Install Stuck on Pending [Android]
I am trying to install Zwift on Android via Google Play.
My tablet is Samsung SM-T820. According to Google Play it should be compatible but install just sits in “Pending…” state indefinitely.
Jim J
Hi @Jim_Jackson
Does the pending start right away, or does it happen part way through the download?
If it starts immediately, the most likely cause is that your tablet is having a hard time connecting to the Google content delivery servers. If it happens mid install, it may be that the download from Google Play is corrupted.
Try using a different internet connection, such as a mobile hotspot or a friend’s Wi-Fi- that uses a different ISP. this should force the download to use a different connection path to Google and get a fresh copy instead of the files instead of one that may be corrupted.
Let us know how it goes.
Thanks for the quick response Terry.
I realised that it was not a Zwift issue but a Google Play one. No apps could be installed. Not sure what I did specifically to my Google account settings but it is okay now.
Thanks Jim J
That’s awesome, I’m glad it’s working now!
Sometimes if this happens if you change the download preference to be over any network (even if your device is wifi only) this can fix it.
It is a google play bug that happens sometimes.
