Kickr / Campag 9 Speed
With an ‘old’ Ribble and Campag Mirage 9 speed, in order to make use of a Kickr Core Zwift One, would purchasing the ZWIFT COG + CLICK UPGRADE KIT make my bike compatible?
That should work. If the chain is worn, get a new chain at the same time.
Thanks!!
Hi @Rob_Shillitoe, Welcome to the forums!
I’m Fernanda, from Zwift.
I would like to follow up on your question and put two cents on this post! The Wahoo KICKR CORE Zwift One is compatible with your Campagnolo Mirage 9 Speed Group Set, the Zwift Cog expands our compatibility as a universal cassette, once you receive the new trainer, you can follow the instructions below for mounting of your bike on the Zwift Cog.
Enjoy your rides and virtual shifting!
Thanks for this. I’m pleased to report I purchased the Kickr Core with cog and clickr and it works perfectly!!
Rob
For future reference, you could also just use a Shimano-compatible 9-speed cassette (plus the required ~1.8 mm spacer), the cog spacing is the same or at least close enough.
