member of only one
This sounds similar to another bug report. I’m curious if changing the device language to English helps. This is purely speculation on my part.
Yes I am member of 1 club only.
Ok…is there a zwift team programmer able to answer that technical question ?
Try and change to English to see if it works. You can edit it after creation to whatever language you want.
it works
Hi @Carlo_Sirtori and @LUC_FUGGETTA_BIKES-F
Thank you both for reporting this issue. We’re investigating.
UPDATE:
We have reproduced this bug in non-English user interfaces of the Companion app. We’ll get this fixed in an upcoming release of the Companion app.
WORKAROUND:
- As noted upstream - temporarily switch to the English UI to create the Club.
- Revert to your preferred language once the club is created.
Where can I change the language ?
you need to change the language of your PHONE or DEVICE in english. Not on the companion app. Then create the club and you can go back to your lamguage
Ok clear. Done deal on it works .
Thanks to all for your help and perseverance
UPDATE November 15
This issue will be fixed in the next Companion release (version 3.53). Thanks for your patience.
@Carlo_Sirtori @LUC_FUGGETTA_BIKES-F
Update November 29
Companion app v 3.53 fixes this issue, Please update at your earliest convenience. Would you let us know this solves this issue for you?
Hello ZWIFT Team,
Thank you for the correction. All is now working fine with non English language…at list french
All the best
Ride On
Luc FUGGETTA
Envoyé de mon iPhone
