Inclination on Bkool simulator Zwift powered
I feel that % of climb/descend is not real as with the original Bkool program.
Too “easy”, in a way.
Anyone experienced the same ? Solution?
Cheers
You should probably read about the so-called ‘Trainer Difficulty’ setting at https://support.zwift.com/en_us/settings-menu-(cycling)-H1jlA1WBQ or in the in-depth article at Using the “Trainer Difficulty” Setting in Zwift | Zwift Insider
