Image upload to Strava
 Hey guys,
Might be an obvious answer, but when I save a ride to strava.com from the game I get no pictures uploaded. Even if I take snapshots during my ride. I have to manually upload images in strava. I have noticed clean images been automatically uploaded from the game, how can I fix this.
Check the “Settings” screen in the game. There is an option to upload images to Strava.
Hi Eric,
That box is ticked it still does not upload.
Are you able to upload the picture manually from within Strava?
Yes that I’m able to do.
Hmm. You should open up a ticket.
One last thing to check before you submit that ticket. If your uploads are set to Private in Strava, the automatic picture upload will fail as well.
Hi @ZWIFT, sometimes, my ZWIFT uploads a picture, but more and more, there is no upload. Just the result, but without a picture.
I did not change any settings in Strava between the last successful upload and the failed one. I just checked the privacy settings. All is set to PUBLIC.
Could you check this?
Thanks! And best regards,
-André
Hi Andre Grunow
I can confirm that behavior. Sometimes it works, but 3 out 5 it will not upload.
I’m using the Mac version of Zwift.
Regards
Christoph
I can confirm that as well. Zwift on macOS, image upload stopped working on January 16 (± a day). Can others confirm this date?
Cheers,
Raoul.
Raoul, I can confirm the date. I checked my Strava Feed and the uploaded stopped also on January 16. Since then the automatic upload is not longer working (from my Mac OS Computer).
Regards
Christoph
Agree 16th was the last.
For those who are having trouble with the auto-upload of photos to Strava, you could try the details in my KB article that describes how to upload screenshots manually, to Strava:
How do I attach more than one Zwift screenshot to my Strava activity?
When you are riding on Zwift and take a screenshot, it can end up becoming visible in your Strava activity. Taking screenshots is easy, and covered in another KB article:
Depending on your Zwift settings, your application can take its own screenshots, or you can take them yourself. Your screenshots will be saved in your \Pictures\Zwift folder on your machine, whether it be a PC, Mac and in your Camera Roll on your iOS device. These “clean” screenshots will have a _clean postfix in the filename, such as: 2015-04-29_1947440_clean.jpg.
The first screenshot taken by Zwift itself is taken without any “HUD” (Heads-Up Display) panels on the screen, so it will appear clean and bare:
When you look at your uploaded Strava activity, you’ll see this one, single screenshot there in your event.
But you may want to take more screenshots, or take those perfectly-timed screenshots when you cross the line first in a race event, and include those in your public Strava profile.
There’s a limitation of how this works with Strava, and many have complained they want this expanded to include support for attaching images from a desktop web browser. So far, Strava has been resistant to add this capability.
For now, you can only attach supplemental photos and screenshots to your Strava activity from the Strava app on your mobile device.
To add more screenshots, you’ll need to put them somewhere that your mobile device can get to them, using a tool like Dropbox, Google Drive, Box or another tool. Once those images are accessible via your mobile device, load up Strava and select your specific activity.
Once there, you should have a menu option or button to edit your Strava activity. Here’s how it looks on my Android device:
On an iOS device such as an iPad, the “Edit” button is located in the upper-right corner of the screen.
When you choose “Edit activity” the activity, you’ll be presented with a different screen, where you can then tap the [+] button to add additional images. On your mobile device, browse to where your custom screenshots or images are and choose them one at a time.
Selecting one of the existing images your Strava activity will allow you to add a custom image caption, remove or replace that image.
At the bottom, when you select “Save Activity”, those images will then be posted to your profile and saved within your Strava activity.
That’s all there is to it! Now get out there, ride and showcase those amazing screenshots with the rest of the world!
Same behavior here, Autoupload on Windows 10 x64 also stopped January 16.
Me too. I have started Zwift from 02/19/2017 and never suceeded in autouploading on Windows 10 x64.
Image uploads to Strava have been disabled, so you have to upload images manually. See my KB article for the details on how to do that:
