Hello,
We having a new sport centre in my region that was made mostly for yearly international Iron Man in the region. So municipality made a big investment by building a pool, special gym etc…etc…etc…
Between the equipment in the gym there are dozens of CycleOps Phantom 5 each one equipped with a dedicated MacOS tablet. Only two apps on each tablet: Rouvy and Zwift.
I’ve tried Zwift on Phantom 5 for several days and found it extremely difficult to manage any ride, since there is no option to change gears on it. Actually my only option to control the resistance is by re-configuring the Trainer difficulty settings each time, what make the whole ride very uncomfortable.
Lets say the ride starts on the flat and the trainer difficulty is on the max level: still with this difficulty by pedalling with cadence over 100 I will barely make even 300-350 Watts and then will just pedal in the air without any resistance from the trainer. But all this change when hitting the climb in some cases it is almost impossible to pedal at all since there is no option for gear change.
As I’ve found the only option to use this trainer with Zwift is by changing the trainer difficultly during the ride, but this is totally not normal usage of the trainer. And with this configuration it is impossible to participate in sprints or any real competitions (there are no option to sprint or to bring at one moment big amount of power with this trainer).
With all those details and descriptions the bottom line question is really simple:
Is there any way to switch gears with this trainer?
And second one: are there any plans for real Zwift support for this trainer?
