Garmin Sync Issues?
My outdoor ride on Sunday did not sync to Zwift. The sync has been flawless since I set it up when the feature first became available. Never had an issue before.
To try to correct the sync issue, I deleted the activity from Garmin Connect. Then deleted and recreated the Garmin connection in Zwift Companion. I reloaded the ride to Connect from my Garmin Edge 830. It shows up in Zwift Companion now, but it does not show any XP associated with it.
You can ask support for the XP. Then do another outdoor ride and see if it was a one-off problem.
