I used the Zwift Compaion App on my phone to link my Apple TV to my Zwift Hub. I have been experiencing repeated dropped connections since the update, and I have restarted both my phone and the AppleTV. That was no help. There are no connection issues when I connect the Hub to my iPad and mirror the screen to the AppleTV.
Anyone else having this issue?
When pairing via Companion, the connection depends on WiFi connectivity from Companion to Apple TV. When you pair directly to the iPad, it’s using Bluetooth. So one possibility is that you are experiencing problems with WiFi performance. If the phone has the WiFi Assist feature enabled, that can also cause the phone to switch to cellular data instead of WiFi, so turn that off, or put the phone in airplane mode and enable WiFi.
