Flux 2 with Swift Power keeps 'cycling'
Every time i do a work out on Swift i get this affect:
It has never been smooth and just keeps fading in and out of the correct power. I have tried Big ring and Small ring. It just keeps doing it. Sometimes whilst doing a work out i need to change gear for the power output to keep in range.
I have tried it both with ERG On and Off in a workout but there is no change.
I use an iPad via Bluetooth.
Thank you in advance
Nev
Can you replicate this behavior in the Tacx app? If so, you should talk to Garmin about your trainer. The trainer can also take a little time to adjust resistance in response to cadence changes, so any testing should involve very steady cadence to avoid making the trainer respond frequently.
Hi Paul,
Thanks for your reply. I have a separate cadence meter so I keep an eye on cadence and it happens whether I’m rock steady on cadence or not.
I tried Tacx app this morning, via my phone, and that was rock steady for about 10 seconds and then dropped out. I couldn’t get it to reconnect so gave up!!
