My Kickr Bike will no longer connect as “Controllable” following the update - power and cadence connect ok. I have a fairly new PC (not a potato) and connect via companion app. I have rebooted both PC and bike.
This doesn’t happen if i use Zwift on Apple TV with Companion.
Yes there are plenty of people experiencing a lot of issues right now across all the techologies you mention triggered by one of the last 3 releases. Search the forum and you will see thread aplenty on them . Sorry I cant specifically point you to correct thread for your issue , firstly as for now its not affecting me ( tacx neo - but its only a matter of time I am sure ) and Its a bit chaotic and haphazard on what is fixable , known , related etc because there is no zwift system for acknowledging and tracking issues with us , and support process itself not using tracking references. Seems some issues are picked up and others ignored completely . I think your specific issue however is currently sitting in the long term not acknowleged or fixed
Suggest you need to probably contact support on a one to one basis on this one perhaps.
I think i saw a mention of the order of which you pair power and controllable will fix this. One of them has to go first and then the other will pair correctly.
it does not work for my Kickr Bike - I have a MacBook Pro using Ant+ for Power and Cadence will not connect or even attempt to connect bluetooth for controller which enables steering
The issue is their merges at the end of sprints - if they would not wait till the end of sprint to release fixed or new features but roll them out as they test and complete - their merges of code would be much simpler
