Q1—What I do not understand is how to connect those above devices to Adnroid tablet since Garmin Bike sensors are Ant+ and also I would like to see on the screen the heart rate from Garmin Forerunner 645.
Q2— Will I be able to connect speed and cadence sensor to Forerunner 645 watch and then it will be synchronised over Bluetooth to Android Zwift app?
Q3—Or I will need to purchase a special Micro usb Ant + sensor for android tablet in order to receive the signal from Garmin speed and cadence sensors?
Q4—Will I be able to see the heart rates from Forerunner 645 on Zwift android app?
Q5—Apparently Kinetic Rock and Roll Smart 2 comes with some additional InRide Sensor, will it replace the both Garmin speed and cadence sensors?
Q1-4: Simple answer is you would need either a CABLE or a 4iiii HRM to bridge the ANT+ signal to the tablet. At the moment you cannot connect directly to the tablet using ANT+ so it needs to be bridge to BLE. It does not matter if the tablet supports ANT+ or if you get a dongle on it you would still need either the CABLE or the 4iiii HRM to bridge the signal. The same goes for iOS devices just as an FYI.
By the way black screen on Lenovo Tab 4 10 (TB-X304F)
The world is black, but can see the menu, mini-map, can hear the sounds, and even can see some players icons over the black screen world.
Ok. Thank you. Got you now. This is a communication bridge called CABLE.
I thought in the beginning you’ve suggested to me a usage of physical cable … ))
But unfortunately this will be still an issue, since the Android Lenovo Tab4 10 tablet having a black screen on Zwift.
Thus, my only option left for the moment is to install windows on PC.
Be aware that the configuration app for the npe cable device is only on ios. If you have only android devices then the viiiiva heart rate monitor will be your only option for bridging ant+ to bluetooth.
For initial setup you do need an iOS device since the config app is only available on iOS, but after that you can use an Android device for bridging: https://npe-inc.com/cableinfo/cable-faq/
