I have been thinking recently that a small degree of controllable
lateral movement for our Avatars might be a good idea.
The companion app could have a left and right button
to enable you to move to place yourself in the draft for racing
economy, or out of the draft, to help to overtake those in front.
It would be nice if I could give Zwift a hint to where I want to go. When I use the birds view during a race, I often find myself taking wind even if there is space for me behind the riders in front of me. Either the algorithem should be better, there is no reason I would like to take wind if didn’t choose to, or I should be able to override the algorithem and steer with the left-right arrow keys.
I really like this. It could be as simple as a “make a move” button that puts you to the side of the normal line and puts you in the wind for 3 seconds, during which time you can’t be drafted unless someone else clicks “make a move” to try and follow you. Clicking “I’m toast” could drop you back to the normal line. IMO this would really add to the immersion of the gameplay.
I put together a simple app (Mac only for now) that does exactly that, you might want to check it,
search for zwift-voice on github (I cannot add links here).
It works great when you use headphones.
On another note: I’m cycling 220 miles for Ambitious About Autism! If you’d like to support this brilliant cause, check out my fundraising page: /fundraisers/damiankosinski
