The, what I can only assume is cylindrical, 2D graphical cloud layer seems to be clipping through the 3D mesh of the surrounding mountains.
SA’s bug is a wild one.
I’ve never once had issues running many multiple rides without having to restart Zwift before; and definitely nothing like that.
Side note; the asset streaming while loading into Watopia though is a bit wild now; almost a full minute for things to be popping in. A bit on the extreme side when some of us have beasts of computers.
I presume this was just a choice to help lower end machines?
This was really apparent in the desert on my first 1.51 ride. Get in, think “huh, major update here, lots of nice new textures, but I guess they decided to take out all the foliage?” And about a minute into the ride it all popped into existence. The dead leaves on the new road also just popped into existence right in front of me when they first appeared. (side suggestion to ZHQ, just nix the dead leaves, they don’t add any ambiance but do seem to affect performance)
i fixed it brother (zwift and fps monitor do not like eachother. i don’t think it will affect anyone in normal use. if you are going through something similar, it’s possible an overlay app or something is interfering with zwift. disabling it might help) but that solution would not work well for me. for example , i like to line two or three events up and do them in a row. having to leave the game before each one and possibly miss the start of an event would get infuriating fast. anyway, problem solved, other than the fact that the game is running equally as bad on my gaming + editing pc as it is on my £300 zwift pc. looks pretty at least
will keep an eye out. some minor things i noticed were the black squares, though i think zwift are aware of that one, increased loading times and textures taking a while to load properly, and also if you flick through the side bar when fan viewing people the game eventually stops loading in people’s usernames and their equipment. could see that one causing TTT directors some grief
just want to say that the game does look nice, it’s cool, i do appreciate the update. i like my frames though
On what device and spec? New update is very heavy in CPU usage for Watopia so perhaps you are hitting the limit….?! How does Makuri load?
Also try turning off video screenshots if you have that option and it is enabled; that will reduce system load and may get you back in the game for now.
Bright colours bleed through from one side of the screen to the edge of the other. Will try to get a screenshot to show it; most noticeable in the volcano, bright yellow lava from one side bleeds through and shows in the edge of the opposite side.
An older issue that has been raised I believe but seems back/worse on 1.51 and now left-right as well as top to bottom.
If you’d like, you can upload a video recording to YouTube if you have an account there (you can set it to unlisted/private) and share a link to it - it would be helpful to see more details on this one.
This has been happening for a while, but I think it’s worse after the graphics update. Visible here. Just the sky bleeding through. Used to mostly take Tron bikes to do it (plus some other bright objects)
Having the same problem. My HR strap is no longer cnnected (companion via atv). iPhone says in the settings it’s connected. Please fix that zwift. Seems an ATV issue with 1.51
Hello, When will there be updates for mountain biking? Specific equipment, wheel… Mountain biking requires more effort but fewer kilometers but you have the same rewards as a road bike. It would be nice to have different rewards. Thx
No, it is not the workout pain effect. It is a display/graphic effect that makes the side borders of the display look like with vertical banding to give it a more 3D “kinda” visual effect.
