Kickr Core Calibration Issues
Hi all,
I bought my Wahoo Kickr Core 2nd hand almost exactly 2 years ago. I think I’ve done over 15,000 miles on it. I’ve recently been loaned a set of Assioma dual sided pedals (which have been all set up and calibrated correctly) to try and validate the trainer having been coned on various zwift events. This is where the problems start, yet also
• On average, the kickr reads 6-10% lower than the pedals
• This proportion varies with power. In the short anaerobic efforts (<4 mins) the kickr reads close to or higher than the pedals, but after that there is a significant drop off as described above
• This proportion varies with time. For example, I did this endurance ride this week, and the kickr fluctuated between 10% higher and 20% lower than the pedals
• This proportion varies with cadence. For example, in the prior mentioned ride, when I stood up, the kickr read in excess of 80w lower.
I’ve tried a few things to reduce this
• Standard Kickr spin down
• Factory Kickr spin down
• Various settings the kickr has for power smoothing etc
None of the above has fixed the power discrepancy. From the graph it looks like the kickr readings are oscillating between high and low power even with relatively constant Assioma readings. Any ideas?
Thanks in advance
Andrew
(Also during the ride shown in this image, the kickr was initially reading higher than the pedals, so I calibrated the Kickr, only got the trainer to read lower and be all over the place)
One thing you didn’t mention was whether you calibrated the Assiomas for your bike, including setting the correct crank length.
Apologies, I did do that too, will edit that in real quick!
I have exactly the same problem. With calibrated Favero Assioma Duo-Shis, there is a significant difference in measured power. Up to 160W, there is little deviation between Zwift and the Assiomas. At 200W Assiomas, Zwift measures 185W. Around 250W Assiomas, Zwift registers approximately 225W. In the meantime, I have tried to calibrate the Kickr Core 2, but I notice little improvement. During a Robopacer ride with Maria, Zwift registers 176W and the Assiomas 186W. I am now going to try to figure out if large deviations occur at higher power levels or during sprints. Have you solved the problem yet?
Hi Francis,
While I think my Kickr still reads about ± 5% that the pedals would (I don’t have access to them anymore), it doesn’t vary with time anymore. The only thing I think I’ve changed is to regularly (once per week or two weeks) carry out a factory spindown in the Wahoo app, which is done by connecting to the trainer and clicking the image of it 10 times in quick succession. I wonder if the slightly cooler temperatures for us in the UK back in February had something to do with the issues I had. Are the reported deviations in power also changing with time as mine was? You can see it visually in the graph above.
Hello Andrew, I still need to look into this further. In the past, I had a Wahoo v5 mounted on my road bike. Because it couldn’t be upgraded to virtual shifting, I bought a Zwiftride with a Wahoo Kickr Core 2 last year. At the same time, I had to undergo medical treatment and cycling became more difficult for me. My peak power dropped considerably. But now that power should be increasing again, and it’s stalling a bit (200W less sprint power). Hence, I started wondering if the Zwiftride is (partially) the cause? I mounted my Assiomas, calibrated them, started the Garmin cycling computer simultaneously with Zwift, and began comparing. The difference became immediately clear. I’m going to set up my old Wahoo Kickr and road bike again and mount the Assiomas. Curious if that registers different results? Or maybe it’s just the guy :wink:
Yesterday I attempted to select the Favero Assioma power meters as the power input in Zwift. However, Zwift only allows selecting the left or right pedal; both simultaneously is not possible. I performed multiple spindowns on the Wahoo Kickr Core2 after warming up. The deviations decreased when selecting the Wahoo as the power input source and now run level with the Assiomas up to +/-200W. My previous Wahoo displayed a wrench icon in the connection screen in Zwift to calibrate. The Kickr Core2 does not display this? I will use this setup for the next few days. After that, I will switch the setup back to my road bike and previous Wahoo.
Choose the left pedal, and you get unified power from both pedals
Correct, it is an auto-calibrating trainer. Manual calibration is only available through the factory spindown process in the Wahoo app. Calibration through the Wahoo app has always been the recommended way for all Wahoo trainers.
Your other option:
If I were in your situation I would be beating Wahoo support over the head with dual recordings from a single activity using both the trainer and Assiomas to quantify the difference.
It is strange, isn’t it, that auto-calibration allows such large deviations? Personally, it’s not too bad for me, considering I predominantly cycle between 160W and 200W. The average deviated by 10W over a one-hour period (176W instead of 186W), a good 5.5% to 6%. But during sprinting or climbing, it increases significantly. Cyclists who pedal at higher average power outputs quickly struggle with deviations of 10% or more. I am curious if calibration according to “New spindown Core2” will completely solve the problem. Thanks for the advice and input.
Same issue with the same setup. When getting up to 300w it is close to 10-12% difference between power.
