Sorry if this is obvious but I cannot see it anywhere. I’m down as C Cat but cannot enter C cat races. I’m slowly recovering from a long layoff, I was a happy B cat a year ago.
Any help, obvious remarks, etc appreciated, once again sorry if this is plain as day to most folks.
At the risk of boring you, is it normal that lighter riders, such as myself at 64kg, post bigger numbers on routes with significant hills? I can’t put down the same power on flats it seems.
yes, from a w/kg point of view you will have much better performance on hills than heavier riders. Look for races that include bigger climbs to play to your strengths.
I wonder if you smaRt trainer is overestimating the power on the climbs or underestimating on the flats…you should hit the same power numbers on the flat as on the hill. Check you HR bpm and test 5mins on a climb and 5 mins on a flat at the same HR (Tempo at around 90% of your FTHR)
