Kinetic Road Machine Smart Power or Speed Sensor
Long story short, I bought this trainer to use with zwift, couldn’t get the inride working so went out to buy the garmin speed and cadence sensor.
I’ve been using those, now I got a new replacement inride from kinetic and hooked it up and it works perfectly now.
Zwift gives me an option to use the power source or the speed sensor?  Is there one that would be better to use over the other?
Thank you!
Hi Michael,
Highly recommend using the InRide as a Power Source. It’ll be more accurate than your speed sensor for sure!
I’m using the Kinetic Road Machine with inRide and it works great. I’ve read somewhere that inRide’s power is accurate within 2-3%. Not too bad considering the unit’s pricepoint.
