Introducing: Progress Report Screen [December 2025]
If you click or touch anywhere on the screen the timer will stop.
Is there any rationale I don’t understand behind leaving out the drops increase and overall number on the report?
Ummmm, no one cares about your Zwift progress report. You don’t need to share it.
The people want this kind of feature, they like sharing their progress. There is no reason why Zwift should get in the way of that. It’s good business and that’s good for the rest of us who don’t care about seeing it.
Hi! Any idea why the FTP shows an outdated number on the progress report? My current ftp is 30 W lower than the one displayed after my ride today. I had to go in and MANUALLY change the FTP on my profile page ( which I set up or last updated a few years back), so the FTP would match where I currently am. Shouldn’t the progress report display current ftp? Thanks!
It seems to have been working correctly in that it displayed the FTP number stored in your profile.
Now we need to ask, why do you think that the FTP in your profile is/was inaccurate? Unless I’m misunderstanding?
Please add more levels then 100 :smiley:
My ftp in my profile was about two years old. Things have changed a lot medically since then so my ftp is nowhere close to the old value. I manually changed the ftp in my profile once I realized it was being used on that progress report. I thought the progress report would indicate CURRENT ftp.
Ok, it sounds like what’s happened is that your FTP is now lower than the old value stored in your profile.
Zwift doesn’t automatically update your FTP with lower values as opposed to higher values, i.e. it doesn’t lower your FTP. It’s easy for Zwift to see a new higher value and update that, but if you’re producing less power then it’s harder for Zwift to know if you just weren’t going all-out or whether that’s in fact the best you could do.
What you can do if you feel like your FTP will have gone down is to deliberately set it way too low, then Zwift will likely detect an increase from that when you do go all-out, setting your current value a bit more accurately.
James told me that an FTP test with a lower result will update the profile, but any other ride will not. I have not tested this since my FTP only goes up. (Just kidding, I don’t do FTP tests.)
Also, if you ride up The Grade KOM, there is a sign just past the banner that will say “Your Grade” with a number if it is not greater than your profile FTP, and will not update anything. Take a screenshot or make a note of the number. The sign will say “Your FTP” if the number is higher than your profile FTP, and it will update your profile in that case.
Can confirm. The FTP test as part of the Baseline series updated my FTP to a lower number. I didn’t realise that it would, and did that stage carrying a lot of fatigue so got a terrible score.
If your coach asks to see this as a summary of your week, get a new coach. Obviously, you’d hope any coach would have visibility of your training elsewhere but this screen tells you nothing about if you’ve completed your set training for the week, the spread of intensity you’ve done over a week, any recovery information. This screen is only useful for long term zwift goals.
pretty sure that this algorithm is in use on the climb portals too as back in September I did the cheddar gorge climb and set a new 90day 12min power pb which gave me a new FTP in zwift
My understanding is that this algorithm is used everywhere, it replaced the previous 20 min effort as the basis for FTP updates outside of FTP tests. The nice thing about The Grade is it gives you a number even if you didn’t achieve a higher FTP.
This looks like a really nice update, I like how it tells you when your overeaching/Overtraining which is something ive been guilty of in the past. Its nice to see all the stats in once place once finishing a ride.
@shooj , since it includes “Fitness Trends” will that ever be updated to incorporate running, otherwise, that part of the screen is just GIGO for those of us who both bike and run.
Lloyd,
If you are worried about overtraining, check out the Zwift Companion app, it has several charts that track your progression on several metrics, one of which is your training stage (detraining, fresh, productive, over training)
cheers
Now you are trolling.
I’m a bit confused why this is 1 step after the “end and upload ride” flow as opposed to being part of it. Wouldn’t it make it easier to let people send it as part of the package to strava/garmin/etc
Thanks Paul. Makes sense.
