Garmin FR265 no longer displaying HR on zwift
This worked flawless in the past. I set my fr265 to broadcast HR ( iPad ) forerunner is detected, but my HR stays at 0 in Zwift
My wrist shows the red hearth rate icon and is measuring correct.
Restarted Garmin already, also rebooted iPad
No luck.
Any idea since this worked fine for a long time
I have a 965, had similar issues with a different HRM. I would, select “indoor cycling as an activity” on your watch. Pretty sure Zwift will see your heartrate.
When you are done, just bin your activity on your watch. Kind of a pain in the butt, but I’m guessing it will fix your problem. @Robby_Van_Mieghem
I actually tried that but no luck…
Strangly I tried it on my iphone… and selected virtual running, and then the HR appeared on zwift
Something must have changed.. in zwift or in garmin…
if your watch is paired to your phone try turning your phone off or turning bluetooth off on your phone then loading zwift on your ipad
That’s not the cause. I have tried disabling BT on iphone.
Something has changed zwift or garmin
enrolled my self now as a beta tester on the forerunner, let’s see if that solves its fast
