I find it really unhelpful to finish a workout segment and only receive the feedback that I failed. I don’t even know what criteria is being used for the harsh critique. On an hour and half ride with nine intervals I get to the end to have Zwift tell me I failed. There must be a better way to provide more positive and helpful feedback on a workout.
Hi Tim,
There is nu solution for this at the moment in Zwift.
What you can do is compare the required watts with the watts registered in Strava.
#Rideon
I posted it in the feature request section. Thanks.
Allright Tim, I am aware of that. No problem.
There needs to be an average shown at the end of the segment. I often go too far above and get failed rather than credit. That isn’t a failure. I felt strong and went a bit above. If I was aiming for 250 watts, I have to look to strava to find out I did 275? It should be a simple fix, especially not failing to get a star for going over the wattage needed.
