Companion app will not connect - MacOS 27 and iOS27 Beta
Hi Guys,
So now MacOS27 and iOS 27 are in beta I did upgrade my macbook and iPhone to these purely for the improved battery life on the iPhone (which is def a welcome improvement). I have not had a single issue with either update APART from Zwift companion app refusing to connect to Zwift running on my Macbook Pro (m4 Pro).
In the past this has often happened when you get a big update on either MacOS or the iPhone and this has always just been fixed with either a clean install of zwift or updating network permissions, but in this instant I have tried everything over the last couple of weeks and no matter what I try the Companion app will not find zwift running on the network. So something in either the new MacOS 27 or iOS 27 updates seems to have broken this permanently.
If anyone has found a temporary workaround please let me know.
I have tried multiple fresh installs on the macbook of zwift and the companion app on iPhone and a new dedicated wifi network just for the two devices but it never links up.
I appreciate these operating systems are only in Beta so things like this are likely, but at some point a fix will be needed before full release in a couple of months.
@Chris_D9 also observed this. I’m not aware of any workaround.
Yes, there is no workaround for now. The problem doesn’t seem to be iOS 27 developer beta, but MacOS 27 developer beta. New installs do not make any difference.
  • I have tested iOS 27 with Zwift on MacOS Tahoe, that works.
  • But iOS27 or iOS26 with MacOS 27 doesn’t work.
I have reported this to Zwift already.
Something else I have noticed is just on start up of the computer (M4 Pro Mac Mini) is that it is very slow for my bluetooth mouse and the Apple wireless keyboard to pair up with the computer (at the login screen) compared to before. That’s another annoyance.
Hi @Daniel_Haynes_RHINO
A workaround is to open ZwiftAppSilicon directly from the ~/Library/Application Support/Zwift folder.
You’ll get some permission prompts, be sure to allow them.
Kudos to Berto for finding this:
Note you should still run Zwift from the launcher to get any updates that may be available.
I have forwarded these findings to Zwift.
oh nice, thank you! I didnt have any permission popups but for sure it connected straight away using ZwiftAppSilicon instead of the launcher.
I can finally respond in chat again! :joy:
I updated to macOS 27 general release and the problem appears to be the same. Will try the direct open workaround.
Same problem. It seems like the issue is that Zwift is not re-asking for the necessary permissions. Please fix quickly. Riding without companion app is really annoying.
its def something a little more involved with MacOS. I have exactly the same issue with the Mac Sonos app not connecitng to my system from my macbook.
Forcing a full reset in MacOS recovery terminal gets you all the prompts to allow both apps to find devices on your network but to no avail.
Thankfully the workaround ZwiftAppSilicon works 100% every time. so I just have that on my dock instead and dont notice any difference tbh, apart from having to type your password each time you load. when i see a zwift update i boot the launcher just to grab that.
Im sure it will get fixed eventually.. and probably soon now MacOS 27 has been fully released
Looks like installer 1.18 for macOS fixes the issue, but you have to grant the various accesses.
Installed the installer; launched ZwiftAppleSilicon from the installer; confirmed that trainer WiFi pairing worked; launched Companion; joined a robo pacer. Companion synched. Then I shut down and launched from the icon in the Dock and everything was clean.
Yup there we go.. just downloaded the installer again and installed zwift straight over the top even though i was on the lastest game update already.
loaded the normal launcher and it asked for three permissions during game bootup and as soon as i went into a route the companion app connected as normal.
So the installer obviously just fixed whatever the problem was with the launcher.
Ride on!
Hey all - I wanted to confirm, using the Launcher version 1.1.18 (latest on web) should solve this macOS27 issue. We will be installing this version automatically with the next Zwift release.
You can download the latest version here: Download Zwift on iOS, MAC, PC, or Android Devices | Zwift
