Bug or Feature? Holographic Replay/Other Player Holograph Appears
Hi, I’ve noticed that when I am riding, at times there is another personal’s holographic who apepars when I pass an important point. For example, tonight I did a brief ride on Tempus Fugit. I have not been on Zwift for a couple of month (summer break). At some point, perhaps when I started the Fuego Flats segment, someone else’s Holographic Replay/Ghost/PR Bot showed up and then disappeared when I got to the Fuego Flats arch.
Is this a bug or a feature? As It think this through I could see that it is a feature if you don’t have a recent PR. I looked at the log and saw a function called: GetOtherPlayerPlaybackPr and wondered if that what brings up another rider. As you can see from this log snipped, GetOtherPlayerPlaybackPr was executed after I started Fuego Flats, so the timing is right.
[17:30:55] TimingArch: crossed arch start line Fuego Flats
[17:30:55] [SegmentPortal]Segment 1020562761 started on Portal Road 10013
[17:30:55] LIVESEG: Sending Active Segments.
[17:30:55] DEBUG LEVEL: TimingArch: Fuego Flats wants to show timerF
[17:30:55] [ZNet] RRPC::IsRetryable (GetOtherPlayerPlaybackPr) outcome not ok: 404
[17:30:55] [ZNet] RRPC (GetOtherPlayerPlaybackPr) in error state, and initiating retry logic…
[17:30:55] [ZNet] RRPC backoff index: 1, backoff delay milliseconds: 1000
[17:30:56] [ZNet] RRPC (GetOtherPlayerPlaybackPr) retrying…
[17:30:56] [ZNet] RRPC::IsRetryable (GetOtherPlayerPlaybackPr) outcome not ok: 404
[17:30:56] [ZNet] RRPC (GetOtherPlayerPlaybackPr) in error state, and initiating retry logic…
[17:30:56] [ZNet] RRPC backoff index: 2, backoff delay milliseconds: 2000
Erica
It’s a feature. You can turn it off in settings.
Hi Paul, thank you very much for your helpful reply, and the info. Before I posted, I searched the forum for info using the term” holographic replay”.
I see that the term to use now is “HoloReplay”
Erica
