I have the zwift Runn but it’s not sending my elevation gain to zwift or zwift companion. It’s in my garmin app.
Does anyone have a fix for this??
I don’t think Zwift records any elevation changes for running, does it? My understanding is all Zwift running is treated as flat ground, even running up AdZ.
Ok thanks
That’s unfortunate! I hope they upgrade
Probably not possible (or reasonable) until there are true Zwift-compatible treadmills that change inclination as the road goes up (and down??).
Don’t know if this helps. U can find the elevation in the graph of the companion app after the run. The elevation is also transferred to Strava…image|497x500
That’s right Melissa. It doesn’t show the elevation in the profile. So far u can c the elevation only in each single activity…
