I’ve recently found this resource and reference it before trying new routes. It appears a good resource but I’m not sure if the fastest combinations for climbing are accurate. At my level-29-if you look up Ven Top for instance, it cites the DT Swiss Arc 1100 wheels as superior to both the Enve 3.4 and Zipp 353 NSW, both of which are quicker climbers on Eric Schlange’s speed tests. Any explanation anyone?
I don’t know what’s under the hood at zwifterbikes but @Eric-Schlange-ZI has a scatter plot of performance vs the Tron bike that shows the DT Swiss ARC 1100 DiCut 62 wheels as faster than those wheels by a second or two on the Alpe. I think the take away is that there is no difference on steep stuff, but the DT wheels will be faster on the flats so they remain one of the best wheelsets in the game from level 6 onward. This was surprising to me as well, but that’s Zwift. I still use the DT wheels at level 43.
Suggested frames and wheels will often change with the W/Kg you tell it you intend to use.
I use the Aeroad 2021 and those wheels for just about everything but usually swap to the Cannondale Evo and Zipp 353 NSW for long climbs.
Interesting, graph seems to go against the results shown on Eric’s bar-charts of wheel performance on climbs where both the Enve 3.4 and and Zipp 353 come out as being faster than the DT Swiss ARC.
True but the differences are so small it just doesn’t matter on the long climbs. If one wheelset is 3 seconds faster on the Alpe that’s just noise.
How it works
All calculations in this tool is based on wheel and frame tests data published by ZwiftInsider.
The “Golden Source” for the baseline data is the Google sheet provided by ZwiftInsider with all the actual test results; not derived results in charts, tables and articles.
Usage of this Google sheet as “Golden Source” has been confirmed by Eric at ZwiftInsider as the correct approach.
The wheel and frame performance tests for flats are done on two laps of Tempus Fugit, a 17.3 km (10.7 miles) long route, virtually flat with only 16 m (52 feet) elevation.
The Climb performance tests done by ZwiftInsider are done on Alpe du Zwift which is 12.4 km (7.7 miles) of pure climb at average 8.5% gradient till a total elevation of 1053 m (3455 feet).
Please see https://www.zwiftinsider.com for further details about these tests.
These performance tests determines frame and wheel savings on flats and climbs vs the standard Zwift Carbon bike.
(continues on linked page…)
I take the ZwifterBikes results as accurate. It’s also WAY easier to use as a tool for comparison than any other resource I’ve seen.
TL;DR: the difference between frames and bike is tiny, with only seconds difference over long routes. Ride what you like, unless you’re trying to set a PR on a specific route. Zwift themselves stated very early on they will never be “pay to win” so it tracks that the differences between equipment are small.
The Golden Source for ZwifterBikes is the Google sheet that ZwiftInsider kindly provide as a separate download, and not derived results in charts, tables and articles.
I believe you are referring to the Wheel Ranking Charts where the wheel ranking on climbs is as you describe, but this appear to be one of the “derived charts, tables and articles” that has not been retrospectively updated following new tests that ZwiftInsider has recorded in the Google sheet.
Google Sheet numbers vs Wheel Ranking Chart numbers:
DT Swiss ARC 62 2959 vs 2960.5
ENVE SES 3.4 2960 vs 2960
Zipp 353 NSW 2961 vs 2960
A very small difference, but enough to swap the order depending on which source you use as master. As mentioned, ZwifterBikes uses the Google Sheet with values 2959, 2960 and 2961 and hence the ranking on Ven Top is aligned to this.
Thanks for that! I suppose it doesn’t really matter in the great scheme of things as the difference is so small, except that psychologically it feels better to be on the best set up especially for climbs as climbing is not my forte. What I really need is an extra watt per kilo but I don’t think I’m going to get it at 65 years of age!
Best wishes.
Gary
I’ve had a reply from Eric who has updated the wheel performance chart and this now shows the DT Swiss do in fact outclimb the Enve and Zipp 353-at least it will save me swapping before big climbs.
Can’t see an “official” Zwifterbikes thread, but just seen the new Canyon Aeroad 2024 has been added.
It’s fastest frame for Coastal Crown Loop, this week’s zmonthly event, plus Mayan San Remo (late joining chase race for this by @Tim_Perkin Mountain Massif at 1700 BST), for example.
On the big climbs the wheels can be less important from lap to lap than your own condition and your pacing which can easily make up for differences in wheels.
That said on ADZ I’ll usually have the Alpinist wheels or one of the 30+ sets of Meilensteins I’ve earned on ADZ over time.
I generally only ride very mountainous routes so happy to use those wheels only.
Is this now the un-official ZwifterBikes thread?
If so, note that I have now added all the new routes from Zwift version 1.73:
Two more routes added:
Just published an update of ZwifterBikes with the following:
Laps: You can now use the Laps slider to select the number of laps in a ride. The estimates will include lead-in time and time to complete all laps, giving you the total time for the entire ride.
Pacing profile: Before, all estimates relied on a constant power output, similar to ERG mode.
Now, you can opt for a Dynamic Pacing profile, allowing you to simulate more effort on climbs and a bit relaxed on descents.
This should give more accurate estimates on rolling courses, even fine tuning the bike rankings!
The midpoint setting gives a similar pace profile as the Pace Partners uses, adding about 10% more than target power on climbs and easing off 20% on the descents, but you can pull the slider a bit further for an even more dynamic pace.
Lead-in always included: A while ago, I introduced Lead-in time as a separate metric.
Now, I have instead included lead-in in all totals by default, but breakdown is available in the detail pages.
Are you going to add the new routes, or was this Zwift rollout too much to handle?
It did strike my mind to call it a day, but happy to let you know the upgrade is now in progress. Nearly there.
Finally, it’s done. I have now updated ZwifterBikes with the Frame upgrade feature, the wheel on Road frame vs TT frame speed difference, 9 new frames, including the Halo bikes, as well as 15 new routes. With any luck ZwifterBikes should now be in sync with version 1.88 of Zwift. Better to read the full list of changes at zwifterbikes.web.app/history.
This should give you a brief idea what has been done:
Please let me know if anything does not look right.
Thank you
The only oddity is that the Pinarello TT Halo bike is not included when looking at “just TT” and “halo”. I suspect it’s set as a road bike.
