Hi there, not sure if I’m missing the location but for the life of me, I can’t locate the plans developed in training peaks that normally download and can be seen in Zwift. Anyone else experiencing this?
There have been a couple threads about Trainingpeaks issues recently that you might want to check out
Thanks for all of the recommendations! It looks like the problem was on the Training Peaks or my coach’s side and was isolated to that one single workout. Everything is working normal since then. All is good in the world!
Marty Slack
Sometimes there can be an issue with the validation between TrainingPeaks and Zwift, so even if it is still connected it would be a good idea to disconnect and reconnect them again to create a fresh connection. You also might want to try scrolling through your list to see if your TrainingPeaks Work…
