Folks,
I was able to ride 2 days ago. Apparently a patch was made in the meantime and now I can’t connect. I have paid for the month. Please fix ASAP.
Folks,
Hi there, sorry for the issue - but we have the same number of mac rides as always going on according to our data. Can you give us more details on your crash? When it crashes, is there a “Report” button? If so, can you click it and then copy/paste all the computery looking info into this thread? That’ll help us see what happened and try to sort out a fix.
Jon
Was able to finally get on after multiple attempts.
Jon,
I did report the issue to Apple. I will be sure to copy and paste in the thread in the future. thanks!
Heather
I have the same problem. My brand new Macbook I breaking down when I start a ride… Some times it brakes down when it just are parring! If I get the ride started, it breaks down maximum a couple of minutes after… Did you find a solution for this problem? My friend also had the same problem with his Mac, so he is using a PC now, but I don’t have a ekstra PC for riding your app…?!
Hope you can help?
Martin
Martin, when it crashes be sure to click the REPORT button that shows up on the mac. It will show you a bunch of stuff - copy and paste that here or in a ticket and it will tell us why you’re crashing.
A huge percentage of Zwift users use a mac every day with no problems so there may be something specific going on with your setup. The crash report is essential.
Hi Jon
First of all thanks for the response. Underneath I have copy and pasted The report as you asked for.
Just a ekstra bit of information. I have updated my Bkool.
I hoop that you can help me with this problem.
Martin
Process: ZwiftApp [665]
Path: /Users/USER/Library/Application Support/Zwift/ZwiftApp
Identifier: ZwiftApp
Version: 0
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: ZwiftApp [665]
User ID: 501
Date/Time: 2017-10-28 13:19:15.107 +0200
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: B9E71871-8B65-1235-D3C9-85D17F112732
Time Awake Since Boot: 460 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000006400eca
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0x6400eca:
__TEXT 00000001015be000-0000000101ed4000 [9304K] r-x/rwx SM=COW /Users/USER/Library/Application Support/Zwift/*
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.driver.AppleIntelSKLGraphicsGLDriver 0x000000010c062980 IntelVertexArray::buildBufData() + 284
1 com.apple.driver.AppleIntelSKLGraphicsGLDriver 0x000000010c06282f IntelVertexArray::extractBuffers(GLDVertexArrayRec*, unsigned long long, unsigned long long) + 451
2 com.apple.driver.AppleIntelSKLGraphicsGLDriver 0x000000010c06231b glrUpdateVertexArrayBuffers + 13
3 libGPUSupportMercury.dylib 0x00007fff8be06aae gpusLoadCurrentVertexArray + 724
4 com.apple.driver.AppleIntelSKLGraphicsGLDriver 0x000000010b756238 updateDispatch + 1224
5 com.apple.driver.AppleIntelSKLGraphicsGLDriver 0x000000010b755cc6 gldUpdateDispatch + 175
6 GLEngine 0x000000010b659dce gleDoDrawDispatchCore + 520
7 GLEngine 0x000000010b61b0f8 glDrawRangeElements_ACC_Exec + 302
8 libGL.dylib 0x00007fff82588980 glDrawRangeElements + 45
9 ZwiftApp 0x00000001015d68d5 HeightMapTile::Render(int) + 1349
10 ZwiftApp 0x00000001016faa96 HeightMapManager::Render(int) + 118
11 ZwiftApp 0x00000001017aa7d7 drawNewWorld(float, float, float, float, float) + 6407
12 ZwiftApp 0x00000001017b1596 Render(float) + 982
13 ZwiftApp 0x00000001017b2be4 doFrame() + 804
14 ZwiftApp 0x00000001017c4275 CODEmain(int, char const**) + 85
15 ZwiftApp 0x000000010178da73 main + 595
16 libdyld.dylib 0x00007fff938b8235 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff939e744e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff93ad148e _pthread_wqthread + 1023
2 libsystem_pthread.dylib 0x00007fff93ad107d start_wqthread + 13
Thread 2:
0 libsystem_kernel.dylib 0x00007fff939e6f46 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff9396db72 nanosleep + 199
2 ZwiftApp 0x0000000101b86b80 OS_Sleep(unsigned int) + 39
3 ZwiftApp 0x0000000101b6e018 JM_Worker_Thread(void*) + 280
4 libsystem_pthread.dylib 0x00007fff93ad193b _pthread_body + 180
5 libsystem_pthread.dylib 0x00007fff93ad1887 _pthread_start + 286
6 libsystem_pthread.dylib 0x00007fff93ad108d thread_start + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff939e6bf2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff93ad27fa _pthread_cond_wait + 712
2 libc++.1.dylib 0x00007fff9244f4cd std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3 ZwiftApp 0x00000001019b5498 ZwiftHttpConnectionManager::worker(int) + 150
4 ZwiftApp 0x00000001019ac063 void* std::__1::__thread_proxy<std::__1::tuple<HttpConnectionManager::initialize()::$_0> >(void*) + 69
5 libsystem_pthread.dylib 0x00007fff93ad193b _pthread_body + 180
6 libsystem_pthread.dylib 0x00007fff93ad1887 _pthread_start + 286
7 libsystem_pthread.dylib 0x00007fff93ad108d thread_start + 13
Thread 4:
Thread 5:
Thread 6:
2 ZwiftApp 0x0000000101c5943b AK::StreamMgr::CAkIOThread::IOSchedThread(void*) + 75
3 libsystem_pthread.dylib 0x00007fff93ad193b _pthread_body + 180
4 libsystem_pthread.dylib 0x00007fff93ad1887 _pthread_start + 286
5 libsystem_pthread.dylib 0x00007fff93ad108d thread_start + 13
Thread 7:
0 libsystem_kernel.dylib 0x00007fff939df386 semaphore_wait_trap + 10
1 ZwiftApp 0x0000000101c275f3 CAkThreadedBankMgr::BankThreadFunc(void*) + 51
2 libsystem_pthread.dylib 0x00007fff93ad193b _pthread_body + 180
3 libsystem_pthread.dylib 0x00007fff93ad1887 _pthread_start + 286
4 libsystem_pthread.dylib 0x00007fff93ad108d thread_start + 13
Thread 8:
1 ZwiftApp 0x0000000101c2d38f CAkAudioThread::EventMgrThreadFunc(void*) + 63
Thread 9:
1 ZwiftApp 0x0000000101be0b0b CAkOutputMgr::SuspendedThread(void*) + 59
Thread 10:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff939df34a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff939de797 mach_msg + 55
2 com.apple.audio.CoreAudio 0x00007fff7dc9a935 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 127
3 com.apple.audio.CoreAudio 0x00007fff7dc9a8a6 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fff7dc978d0 HALC_ProxyIOContext::IOWorkLoop() + 1196
5 com.apple.audio.CoreAudio 0x00007fff7dc97264 HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6 com.apple.audio.CoreAudio 0x00007fff7dc96fa3 HALB_IOThread::Entry(void*) + 75
7 libsystem_pthread.dylib 0x00007fff93ad193b _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fff93ad1887 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fff93ad108d thread_start + 13
Thread 11:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff7e131434 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff7e1308c1 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fff7e130114 CFRunLoopRunSpecific + 420
5 com.apple.AppKit 0x00007fff7bd76f02 _NSEventThread + 205
6 libsystem_pthread.dylib 0x00007fff93ad193b _pthread_body + 180
7 libsystem_pthread.dylib 0x00007fff93ad1887 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007fff93ad108d thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000010 rbx: 0x0000000000000036 rcx: 0x0000000000000000 rdx: 0x000000000000000c
rdi: 0x00007f9dc4870650 rsi: 0x0000000000000000 rbp: 0x00007fff5e640160 rsp: 0x00007fff5e640120
r8: 0x0000000000000050 r9: 0x00007f9dc48708e8 r10: 0x00007f9dc48708ec r11: 0x0000000000000000
r12: 0x0000000000040000 r13: 0x0000000000000000 r14: 0x00007f9dc4870650 r15: 0x0000000000000fff
rip: 0x000000010c062980 rfl: 0x0000000000010246 cr2: 0x0000000006400eca
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x1015be000 - 0x101ed3ff7 +ZwiftApp (0) <4FD3E76B-4164-366F-8A97-0A20F7CAB236> /Users/USER/Library/Application Support/Zwift/ZwiftApp
0x1026b7000 - 0x102713ff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <DD6F8D1F-69EE-335A-8654-72B24E25423D> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x102759000 - 0x102776fff +libant.dylib (0) <69DB8DF7-7E3F-33EE-9472-45DD36CFD413> /Users/USER/Library/Application Support/Zwift/libant.dylib
0x10279c000 - 0x1027dbffb com.apple.glut (3.6.9 - GLUT-3.6.9) <43620BB5-4583-33D0-9ABB-B401B2636E17> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x102851000 - 0x10288fff7 com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x1028ba000 - 0x1029e6ff7 com.apple.AudioVideoBridging (503.2 - 503.2) <90DFEC17-1857-3C9E-BDFC-41AFE115296A> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x102aa0000 - 0x102ab9ffb libexpat.1.dylib (15) <F48F1B7B-BEB4-32EE-8C5D-0370096F3864> /usr/lib/libexpat.1.dylib
0x102ac4000 - 0x102ad8ff3 com.apple.AudioServerApplication (1.0 - 200.9) <4977039B-FC27-3D6E-9B3E-81B3071ADBB3> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
0x102aee000 - 0x102afdfff com.apple.TimeSync (1.0 - 500.27) <8C1B7D3F-2229-3494-924D-89D700C15E70> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x102ed7000 - 0x102edbfff com.apple.audio.AppleHDAHALPlugIn (279.48 - 279.48) <ECA84145-2AC4-347D-BBC0-933AAAC15356> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x108285000 - 0x1083ecfff com.apple.audio.units.Components (1.14 - 1.14) <C79BB0B7-9231-316F-A48D-BA93A68EA7ED> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x10a2f5000 - 0x10a31ffff GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x10a4c6000 - 0x10a503dc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
0x10b54d000 - 0x10b6f3fff GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x10b732000 - 0x10c187ff7 com.apple.driver.AppleIntelSKLGraphicsGLDriver (10.25.17 - 10.2.5) <A69899DE-EAA2-3FB2-BDCD-115225CDC0BD> /System/Library/Extensions/AppleIntelSKLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsGLDriver
0x13a4f7000 - 0x13a585ff7 com.apple.driver.AppleIntelSKLGraphicsMTLDriver (10.25.17 - 10.2.5) <8BEC3806-DEDE-3024-8133-5DB942ACE15C> /System/Library/Extensions/AppleIntelSKLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsMTLDriver
0x7fff78d5a000 - 0x7fff7909fff7 com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff7a8d6000 - 0x7fff7aa97fff com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff7aa98000 - 0x7fff7ab3aff7 com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff7ac05000 - 0x7fff7ac05fff com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff7ac06000 - 0x7fff7ac1dffb libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff7ac1e000 - 0x7fff7b137feb com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff7b138000 - 0x7fff7b2a9ff3 libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff7b2aa000 - 0x7fff7b2beffb libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff7b2bf000 - 0x7fff7b6b5fef libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff7b6b6000 - 0x7fff7b6ccfff libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff7b6cd000 - 0x7fff7b6d3fff libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff7b6d4000 - 0x7fff7b6e8ff7 libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff7b6e9000 - 0x7fff7b870fe7 libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff7b871000 - 0x7fff7b923fff libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff7b924000 - 0x7fff7b924fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff7bbe3000 - 0x7fff7c9bcff3 com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff7c9ce000 - 0x7fff7c9cefff com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff7c9cf000 - 0x7fff7ca3dff7 com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff7cad7000 - 0x7fff7cc06ff7 libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff7cc07000 - 0x7fff7cc51fff libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff7ccae000 - 0x7fff7cce1fff libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff7cd4e000 - 0x7fff7cdf8ff7 com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff7cdf9000 - 0x7fff7ce4afff com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff7ce4b000 - 0x7fff7ce5aff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff7ce5b000 - 0x7fff7cea8fff com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff7cea9000 - 0x7fff7cee4fff com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff7cee5000 - 0x7fff7cef0fff com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff7cef1000 - 0x7fff7d0fdff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff7d0fe000 - 0x7fff7d0fefff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff7d267000 - 0x7fff7d641fff com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff7d65b000 - 0x7fff7d65bfff com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff7d65c000 - 0x7fff7d65ffff com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff7d660000 - 0x7fff7d969fff com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff7d96a000 - 0x7fff7d96dff7 com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff7d96e000 - 0x7fff7d973fff com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff7d974000 - 0x7fff7da0bff3 com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff7da0c000 - 0x7fff7da26fff com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff7da27000 - 0x7fff7da28ff3 com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff7da29000 - 0x7fff7da2bff7 com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff7da2c000 - 0x7fff7da32ff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff7db13000 - 0x7fff7db13fff com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff7dc5d000 - 0x7fff7dceafff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff7dceb000 - 0x7fff7dcfefff com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff7dcff000 - 0x7fff7dffafff com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff7dffb000 - 0x7fff7e0a8ff7 com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff7e0a9000 - 0x7fff7e542ff7 com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff7e543000 - 0x7fff7ebc5fff com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff7ebc6000 - 0x7fff7ee09ffb com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff7ee70000 - 0x7fff7ef21fff com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff7ef22000 - 0x7fff7ef6dff7 com.apple.CoreMediaIO (805.0 - 4932) <03F2B863-BF99-36DF-9A14-1DB534A289F3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff7ef6e000 - 0x7fff7ef6efff com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff7ef6f000 - 0x7fff7efc0fff com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff7efc1000 - 0x7fff7f29cff7 com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff7f29d000 - 0x7fff7f2d0fff com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff7f2d1000 - 0x7fff7f2d9ff3 com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff7f2da000 - 0x7fff7f446ff7 com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff7f447000 - 0x7fff7f4f7ffb com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff7f4f8000 - 0x7fff7f557fff com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff7f558000 - 0x7fff7f5c8fff com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff7f5c9000 - 0x7fff7f60eff7 com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff7f697000 - 0x7fff7f7e4ffb com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff7f7e5000 - 0x7fff7f81aff3 com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff7f81b000 - 0x7fff7f88cffb com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff7f8cb000 - 0x7fff7f989ff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <9397E609-CB54-37B2-B28E-D4BC6C34BFAB> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff7f98a000 - 0x7fff7f98ffff com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff7fb21000 - 0x7fff7fec7fff com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff7fef3000 - 0x7fff7ff24ff7 com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff7ffe4000 - 0x7fff80087fff com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff80088000 - 0x7fff8011eff7 com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8011f000 - 0x7fff80125ffb com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff80178000 - 0x7fff802d8fef com.apple.ImageIO.framework (3.3.0 - 1599.12) <E54ADBF0-6001-3DEB-AEB0-3F857A781E06> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff802d9000 - 0x7fff802ddfff libGIF.dylib (1599.12) <A0836C44-9566-32A3-ACCF-82A5BAF2E521> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff802de000 - 0x7fff803ceff7 libJP2.dylib (1599.12) <0DB4F152-B36D-365C-97B1-34F1C114982B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff803cf000 - 0x7fff803f2ffb libJPEG.dylib (1599.12) <2F66BA16-D569-35AD-A4BB-7A1909F1BF11> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff803f3000 - 0x7fff8041aff7 libPng.dylib (1599.12) <A068239E-7DB3-33AD-BEA9-499D8DEF771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8041b000 - 0x7fff8041dff3 libRadiance.dylib (1599.12) <D26D6FC9-1175-38AB-ACAA-0CA073FD3978> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8041e000 - 0x7fff8046cffb libTIFF.dylib (1599.12) <5D161E6A-D279-37A0-9F5F-A71A4C13BB09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff811d5000 - 0x7fff811eeff7 com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff811ef000 - 0x7fff81225fff com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff81478000 - 0x7fff8147efff com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff81494000 - 0x7fff819cdff7 com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff819ce000 - 0x7fff81a29fff com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff82312000 - 0x7fff8231afff com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff824cb000 - 0x7fff824f0fff com.apple.audio.OpenAL (1.8 - 1.8) <E3447078-6A7E-3A6D-B136-B6EA93982EE1> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff824f1000 - 0x7fff824f9ff7 libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff824fa000 - 0x7fff82548ff3 com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff82549000 - 0x7fff82562ffb com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff82563000 - 0x7fff8256eff7 com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff8256f000 - 0x7fff82571fff libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff82572000 - 0x7fff82575ff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff82576000 - 0x7fff8257afff libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8257b000 - 0x7fff82584ff7 libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff82585000 - 0x7fff82590fff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff82591000 - 0x7fff825cdff7 libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff825ce000 - 0x7fff82744ff3 libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff82745000 - 0x7fff82786ff7 libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff830ee000 - 0x7fff830fcfff com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff83c4e000 - 0x7fff83e4efff com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff8439e000 - 0x7fff843b5ff7 com.apple.ScriptingBridge (1.3.3 - 69) <F51B85CD-9C80-317E-B594-4A03612EAF52> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff843b6000 - 0x7fff846b8ff7 com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff846b9000 - 0x7fff8472efff com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff84759000 - 0x7fff8475cff3 com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff84ae3000 - 0x7fff84b52ff7 com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff84b53000 - 0x7fff84f01fff com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff86c2e000 - 0x7fff86c35ffb com.apple.APFS (1.0 - 1) <A0614DF8-56CE-3DA3-922E-769B9F975A37> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff873a9000 - 0x7fff873c4ff3 com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff873c5000 - 0x7fff873d2ff3 com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff873d3000 - 0x7fff873f5ffb com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff873f6000 - 0x7fff87405feb com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff874f2000 - 0x7fff8757d97f com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff875ad000 - 0x7fff875b5ffb com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff875ba000 - 0x7fff8760cfff com.apple.AppleVAFramework (5.0.36 - 5.0.36) <7352078D-C230-397C-81A5-57A48CF218C0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff879b0000 - 0x7fff87a2eff7 com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff87a57000 - 0x7fff87a94ffb com.apple.bom (14.0 - 194.1) <0CBECAF1-B5E0-302F-99EC-D7ED14E12B84> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff886b9000 - 0x7fff886e0ff3 com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff89005000 - 0x7fff8900effb com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff89193000 - 0x7fff89572ff7 com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff89573000 - 0x7fff895a3fff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff8963e000 - 0x7fff89646ffb com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff89757000 - 0x7fff89767fff com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff89aa2000 - 0x7fff89ad2ff3 com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff89d63000 - 0x7fff89df2ff7 com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff89df3000 - 0x7fff89f32fe7 com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff89f33000 - 0x7fff8a003ff3 com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff8a053000 - 0x7fff8a0b8ff3 com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff8a0b9000 - 0x7fff8a0c7ff7 com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8a139000 - 0x7fff8a143ffb com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff8a144000 - 0x7fff8a148ff3 com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff8a17e000 - 0x7fff8a1f3ffb com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8a22f000 - 0x7fff8a26efff com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8a26f000 - 0x7fff8a380fff com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff8a385000 - 0x7fff8a45afff com.apple.DiskImagesFramework (444.50.16 - 444.50.16) <85BC24F9-3DF7-3AFC-B953-DE2CC94D61E9> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff8a513000 - 0x7fff8a515ffb com.apple.EFILogin (2.0 - 2) <A74B0065-643F-3BC1-8FE9-E7CEAA29AD9A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8a668000 - 0x7fff8aa99ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff8bdf0000 - 0x7fff8bdf0fff libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff8bdfd000 - 0x7fff8be08ff3 libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff8c0c1000 - 0x7fff8c0ddfff com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8c7ee000 - 0x7fff8c864ff3 com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff8ce7f000 - 0x7fff8ce86ffb com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff8ce88000 - 0x7fff8ce9cff7 com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff8ce9d000 - 0x7fff8cebffff com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8cf5b000 - 0x7fff8cf6bff3 com.apple.IntlPreferences (2.0 - 216) <77C9C2E7-EF9F-34BB-A5E3-B8BEA4226B5F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff8cfa6000 - 0x7fff8d15dfff com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff8d7cd000 - 0x7fff8d7d0fff com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff8d8a9000 - 0x7fff8d8ddff3 com.apple.MediaKit (16 - 845) <883DC63F-F90F-3FB9-8C23-9CECD72EBCDE> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8da7e000 - 0x7fff8daf7ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff8db09000 - 0x7fff8dc5aff7 com.apple.mobiledevice (988.1.4.100.1 - 988.1.4.100.1) <0CDE2600-0EC3-3060-AB58-6A7617AF0B9B> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x7fff8dc7a000 - 0x7fff8dca2ff7 com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8dd54000 - 0x7fff8dd5ffff com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8e637000 - 0x7fff8e678ff3 com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff8ed25000 - 0x7fff8ed5fffb com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff8ed60000 - 0x7fff8ed7afff com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff8ed93000 - 0x7fff8edb6ff3 com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff8fa80000 - 0x7fff8fa83fff com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff8fb12000 - 0x7fff8fb9ffff com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff8fbc0000 - 0x7fff8fe26feb com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff90005000 - 0x7fff90011ff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff906fd000 - 0x7fff90771fdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff90bb0000 - 0x7fff90bb6ff7 com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff90c42000 - 0x7fff90d08ff7 com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff90d7c000 - 0x7fff90d7dfff com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff90d7e000 - 0x7fff90f0eff3 com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff919dd000 - 0x7fff91a9dfff com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff91ee8000 - 0x7fff91eeefff com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff91fbf000 - 0x7fff91fc1ffb com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff92016000 - 0x7fff92031ff7 libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
0x7fff92032000 - 0x7fff9203dfff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
0x7fff9203e000 - 0x7fff920ceff7 libCoreStorage.dylib (540.30.1) <85C0A366-F901-36E3-854A-FE8A14A04A72> /usr/lib/libCoreStorage.dylib
0x7fff920cf000 - 0x7fff920d0ff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff920d1000 - 0x7fff922e4fff libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
0x7fff92300000 - 0x7fff92307fff libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
0x7fff92308000 - 0x7fff92308fff libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
0x7fff92309000 - 0x7fff9230dffb libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
0x7fff9230e000 - 0x7fff9230fffb libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
0x7fff9237b000 - 0x7fff923a6ff3 libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
0x7fff923a7000 - 0x7fff92423fc7 libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
0x7fff92427000 - 0x7fff92427ff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
0x7fff92428000 - 0x7fff92438ff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fff92439000 - 0x7fff92447ff7 libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
0x7fff92448000 - 0x7fff9249eff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
0x7fff9249f000 - 0x7fff924c8ff7 libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
0x7fff924c9000 - 0x7fff924d9ffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fff924da000 - 0x7fff924f0fcf libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
0x7fff924f1000 - 0x7fff924f1ff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
0x7fff924f2000 - 0x7fff924f3ff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff925ad000 - 0x7fff92692ff7 libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
0x7fff92824000 - 0x7fff9282ffff libcsfde.dylib (540.30.1) <0C2B183B-16D9-3D5F-962D-0A09C7063211> /usr/lib/libcsfde.dylib
0x7fff92830000 - 0x7fff92883ff7 libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
0x7fff92884000 - 0x7fff928d6fff libcurl.4.dylib (95.70.1) <8987EFA8-0BF6-3E2A-8F04-7BD5803B9A37> /usr/lib/libcurl.4.dylib
0x7fff928d7000 - 0x7fff928deff3 libdscsym.dylib (148.3) <EF99B991-18D9-3A73-BE88-4DC55F036DEF> /usr/lib/libdscsym.dylib
0x7fff92900000 - 0x7fff92900fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fff9290e000 - 0x7fff9290ffff libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
0x7fff92910000 - 0x7fff92915ff7 libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
0x7fff92916000 - 0x7fff92a08ff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fff92a09000 - 0x7fff92c2effb libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
0x7fff92c34000 - 0x7fff92c35fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
0x7fff92c36000 - 0x7fff92c4fffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fff92c50000 - 0x7fff92c66ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
0x7fff92c67000 - 0x7fff92f0fff7 libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
0x7fff92f42000 - 0x7fff92fbcff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
0x7fff92fbd000 - 0x7fff9338f047 libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
0x7fff93392000 - 0x7fff93396fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
0x7fff93397000 - 0x7fff933c8fff libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
0x7fff933e5000 - 0x7fff93401ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fff93402000 - 0x7fff9343bfff libsandbox.1.dylib (592.70.1) <9C428C49-9D9A-3F9F-9573-BF5202D1F933> /usr/lib/libsandbox.1.dylib
0x7fff9343c000 - 0x7fff9344effb libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
0x7fff9344f000 - 0x7fff93450ff3 libspindump.dylib (231.3) <C7CEEB64-06F4-3ACA-AAC1-30ECA909501A> /usr/lib/libspindump.dylib
0x7fff93451000 - 0x7fff9359fff7 libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
0x7fff935c2000 - 0x7fff935faff3 libssl.0.9.8.dylib (64.50.6) <9A9C9D9A-7948-3412-ABE4-01FCC4A72CD2> /usr/lib/libssl.0.9.8.dylib
0x7fff935fb000 - 0x7fff9364bfff libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
0x7fff93690000 - 0x7fff93693ff7 libutil.dylib (47.30.1) <88CC63B3-0EDF-306E-9AB5-D87EBE0F3F16> /usr/lib/libutil.dylib
0x7fff93694000 - 0x7fff936a1fff libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
0x7fff936a2000 - 0x7fff93791fff libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
0x7fff93792000 - 0x7fff937bbfff libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
0x7fff937bc000 - 0x7fff937cdff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fff937dc000 - 0x7fff937e0ff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
0x7fff937e1000 - 0x7fff937ebfff libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
0x7fff937ec000 - 0x7fff937f3fff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
0x7fff937f4000 - 0x7fff937fcfff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
0x7fff937fd000 - 0x7fff93880fdf libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
0x7fff93881000 - 0x7fff938b2fff libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
0x7fff938b3000 - 0x7fff938b8ffb libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
0x7fff938b9000 - 0x7fff938b9ffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
0x7fff938ba000 - 0x7fff938c6fff libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
0x7fff938c7000 - 0x7fff938c7fff liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
0x7fff938c8000 - 0x7fff938cdff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
0x7fff938ce000 - 0x7fff938d0ff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
0x7fff938d1000 - 0x7fff938d2ffb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
0x7fff938d3000 - 0x7fff938ebff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
0x7fff938ec000 - 0x7fff938ecff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
0x7fff938ed000 - 0x7fff9397afef libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
0x7fff9397b000 - 0x7fff9397effb libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
0x7fff9397f000 - 0x7fff93982fff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
0x7fff93983000 - 0x7fff9399bfff libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
0x7fff9399c000 - 0x7fff939a2fff libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
0x7fff939a3000 - 0x7fff939ccff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
0x7fff939cd000 - 0x7fff939efff7 libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
0x7fff939f0000 - 0x7fff93a37fe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
0x7fff93a38000 - 0x7fff93a56ff7 libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
0x7fff93a57000 - 0x7fff93ab0ffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
0x7fff93ab1000 - 0x7fff93abaff3 libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
0x7fff93abb000 - 0x7fff93ac4ff3 libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
0x7fff93ac5000 - 0x7fff93acdfe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
0x7fff93ace000 - 0x7fff93ad8ff7 libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
0x7fff93ad9000 - 0x7fff93adcff7 libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
0x7fff93add000 - 0x7fff93adeff3 libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
0x7fff93adf000 - 0x7fff93ae6ffb libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
0x7fff93ae7000 - 0x7fff93afaff7 libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
0x7fff93afb000 - 0x7fff93b00ffb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
0x7fff93b01000 - 0x7fff93b2aff7 libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 435
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=302.1M resident=0K(0%) swapped_out_or_unallocated=302.1M(100%)
Writable regions: Total=1.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.1G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 512K 4
Activity Tracing 256K 2
CG backing stores 35.1M 4
CG image 1476K 11
CoreAnimation 64K 6
CoreUI image data 1388K 11
CoreUI image file 292K 5
Foundation 4K 2
IOKit 7972K 3
Image IO 1036K 3
Kernel Alloc Once 8K 2
MALLOC 592.8M 103
MALLOC guard page 48K 10
MALLOC_LARGE (reserved) 340K 2 reserved VM address space (unallocated)
Memory Tag 242 12K 2
OpenGL GLSL 256K 4
STACK GUARD 56.0M 12
Stack 11.8M 13
Stack Guard 4K 2
VM_ALLOCATE 431.2M 337
VM_ALLOCATE (reserved) 36K 2 reserved VM address space (unallocated)
__DATA 27.6M 269
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 123.3M 18
__TEXT 178.7M 267
__UNICODE 556K 2
mapped file 46.6M 13
shared memory 16.4M 16
TOTAL 1.5G 1100
TOTAL, minus reserved VM space 1.5G 1100
Model: MacBookPro13,2, BootROM MBP132.0226.B25, 2 processors, Intel Core i5, 2,9 GHz, 16 GB, SMC 2.37f20
Graphics: Intel Iris Graphics 550, Intel Iris Graphics 550, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x157), Broadcom BCM43xx 1.0 (7.21.171.130.1a1)
Bluetooth: Version 5.0.5f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: USB2.0 Hub
USB Device: USB-C Digital AV Multiport Adapter
USB Device: iBridge
USB Device: USB3.0 Hub
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
