When I pair my elite trainer (zumo) it often picks up the elite real trainer option as controllable not the FE-C option which is required. Even when the last trainer I paired was the FE-C version.
Unless I notice this has happened there is no gradient changes or erg mode and I have to go back into the pairing screen and change it after noticing once I start riding which is quite annoying.
Would be good if I could disable this somehow within zwift so it didn’t pick it up.
Zwift can obviously tell it is really controllable as you are unable to select erg mode in workouts if you have the wrong one selected.
