Mac blank screen, colored screen and black blocks [October 2021] [1.18.0] [SOLVED]
Hi
After the todays update there is No Chance to start zwift in my imac highsierra 10.13.6
Please give my some Support to solve this Bug!!!
Any further update?
Not yet, but once there is, we will communicate it. The teams have been, and continue to be, actively working on it. We know this is incredibly frustrating for all of you. As soon as we see an update, you’ll know!
Same problem here:
MacBook Air (13-inch, Late 2010)
macOS High Sierra V 10.13.6
Hope there’ll be a solution asap.
Same here with macOS Sierra 10.12.6, app disappears after a second or two of pressing lets go.
Extremely irritating, and not for the first time. Better to just say you’ll no longer support older macOS than go through this every few months
Screenshot 2021-10-21 at 20.24.32
Same issues - was perfect before the latest update :frowning:
Me parece una vergüenza lo que ha pasado hoy. Había quedado con varios amigos para hacer una carrera y al actualizar no he podido ejecutar el programa en mi mac antiguo del 2011 (High sierra). Pagamos para tener un servicio acorde, por favor.
Se va a solucionar pronto el problema? No van a devolver el dinero?
Having issue on 2020 MacBook Pro (10.15.7). Not just old Macs
Same problems Mac Mini 2012 OS High Sierra 10.13.6. I could try to roll back the update as I have Time Machine running but the first thing Zwift does is run the update so that would need turning off first?
It does still run, worst part is black screen but it does come back to the red and green. Sends file to Strava okay.
This did not solve it for me. Both the Documents and the Zwift folders are “unlocked”. I realize this is a known issue on older Macs, but it’s been a while since this was first reported and I, for one, would like to use my Mac! I’m on OS 10.13.6, High Sierra.
For the record. Zwift screen froze upon changing worlds, flickered a few times at the beginning of the workout, then went black. But the trainer resistance was controlled correctly, so I could finish the workout by looking at the workout screen in the Companion app.
So annoying I’m having the same problem with 2015 mac book running OS X El Capitan.
When I click Lets Go, it won’t launch, it just disappears.
Same here, screen didn’t work after Lets Go, but I could still use the companion app to complete a session. Was working OK on Monday.
Osx El Capitan 10.11.6
Thanks for the update but I am always suspicious when the word “actively” is used in this context. Now sounds more like a self- justification to Zwift that all is being done rather than to large number of suffering customers. Clearly failure in pre-release testing has occurred but if you can’t fix in 24 hours it also questions the technical capability of those involved in designing the upgrade and those trying to resolve it.
I wonder why it’s so difficult to revert to the previous version.
[19:54:31] Log Time: 19:54:31 2021-10-21
[19:54:31] Game Version: 1.0.85474
[19:54:31] Config: Shipping
[19:54:31] Device: MacBookPro10,1
[19:54:31] Launcher Version : 1.0.25
[19:54:31] Loading WAD file ‘assets/global.wad’ with file.
[19:54:31] Loading WAD file ‘assets/Environment/Ground/textures.wad’ with file.
[19:54:31] Loading WAD file ‘assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad’ with file.
[19:54:31] Loading WAD file ‘assets/UI/minimap/minimap.wad’ with file.
[19:54:31] Loading WAD file ‘assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad’ with file.
[19:54:31] Loading WAD file ‘assets/UI/layouts/layouts.wad’ with file.
[19:54:31] Loading WAD file ‘assets/Environment/GrassTextures/GrassTextures.wad’ with file.
[19:54:31] Successful audio init!
[19:54:31] Loaded audio banks
[19:54:31] Initializing graphics window of size 0 x 0
[19:54:31] GFXDevice_Metal::Initialize(): Found device ‘<MTLIGAccelDevice: 0x7fdcc8db2000>
name = Intel HD Graphics 4000’
[19:54:31] GFXDevice_Metal::Initialize(): Found device ‘<NVMTLDevice: 0x7fdcc8dd2000>
name = NVIDIA GeForce GT 650M’
[19:54:31] GFXDevice_Metal::Initialize(): Using device ‘<NVMTLDevice: 0x7fdcc8dd2000>
[19:54:31] GLFW ERROR 65544: Cocoa: Failed to find service port for display
[19:54:32] window scale (1.000000, 1.000000)
[19:54:32] framebuffer size (1280, 675)
[19:54:32] Vendor = NVIDIA GeForce GT 650M
[19:54:32] Renderer = <NVMTLDevice: 0x7fdcc8dd2000>
[19:54:32] Calculating Graphics Score
[19:54:32] GFX: Found a vendor/model match for 650M
[19:54:32] Initializing Render Targets
[19:54:32] Initializing Texture Systems
[19:54:32] Calling initialize_zwift_network()
[19:54:32] NETCLIENT:[INFO] CNL 3.13.0
[19:54:32] NETCLIENT:[INFO] Machine Id: 2-5c184755-3c83-463b-964d-ddfec1b48a2b
[19:54:32] Suceeded initializing graphics
[19:54:32] Loading WAD file ‘assets/fonts/font.wad’ with file.
[19:54:32] Using medium graphics profile
[19:54:32] > res 1280x720(0x)
[19:54:32] Changed resolution to 1280 x 720 ( NO MSAA )
[19:54:32] > sres 1024x1024
[19:54:32] Changed shadow resolution to 1024 x 1024
[19:54:32] Syntax Error. USAGE: set VARNAME=VALUE
[19:54:32] Type ‘listvars’ for list of tweakable variables
[19:54:32] Unknown command "aniso 4
[19:54:32] > set gSSAO=0
[19:54:32] > set gFXAA=1
[19:54:32] > set gSunRays=0
[19:54:32] > set gHeadlight=0
[19:54:32] > set gFoliagePercent=0.5
[19:54:32] > set gSimpleReflections=1
[19:54:32] > set gLODBias=1
[19:54:32] Metal macOS_GPUFamily1.1 initialized
[19:54:32] Graphics Vendor: NVIDIA GeForce GT 650M
[19:54:32] Graphics Renderer: <NVMTLDevice: 0x7fdcc8dd2000>
[19:54:32] RAM: 16GB
[19:54:32] CPU: Intel(R) Core™ i7-3820QM CPU @ 2.70GHz
[19:54:32] ANT : ANT USB receiver NOT found
[19:54:32] Loading WAD file ‘assets/UI/Achievements/goals.wad’ with file.
[19:54:32] Loading WAD file ‘assets/UI/Achievements/achievements.wad’ with file.
[19:54:32] Registered segment 1 with hash id 888000
[19:54:32] Registered segment 2 with hash id 888001
[19:54:32] Registered segment 3 with hash id 888002
[19:54:32] Registered segment 4 with hash id 888003
[19:54:32] Registered segment 5 with hash id 888004
[19:54:32] ERROR: GFX_CreateShaderFromFile(SSR): GFXAPI_CreateShaderFromFile failed!
[19:54:32] ERROR: GFX_CreateShaderFromFile(RadialBlur): GFXAPI_CreateShaderFromFile failed!
[19:54:32] Loading WAD file ‘assets/Environment/SkyDome/sky.wad’ with file.
Here’s an idea… Buy a old Mac… And test an update before releasing it on the world! Seriously who is your Test Manager… He should be fired!
Same on 10.12.3
Radeon Pro 450 2048 MB
Intel HD Graphics 530 1536 MB
