Hello, I’m new in the world of Zwift and at the moment I’m using the zwift trial period.
I have a VirtuFit HTR 3.0i Ergometer Hometrainer and is zwift compatible.
I’ve been using zwift on my Galaxy S21 Ultra so it connects with Bluetooth but for some reason ERG mode is not working.
Zwift says ERG mode is on but no resistance change.
In de zwift connect option the everything is connected to control the bike.
I’ve been testing workout that using ERG mode but nothing is happening.
Did I miss something?
Of somebody has a solution for this problem.
Zwift looks like fun way to train, but if the ERG mode isn’t workings I find the subscription a little bit too much.
I had a look at this article, which lists all the indoor bikes officially supported for use with Zwift. I’m sorry to say that I did not see the VirtuFit HTR 3.0i Ergometer Hometrainer listed on that webpage.
This usually means that while the bike may connect to Zwift, it hasn’t been tested by Zwift’s developers nor has it been officially approved for use with Zwift.
Essentially, the device likely isn’t supported and this may be why the resistance doesn’t function. Sorry for the bit of bad news, but there you have it.
