straight 2x) over Hilly reverse to (R) Ocean Blvd. to (L) Fuego Flats
(R) Titans Grove Rev. to (R) Col de Saddle Springs and downhill
(R) Epic Rd into Ocean tube to (L) at Sequoia circle
(R) Wind Farm/Marina to (L) Italy Villas/waterfall to (R) to Sprint
Distance = 56.7km (5.3 km of dirt/wood/cobbles); climb = 416m
Tour of Lower Watopia Watopia map:
All the roads and climbs of lower Watopia region
Start Downtown pier, No lead in
Pick any route that goes from downtown into Esses that goes through downtown pier arch in free ride
1 lap of Two Bridges loop route ideal to start
Esses to (L) at Italian Villas/waterfall to (R) Marina to (L) to Sequoia Circle
(R) Epic Rd. to (L) Desert Rd to Col de Saddle Springs
Fuego Flats Rev. to (L) Ocean Blvd to (R) Wind farm/Marina to (Straight then L) Sprint connector
If observatory is add in at some point. Most of climbing beings now
(L) to Italian Villas to (R) land bridge into Volcano Circuit lap with KOM climb at second trip at climb junction. Then leaving volcano after coming down and back through to glass tube.
1.5laps and climb when done with Volcano
(L) Glass tube to (L) Downtown to Hilly Forward over and down Reverse
(Straight then L) to Marina (Straight) to seaplanes and Bixby Bridge hill climb
(L) Up Cliffside to (L) down Epic Gate Bridge
(R) Desert Rd. junction to (L) Col de Saddle Spring into Titans Grove forward
Out of Titans grove to (L) to Ocean Blvd. (R 2X) to Downtown for finish
Distance= 81.5km; Climb = 744m
Epic forward triple loops Watoipa map:
Mountain 8 route start with Cliffside added in to Epic forward and through the volcano before finish
Pick any route that goes from downtown onto Ocean Blvd. that goes through downtown pier arch in free ride
Downtown to (L) Ocean Blvd. (Straight) at Sequoia Circle
(L) Wind Farm/seaplanes and climb Bixby Bridge hill
(L) onto Cliffside to (R) Epic forward climb and radio tower out and back
(L) Down Epic Reverse to (R) Cliffside to (L) Epic Gate Bridge
(L) at Sequoia circle to (R) Wind Farm/Marina (Straight then L) to sprint connector
(L) to Italian villas (R) to Dirt Road/land bridge and (R) at Volcano CCW through arch
(R) Glass Tube to (L) Downtown
Distance = 39.1 km; Climb = 717m
???Maybe S/F at volcano arch if leadin is not too long from pier some how for uphill finish???
WLOCT Watopia map
A more hill climbing version of Ocean-Lava- Cliffside with the wall, esses, volcano climb, and titans grove add in one loop.
Select Hilly route: Route start at downtown arch
(Straight) to Hilly forward and over the top then down reverse side
(R) at Sprint Connector to
(R) into Esses
(L) to Volcano/glass tube
(R) Volcano CCW to (L) Volcano climb and descent at the junction
(Straight 2x) down ramp along Beach and onto Land Bridge to Dirty Sorpresa
(R 3x) to Waterfall down into Marina to Bixby Bridge Climb
(L) Cliffside
(L) down Epic Gate Bridge hill (R) Desert Rd/Col de Saddle Springs
(L) Titans Grove Forward
(L) Desert Rd. to Ocean
(R 2x) to downtown finish
Distance = km 41.5 ; Climb = 534 m
If event only version have Lead into km to Hilly KQOM line for start and laps or finish there. (Lead in 1.8 km 57m climb; Route: one lap: 41.5km 534m)
Sequoia Bay Loop Watopia map
Hilly ride with hill top finish, no Sequoia Circle junction on route. Ideally start at Titan Grove K/QOM line in free ride mode.
Event/Race: Start at Desert start pens heading “(L) Into Titan Grove Reverse climb and start route at top of climb (5.2km 122m)
(Straight) down past the dinos and through the fog
(R) Down Col de Saddle Spring to Epic/desert junction
(L) Epic Gate Bridge hill to (R) Cliffside
(R) Down Bixby Bridge Hill to Marina
(L) through Wind farm, into Marina
(L) towards Italian Villas
(Straight) to sprint
(R) into connector into (L) Hill reverse and down
(R) Onto Ocean Blvd then (L) at Desert Rd. across the island
(R) Titans grove and finish at top of climb
Distance = 26.6 km; Climb = 351m
Mur and the Jungle Watopia map
Hilly ride with a mix of surfaces with hill top finish. Ideally start at Titan Grove K/QOM line in free ride as in Mur in the Mountain route
Event/Race: Start by Desert start pens heading “(L) Into Titan Grove over climb and start route at top of climb (4.8km 122m)
(R) Cliffside and (Straight) into Jungle reverse loop
(R) Mayan bridge then (L) Loop forward through Jungle arch
(L) Mayan bridge to (R) Jungle reverse (Straight) back out over Windmill pass
(L) Down to Bixby Bridge Hill
(L) through Wind farm into Marina
(Straight) to sprint arch
(R) into connector into (L) Hill Reverse and down other side
Distance = 43.7km; Climb = 542m *about 14km of dirt/wood/cobbles, 32% of distance
Volcano 8 Watopia map
Rolling and flat figure 8 around the volcano circuit and seaside sprint loop in both directions.
Start Volcano arch in Volcano CCW direction.
Follow Volcano CCW around the volcano
(Straight) across land bridge and up Dirty Sopressa (L) to sprint arch and esses
(L) Glass tube to (L) around Volcano Circuit (R) Glass Tube (R) Esses/sprint arch
(R) Down the Dirty Sporessa across land bridge (R) up hill to Volcano arch for Finish
Distance = 17.3km; Climb = 110m; non pavement = 10%
Ocean 8 Watopia map
Flat and rolling along ride the waterfront. Select Figure 8
Start going through Downtown S/F Arch
(L) Ocean Blvd (Straight 2x) into marina (Straight2x) to 360 bridge
(L) KQOM bypass (L) down hill then (straight)
Through arch (Straight) into Esses and sprint (R) down Dirty Sorpessa towards Volcano
(Straight) Volcano Circuit (R) Glass Tube (L) down to beach for finish
Distance = 17.5km; Climb = 119m; non pavement = 10%
Italian 8 Watopia map
Figure 8 doing roads on both directions with Start/Finish at sprint by Italian Villas avoid the downtown area and adding in Volcano area
(Leadin in as in Seaside Sprint 2.8km 36m)
(Straight) To Italian Villas (L) waterfall/ 360 bridge (R) onto Ocean Blvd. down to Marina
(L) Stay on Ocean Blvd. (straight 2x) up Ocean Blvd. (L) Hilly Climb forward and down
(straight 3x) to Italian Villas (L) down Dirty Sporessa
(R) Volcano CCW through volcano arch (R) Glass Tube (R) Esses/ Sprint
(straight 3x) to 360 bridge into Hilly Reverse
(R) onto Ocean Blvd. (Straight 2x) till out of tunnels
(R) at Wind Farm into Marina (L) to Italian Villas (R) Sprint arch(straight) to Esses
(L) Glass Tube to Volcano (R) around Volcano CCW
(Straight) to land bridge/up Dirty Sporessa (L) sprint arch for Finish
Distance = 37.2km; Climb = 297m; non pavement = 12%
4 Sisters Watopia map
Three sisters with Titan Grove Reverse added in
Select Three Sisters Route then add in a detour
At Sequoia Circle go (Straight) up Ocean Blvd. (R) Desert Rd.
(R) Titan Grove Reverse (R) Down hill at Col de Saddle Springs
(L) Epic Rd. back onto regular route
Distance = 60.7km; Climb = 1060m;
Five horsemen Watopia map
Four horsemen route plus Titans Grove in order of each climb higher than the next
Two routes possible: Shorter one is cutting off Jungle/Alp section. Cut off after main part of Epic/Radio Tower descent at 4 way junction. Still a hard good workout/event or race route without totally destroying most people
Start: Downtown (Straight) into Hilly Forward and down other side
(Straight then L) after 360 bridge to Marina to (L) stay on Ocean Blvd. to
(R) at Sequoia Circle (L) Desert Rd to Col de Saddle Spring to (L) Titans Grove forward
(L) Ocean Blvd. to (R 2x) Downtown to (R) Volcano glass tube
(R) Volcano CCW to Climb up and down
(Straight 2x) to beach and land bridge to Dirty Sporessa
(R) Waterfall/Marina over rollar
(R) to Marina to (L) to Sequoia Circle to (L) Epic/Desert
(Straight) on Epic forward to (L) Radio Tower out n back
(L) down the mountain
(Straight or L) at 4 way junction or (Straight) skip jungle/Alp climb for run in to finish
Cutoff route: Hoursemen Bailout
(L then R, but program shows straight) down to Marina to
(L) Italian Villas/waterfall (R) Sprint/ Esses to (Straight) to downtown finish
distance = 66.7 km climb = 1116m non pavement = 10%
Main Long route with jungle loop/alp climb
(L) to Jungle/Alp over Windmill Pass
(L) Jungle Reverse through Jungle arch to
(L) for Alp climb, Summit and back down (25.8km 1035m to do at segment start)
(L) Follow Jungle Reverse out (Straight) over Windmill Pass
(L) Marina to (L) Italy Villas/waterfall
(R) Sprint/ Esses to (straight) to downtown finish
Distance = 106.1 km; Climb = 2264m Non pavement = 15%
Epic Climb after party Watopia map (Event Only)
Start at the pier in downtown rollling around the lower watopia regions before the big climb through the castle into the snow.
Starting on the pier down to arch to start route.
Do about 1.5 laps Waistband Reverse
2nd time Epic Rd and Desert Rd junction start Epic forward climb to finish (418m 9.5km to go)
Distance = 46.0km climb = 566 m non pavement = 4.2km
Many Bridges tour: Watopia map
A tour of watopia bridges across rollars, hills, mountain. Select Two Bridges route to start with. Start/finish at JWB bridge sprint arch
Lead in: same as Seaside sprint to sprint arch 2.7km 36m from downtown arch
(Straight) to Italian Villas (L) to 360 bridge (Straight2x) to bridge
(L) KQOM bypass (L) downhill (R) Ocean Blvd. (L) Desert Road
(R) Over Titan Grove Reverse (R) down hill at Col de Saddle Springs
(L) Epic forward climb (Straight) after Epic Gate Bridge to stay on climb
Over highest bridge and (Straight) down Epic Reverse (R) Epic kom bypass/Cliffside
(L) down Epic Gate bridge hill (straight) into Ocean Tunnels
(L) at Sequoia Circle to Marina/Wind Farm (L) up Bixby Bridge hill
(R) Jungle forward (L) Mayan bridge
(R) Jungle Reverse through arch (R) Mayan bridge (L) Jungle forward over Rope Bridge
(Straight) out of Jungle over Windmill Pass (L) Bixby Bridge down to marina
(Straight) onto Ocean Blvd. (L) towards Italian Villas (L) towards Volcano
(R) Volcano CCW through arch
(straight) to stay on Volcano CCW to Volcano climb up and down then back
(L) Glass Tube/sky bridge (R) Esses to sprint arch for finish.
Distance =78km ; Climb = 1188 ; non pavement = 22%
Skip going along Cliffside, down Epic Gate Bridge, Ocean tunnel, up Bixby bridge hill (68.3km and 1106m)
Sequoia Bay 8 Watopia map
Hilly ride with a hill top finish around and through Sequoia Bay. Last 23% of distance has 34% of climbing so save energy for last two hills in quick order. Finish does not favor not a pure climbers or sprinters but in between type of rider.
Event/Race: Start at Desert start pens with (R) out of start pens. Free ride spawn by desert start pens, no leadin. Distance starts at pens.
(Straight) across island to Ocean Blvd (R) Ocean Blvd. to downtown
(L) Hilly forward and arch, then down reverse (R) onto sprint arch connector
(L) towards Italian Villas (L) Waterfall /360 bridge (R) into Marina through Wind farm
(R) to Sequoia Circle and (Straight) up Ocean Blvd to downtown
(R) Desert Rd across island to (R) Over Titans Reverse
(L) Epic Gate Bridge hill to (R) Cliffside (Straight then R) Down to Marina
(Straight) Through windfarm/marina (L) Italian Villas
(R 2x) to Sprint arch and connector (L) over Hilly Reverse (R) onto Ocean Blvd.
(Straight 2X) down Ocean Blvd
(L) to Bixby Bridge Hill (L) Cliffside (L) down Epic Gate Bridge hill
(R) up Col de Saddle Spring (L) Titans Grove forward Finish at top of climb
More laps just head downhill 4.5km and (L) to repeat
Distance = 55.6km; Climb = 669m Non pavement = 5.2km (9.4%)
Little Four Horses : Watopia
An easier version than four horsemen route with some twists. Still a route with each major climb higher than the previous one. Titans Grove instead of the Alp and last climb is just Epic Reverse, no radio tower. Epic Rev. steepness to prepare for the Alp is last.
(R) Volcano CCW to climb up and down
(R) Waterfall/Marina over roller
(R) to Marina (Straight) to Bixby Bridge Hill (L then R) at 4 way junction onto Epic Reverse
(Straight) to arch: just up and down the mountain, no radio tower
(Straight) across Epic Gate Bridge (Straight) to Ocean Tunnel (L) to Italian Villas
(R) to Marina (L) Italian Villas/waterfall
(R) Sprint/ Esses to (Straight 2x) to downtown finish
Distance = 63.9km climb = 957m non pavement = 6.2km (9.7%)
