Error ZLM06 [SOLVED]
Same here on Puerto Rico. I use Imac27.
Finished a Zwift session, got logged out after saving (hate that, please fix it) - went to log in to check stats and getting ZLM06 error as above on both the MacBook I used for the session and also on my MacBook Air…
Help!
UPDATE
I did a restart of my MB Pro and on re-starting it did some kind of system update - when that finished I tried Zwift & it started fine.
Mind you, no restart on the Air and Zwift just started up fine on that too, so it looks like it was a Zwift issue
me too… same error, same macbook pro
Using a MacBook Air and having the same issue in NY
Having the same issue on a MacBook Pro here in Australia
Having the same Issue MacBook Pro in Kuwait
Same here iMac 10.15.4, nothing seems to fix it.
Same here, tried to restart computer, change network, reset DNS cache. Nothing works. Macbook Pro Ireland.
Having the same error in Melbourne. I have only been on zwift for 6 weeks with no issues and used it yesterday…turned off and on again…no help.
Try this link and see what it look for the results in the US-West-2 region (Oregon) (you should get all Green check marks if successful): http://ec2-reachability.amazonaws.com/
Zwift Status: https://status.zwift.com/
Same here in Colombia
iMac. macOS Catalina 10.15.4
Yes same issue here, hopefully they will sort it out quickly for us
All green here… still won’t work
same here in Germany on a MacBook Air. status is all green, btw.
I tried the link (I’m IT not savvy so I don’t really understand it) and I had all green ticks.
same issue here in Florida. nothing seems to function anymore. frustrating. and nobody from zwift is available to respond?
Paul, checked both those links and I see green check marks for all rows and Zwift status is operational. Still getting the error.
Someone tried unninstaling and re installing the app?
I did… no luck
I did too and nothing
