Zwift crashing mid session on Mac
Hi, on several occasions the screen freezes mid session.  I continue to pedal to see if it refreshes but it doesn’t.  Eventually I have to stop and log out then back in again.  I have the following error report…
Process:               ZwiftApp [966]
Path:                 /Users/USER/Library/Application Support/Zwift/ZwiftApp
Identifier:           ZwiftApp
Version:               ???
Code Type:             X86-64 (Native)
Parent Process:       ??? [1]
Responsible:           ZwiftApp [966]
User ID:               501
Date/Time:             2017-02-23 18:44:40.563 +0000
OS Version:           Mac OS X 10.12.3 (16D32)
Report Version:       12
Anonymous UUID:       3032AF55-0F12-7C24-F9AA-83FB970C1E60
Time Awake Since Boot: 2900 seconds
System Integrity Protection: enabled
Crashed Thread:       0 Dispatch queue: com.apple.main-thread
Exception Type:       EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000058
Exception Note:       EXC_CORPSE_NOTIFY
Termination Signal:   Segmentation fault: 11
Termination Reason:   Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [0]
VM Regions Near 0x58:
   __TEXT                 000000010d1f3000-000000010da12000 [8316K] r-x/rwx SM=COW /Users/USER/Library/Application Support/Zwift/*
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.apple.GeForceGLDriver        0x00007fffa45081cf 0x7fffa41ea000 + 3269071
1   com.apple.GeForceGLDriver        0x00007fffa4407fea gldGetQueryInfo + 38
2   GLEngine                         0x00007fffade2471d glGetQueryObject_Core + 340
3   GLEngine                         0x00007fffade247dd glGetQueryObjectuiv_Exec + 37
4   ZwiftApp                          0x000000010d3c9e04 Sky::Render_PostFX(VEC3, float, bool) + 196
5   ZwiftApp                          0x000000010d36e9e6 drawNewWorld(float, float, float, float, float) + 16982
6   ZwiftApp                          0x000000010d372626 Render(float) + 982
7   ZwiftApp                          0x000000010d373c44 doFrame() + 804
8   ZwiftApp                          0x000000010d382f95 CODEmain(int, char const**) + 85
9   ZwiftApp                          0x000000010d3529a3 main + 595
10 ZwiftApp                         0x000000010d1f53f4 start + 52
Thread 1:
0   libsystem_kernel.dylib                0x00007fffbe4c2fda __semwait_signal + 10
1   libsystem_c.dylib             0x00007fffbe449b72 nanosleep + 199
2   ZwiftApp                          0x000000010d709013 JM_Worker_Thread(void*) + 307
3   libsystem_pthread.dylib              0x00007fffbe5abaab _pthread_body + 180
4   libsystem_pthread.dylib              0x00007fffbe5ab9f7 _pthread_start + 286
5   libsystem_pthread.dylib              0x00007fffbe5ab1fd thread_start + 13
Thread 2:
0   libsystem_kernel.dylib                0x00007fffbe4c2c86 __psynch_cvwait + 10
1   libsystem_pthread.dylib              0x00007fffbe5ac96a _pthread_cond_wait + 712
2   ZwiftApp                          0x000000010d7db4fb AK::StreamMgr::CAkIOThread::IOSchedThread(void*) + 75
Thread 3:
0   libsystem_kernel.dylib                0x00007fffbe4bb3c6 semaphore_wait_trap + 10
1   ZwiftApp                          0x000000010d7ad793 CAkThreadedBankMgr::BankThreadFunc(void*) + 51
2   libsystem_pthread.dylib              0x00007fffbe5abaab _pthread_body + 180
3  libsystem_pthread.dylib              0x00007fffbe5ab9f7 _pthread_start + 286
4   libsystem_pthread.dylib              0x00007fffbe5ab1fd thread_start + 13
Thread 4:
1   ZwiftApp                           0x000000010d7b316f CAkAudioThread::EventMgrThreadFunc(void*) + 63
Thread 5:
1   ZwiftApp                          0x000000010d76c33b CAkOutputMgr::SuspendedThread(void*) + 59
Thread 6:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib                0x00007fffbe4bb38a mach_msg_trap + 10
1   libsystem_kernel.dylib                0x00007fffbe4ba7d7 mach_msg + 55
2   com.apple.audio.CoreAudio        0x00007fffa8920f26 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 122
3   com.apple.audio.CoreAudio        0x00007fffa8920e9c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4   com.apple.audio.CoreAudio        0x00007fffa891dcee HALC_ProxyIOContext::IOWorkLoop() + 1198
5   com.apple.audio.CoreAudio        0x00007fffa891d667 HALC_ProxyIOContext::IOThreadEntry(void*) + 131
6   com.apple.audio.CoreAudio        0x00007fffa891d38b HALB_IOThread::Entry(void*) + 75
7   libsystem_pthread.dylib              0x00007fffbe5abaab _pthread_body + 180
8   libsystem_pthread.dylib              0x00007fffbe5ab9f7 _pthread_start + 286
9   libsystem_pthread.dylib              0x00007fffbe5ab1fd thread_start + 13
Thread 7:: com.apple.NSEventThread
2   com.apple.CoreFoundation        0x00007fffa8d98e84 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation        0x00007fffa8d98301 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation        0x00007fffa8d97b54 CFRunLoopRunSpecific + 420
5   com.apple.AppKit                        0x00007fffa6a15a62 _NSEventThread + 205
6   libsystem_pthread.dylib              0x00007fffbe5abaab _pthread_body + 180
7   libsystem_pthread.dylib              0x00007fffbe5ab9f7 _pthread_start + 286
8   libsystem_pthread.dylib              0x00007fffbe5ab1fd thread_start + 13
Thread 8:
5   com.apple.CoreFoundation        0x00007fffa8dd7631 CFRunLoopRun + 97
6   libant.dylib                      0x000000010e148641 IOKitDeviceHandle::EventThread() + 265
7   libant.dylib                      0x000000010e1477b3 IOKitDeviceHandle::EventThreadStart(void*) + 9
8   libsystem_pthread.dylib              0x00007fffbe5abaab _pthread_body + 180
9   libsystem_pthread.dylib              0x00007fffbe5ab9f7 _pthread_start + 286
10 libsystem_pthread.dylib            0x00007fffbe5ab1fd thread_start + 13
Thread 9:
0   libsystem_kernel.dylib                0x00007fffbe4c4232 poll + 10
1   libant.dylib                      0x000000010e1453c4 IOKitTransfer::Receive() + 126
2   libant.dylib                     0x000000010e14845e IOKitDeviceHandle::SendSyncBulkTransfer(unsigned char, unsigned char*, int, unsigned int, int&) + 182
3   libant.dylib                      0x000000010e149080 USBDeviceHandleIOKit::ReceiveThread() + 178
4   libant.dylib                     0x000000010e148ed7 USBDeviceHandleIOKit::ProcessThread(void*) + 9
5   libsystem_pthread.dylib              0x00007fffbe5abaab _pthread_body + 180
6   libsystem_pthread.dylib              0x00007fffbe5ab9f7 _pthread_start + 286
7   libsystem_pthread.dylib             0x00007fffbe5ab1fd thread_start + 13
Thread 10:
2   libant.dylib                      0x000000010e14d955 DSIThread_CondTimedWait + 136
3   libant.dylib                      0x000000010e14b122 TSQueue<char, std::deque<char, std::allocator<char> > >::PopArray(char*, unsigned int, unsigned int) + 74
4   libant.dylib                      0x000000010e148fb9 USBDeviceHandleIOKit::Read(void*, unsigned int, unsigned int&, unsigned int) + 35
5   libant.dylib                      0x000000010e14d656 DSISerialGeneric::ReceiveThread() + 96
6   libant.dylib                      0x000000010e14d4e1 DSISerialGeneric::ProcessThread(void*) + 9
Thread 11:
3   libant.dylib                      0x000000010e14f2c1 DSIFramerANT::WaitForMessage(unsigned int) + 87
4   libant.dylib                      0x000000010e143077 MessageThread(void*) + 632
Thread 12:
0   libsystem_kernel.dylib                0x00007fffbe4c34e2 __workq_kernreturn + 10
1   libsystem_pthread.dylib              0x00007fffbe5ab791 _pthread_wqthread + 1426
2   libsystem_pthread.dylib              0x00007fffbe5ab1ed start_wqthread + 13
Thread 13:
0   libsystem_kernel.dylib                0x00007fffbe4c3e2a kevent + 10
1   ZwiftApp                          0x000000010d5a4061 asio::detail::kqueue_reactor::run(bool, asio::detail::op_queue<asio::detail::task_io_service_operation>&) + 265
2   ZwiftApp                          0x000000010d5a3d95 asio::detail::task_io_service::do_run_one(asio::detail::scoped_lock<asio::detail::posix_mutex>&, asio::detail::task_io_service_thread_info&, std::__1::error_code const&) + 267
3   ZwiftApp                          0x000000010d5a3a7e asio::detail::task_io_service::run(std::__1::error_code&) + 416
4   ZwiftApp                          0x000000010d510247 asio::io_service::run() + 43
5   ZwiftApp                          0x000000010d5a855c asio_detail_posix_thread_function + 19
Thread 14:
Thread 15:
3   libant.dylib                      0x000000010e14cd0c DSITimer::TimerThread() + 94
4   libant.dylib                      0x000000010e14cbcd DSITimer::TimerThreadStart(void*) + 9
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000000007d81a rbx: 0x0000000000000030 rcx: 0x00007fff52a0a7e0 rdx: 0x0000000000008866
rdi: 0x0000000116128000 rsi: 0x00007fffc71dc3c0 rbp: 0x00007fff52a0a7b0 rsp: 0x00007fff52a0a780
   r8: 0x00007fffa4508315   r9: 0x00007fffa45085f4 r10: 0x00000000000000f9 r11: 0x00000000000000f9
r12: 0x0000000116128000 r13: 0x0000000000008866 r14: 0x00007fda388724a0 r15: 0x0000000110c50000
rip: 0x00007fffa45081cf rfl: 0x0000000000010206 cr2: 0x0000000000000058
Logical CPU:     0
Error Code:     0x00000004
Trap Number:     14
Binary Images:
       0x10d1f3000 -       0x10da11fef +ZwiftApp (???) <27789409-B461-3FD1-B047-B883720C3D89> /Users/USER/Library/Application Support/Zwift/ZwiftApp
       0x10e09a000 -       0x10e0f6ff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <5440B95E-0391-32BA-8C2B-6568553F72E7> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
       0x10e142000 -       0x10e15ffff +libant.dylib (0) <69DB8DF7-7E3F-33EE-9472-45DD36CFD413> /Users/USER/Library/Application Support/Zwift/libant.dylib
       0x10e18c000 -       0x10e1cbffb com.apple.glut (3.6.8 - GLUT-3.6.8) <B773A6AC-B274-3E39-A81B-342060F72B54> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
       0x10e240000 -      0x10e27eff7 com.apple.audio.midi.CoreMIDI (1.10 - 88) <05B584BA-1FEA-3D34-8ABB-7C8C37952CB0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x10e2a6000 -       0x10e3d2ff7 com.apple.AudioVideoBridging (500.19 - 500.19) <107C2945-A1C6-3DF2-9914-C41909C99EE1> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
       0x10e488000 -       0x10e4a1ffb libexpat.1.dylib (15) <617B8B7A-A0AB-37D6-AFCA-F90F7F14E455> /usr/lib/libexpat.1.dylib
      0x10e4ae000 -       0x10e4c2ff3 com.apple.AudioServerApplication (1.0 - 200.9) <F3A5C381-B7D2-3BE1-AB30-3426922C3938> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
       0x10e4d2000 -       0x10e4e1fff com.apple.TimeSync (1.0 - 500.27) <962394AB-8359-31B4-8671-AAF2C535A8E8> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
       0x10e5f1000 -       0x10e5f5fff com.apple.audio.AppleHDAHALPlugIn (278.56 - 278.56) <CDA14261-23B7-30CD-B27B-1459F5C70F9D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x1142cf000 -       0x114439fff com.apple.audio.units.Components (1.14 - 1.14) <12D3C1ED-30A2-3270-B1B7-E5E64E245959> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
       0x116280000 -       0x1162bd267 dyld (421.2) <947FC440-80F9-32F7-A773-6FC418FE1AB7> /usr/lib/dyld
       0x128ec3000 -       0x128ecbff7 com.apple.iokit.IOUSBLib (900.4.1 - 900.4.1) <910CA10A-FAED-32D2-B900-BA7B84E82C41> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
   0x7fffa38ad000 -     0x7fffa3be6fff com.apple.RawCamera.bundle (7.01 - 889) <155ED09B-673E-3726-8302-E54AADAC5B63> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
   0x7fffa3d14000 -     0x7fffa41e9fff com.apple.GeForceAIRPlugin (10.14.20 - 10.1.4) <06838AF2-9837-38D3-AE45-8AD61DB52B4C> /System/Library/Extensions/GeForceAIRPlugin.bundle/Contents/MacOS/GeForceAIRPlugin
   0x7fffa41ea000 -     0x7fffa4a36fff com.apple.GeForceGLDriver (10.14.20 - 10.1.4) <E96D52FC-436A-304B-9C89-81DF0923A16D> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
   0x7fffa4a37000 -     0x7fffa5305ff3 libclh.dylib (4.0.3 - 4.0.3) <17D1CEB7-CFC3-356B-92B3-CE3E4E9A4618> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
   0x7fffa5306000 -     0x7fffa5416ff7 com.apple.GeForceMTLDriver (10.14.20 - 10.1.4) <F2438C2D-0DF4-35D6-BD4D-5A8551038779> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
   0x7fffa5417000 -     0x7fffa55d6ffb com.apple.avfoundation (2.0 - 1187.11.13) <0D0BB4A4-F987-381B-885E-88A81F50FD50> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
   0x7fffa55d7000 -     0x7fffa567afff com.apple.audio.AVFAudio (1.0 - ???) <E3CDC215-9272-3F94-8093-865CA181F728> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
   0x7fffa5743000 -     0x7fffa5743fff com.apple.Accelerate (1.11 - Accelerate 1.11) <BDDB2053-BB24-34E4-A452-50D1260BF672> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
   0x7fffa5744000 -     0x7fffa575bff3 libCGInterfaces.dylib (331.5) <4E2DCEFA-F243-3FAE-8BFC-0B349973DD14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
   0x7fffa575c000 -     0x7fffa5d9cfe3 com.apple.vImage (8.1 - ???) <77F96C96-725E-31E5-8072-D09C6BD988A2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
   0x7fffa5d9d000 -     0x7fffa5f64fef libBLAS.dylib (1185) <0D55CF73-6DBD-3D15-B500-189479638551> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
   0x7fffa5f65000 -     0x7fffa5f7cfff libBNNS.dylib (14) <43A9B06E-3C21-3CE6-B0C1-99DA172DEEB0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
   0x7fffa5f7d000 -     0x7fffa6388fff libLAPACK.dylib (1185) <E7AE9C48-6E42-3EB7-A257-D48E0CB48D00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
   0x7fffa6389000 -     0x7fffa639ffff libLinearAlgebra.dylib (1185) <08F00EFB-B477-3421-906E-3D364E607E6A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
   0x7fffa63a0000 -     0x7fffa63a6fff libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
   0x7fffa63a7000 -     0x7fffa63baff7 libSparseBLAS.dylib (1185) <912E3D25-27C0-3245-B64C-3CAD43A5D633> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
   0x7fffa63bb000 -     0x7fffa6508ff7 libvDSP.dylib (600) <87EF1D0A-1F85-31DD-AD8F-AB31E7D8E73B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
   0x7fffa6509000 -     0x7fffa65c0fff libvMisc.dylib (600) <F6EA539E-0A90-3F8A-9ECA-001E46394E29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
   0x7fffa65c1000 -     0x7fffa65c1fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <B4B785D8-CB43-3E5D-AE81-1F27885AA112> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
   0x7fffa6881000 -     0x7fffa7653ff3 com.apple.AppKit (6.9 - 1504.81.100) <0CCB2E18-076E-3D8A-A777-A6E57EF2570A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
   0x7fffa7665000 -     0x7fffa7665fff com.apple.ApplicationServices (48 - 48) <237200C2-28A6-3C19-B34B-53C953F8AE42> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
   0x7fffa7666000 -     0x7fffa76d4ff7 com.apple.ApplicationServices.ATS (377 - 422.2) <3680281F-DB99-3CA2-9C76-CABFC8DBC980> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
 0x7fffa776e000 -     0x7fffa789dfff libFontParser.dylib (194.6) <F3DF2CF7-B25D-30BB-9EE6-1EA9F3B8A066> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
   0x7fffa789e000 -     0x7fffa78e8fff libFontRegistry.dylib (196.3) <855AF921-EAE0-3D07-B161-5EF09806B643> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
   0x7fffa7945000 -     0x7fffa7978ff7 libTrueTypeScaler.dylib (194.6) <D0D7DA50-DF52-3D24-AFD2-03B336AA1929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
   0x7fffa79e4000 -     0x7fffa7a8eff7 com.apple.ColorSync (4.12.0 - 502.1) <5F244DE3-A6E8-335F-AE3B-25F0E407DD62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
   0x7fffa7a8f000 -     0x7fffa7adfff7 com.apple.HIServices (1.22 - 591) <34C950CC-1084-354A-BCE6-9396EDB29DF8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
   0x7fffa7ae0000 -     0x7fffa7aefff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
   0x7fffa7af0000 -     0x7fffa7b3dfff com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
   0x7fffa7b3e000 -     0x7fffa7b79fff com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
   0x7fffa7b7a000 -     0x7fffa7b85ff7 com.apple.speech.synthesis.framework (6.3.3 - 6.3.3) <629831B1-B13C-30F5-AE16-6BB9037E3753> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
   0x7fffa7b86000 -     0x7fffa7d96fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <A1B98513-C19E-376F-8DAF-71BB2F263C5F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
   0x7fffa7d97000 -     0x7fffa7d97fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <55C6A958-D52B-3D81-B230-EB949212B5D9> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
   0x7fffa7f00000 -     0x7fffa82d3ff7 com.apple.CFNetwork (807.2.14 - 807.2.14) <9702C8B9-2984-3DD9-9C59-A83499C2DBC4> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
   0x7fffa82ed000 -     0x7fffa82edfff com.apple.Carbon (154 - 157) <1BF9C0EB-45A0-3584-85DC-F64A9914F40D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
   0x7fffa82ee000 -     0x7fffa82f1fff com.apple.CommonPanels (1.2.6 - 98) <6A71E8CB-3BF7-3A49-A5F7-0579BAE1219D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
   0x7fffa82f2000 -     0x7fffa85faff7 com.apple.HIToolbox (2.1.1 - 856.13) <98D5D2A7-55A6-31A7-9056-CC48EBB16654> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
   0x7fffa85fb000 -     0x7fffa85feff7 com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
   0x7fffa85ff000 -     0x7fffa8604fff com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
   0x7fffa8605000 -     0x7fffa869cff3 com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
   0x7fffa869d000 -     0x7fffa86b7fff com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
   0x7fffa86b8000 -     0x7fffa86b9ff3 com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
   0x7fffa86ba000 -     0x7fffa86bcff7 com.apple.securityhi (9.0 - 55006) <ACD20DC1-FBDE-3E1B-91BF-867FE7849CBC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
   0x7fffa86bd000 -     0x7fffa86c3ff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
   0x7fffa87a2000 -     0x7fffa87a2fff com.apple.Cocoa (6.11 - 22) <CF1AD0E9-2257-35FE-B719-760B58E405C9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
   0x7fffa88e2000 -     0x7fffa8972ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <A38A11A5-130B-39CE-BEBA-F5427F6801DC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
   0x7fffa8973000 -     0x7fffa8986fff com.apple.CoreBluetooth (1.0 - 1) <76AFC4B4-A9FD-3434-B168-90087E71F5C4> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
   0x7fffa8987000 -     0x7fffa8c85fff com.apple.CoreData (120 - 752.8) <694F9EA9-A785-3F84-8EB1-DAF76E3BDF9B> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
   0x7fffa8c86000 -     0x7fffa8d12fff com.apple.CoreDisplay (1.0 - 1) <48B568C0-1E12-34F4-943D-EAB447FBA1BE> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
   0x7fffa8d13000 -     0x7fffa91a7ff7 com.apple.CoreFoundation (6.9 - 1348.28) <0F1FAA52-1C06-327E-A170-382B48B1846D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   0x7fffa91a8000 -     0x7fffa984bff7 com.apple.CoreGraphics (2.0 - 1070.13.2) <ACB5545C-FE91-36C9-8F02-87DF6904A911> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
   0x7fffa984c000 -     0x7fffa9a8efff com.apple.CoreImage (12.2.0 - 451.3.1) <CDAD60F3-74F6-3EA5-A8B5-B42476E350FD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
   0x7fffa9af6000 -     0x7fffa9ba6fff com.apple.CoreMedia (1.0 - 1907.15.15) <B5B8C128-C1C2-3585-9B43-41141B2C6332> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
   0x7fffa9ba7000 -     0x7fffa9bf2ff7 com.apple.CoreMediaIO (804.0 - 4929) <54CF2AD2-4928-3A41-9F7D-F135A8A616D1> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
   0x7fffa9bf3000 -     0x7fffa9bf3fff com.apple.CoreServices (775.9.7 - 775.9.7) <A5C444F3-408B-3062-AF4B-BF8CD919F221> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
   0x7fffa9bf4000 -     0x7fffa9c45fff com.apple.AE (712.2 - 712.2) <342A13C0-4A6A-3947-B66B-0F624A4A7B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
   0x7fffa9c46000 -     0x7fffa9f21ff7 com.apple.CoreServices.CarbonCore (1159.5 - 1159.5) <11CC2194-0C9C-397A-B7F9-CDAB9B68D87D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
   0x7fffa9f22000 -     0x7fffa9f55fff com.apple.DictionaryServices (1.2 - 274) <864F3808-FFDD-3C4B-A5B7-F1A6C4668A86> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
   0x7fffa9f56000 -     0x7fffa9f5effb com.apple.CoreServices.FSEvents (1230 - 1230) <13A2FC17-8F8C-35BF-9584-59FDFB738E2B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
   0x7fffa9f5f000 -     0x7fffaa0cbff7 com.apple.LaunchServices (775.9.7 - 775.9.7) <E350E4F6-822A-3F04-B59B-468A39AF5C64> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
   0x7fffaa0cc000 -     0x7fffaa17cfff com.apple.Metadata (10.7.0 - 1075.28) <DBB524CD-6938-3623-99C2-4B1EC1E1BE58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
   0x7fffaa17d000 -     0x7fffaa1dcfff com.apple.CoreServices.OSServices (775.9.7 - 775.9.7) <E9625B0B-9AE7-3024-9FEF-FEE0A1876D9D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
   0x7fffaa1dd000 -     0x7fffaa24dfff com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
   0x7fffaa24e000 -   0x7fffaa294ff7 com.apple.coreservices.SharedFileList (38 - 38) <E1400999-1F08-35A1-9D07-27D80A2AF89A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
   0x7fffaa321000 -     0x7fffaa46dff7 com.apple.CoreText (352.0 - 544.5) <E90EA1D8-3491-3014-9043-9928C4E4349C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
   0x7fffaa46e000 -     0x7fffaa4a3fff com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
   0x7fffaa4a4000 -     0x7fffaa515ffb com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <BEBE9C03-3B9A-3948-99E3-CC8148FA2AB5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
   0x7fffaa555000 -     0x7fffaa613ff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <4A3165EA-9CC2-3B06-84FF-953C3FE9D812> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
   0x7fffaa614000 -     0x7fffaa619fff com.apple.DiskArbitration (2.7 - 2.7) <16EA6D93-A2EC-31DB-BF52-C4764E7B1630> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
   0x7fffaa7a8000 -     0x7fffaab4fff3 com.apple.Foundation (6.9 - 1349.25) <D820A498-2E62-367D-BC72-5845B14C06E3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
   0x7fffaab7b000 -     0x7fffaabacfff com.apple.GSS (4.0 - 2.0) <95FAD1F9-1610-3428-B9B4-D32F67C26574> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
   0x7fffaac6c000 -     0x7fffaad0fffb com.apple.Bluetooth (5.0.3 - 5.0.3f1) <CCB4E097-1ED0-3439-8450-2B6EFFBC4608> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
   0x7fffaad10000 -     0x7fffaada5ff7 com.apple.framework.IOKit (2.0.2 - 1324.30.13) <163BE7FA-B29A-348F-8B5F-E301F2E8C964> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
   0x7fffaada6000 -     0x7fffaadacffb com.apple.IOSurface (153.3 - 153.3) <3DD3BF22-0800-31F2-B179-87F87D6F0548> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
   0x7fffaadfe000 -     0x7fffaaf5aff7 com.apple.ImageIO.framework (3.3.0 - 1582) <A9A63D25-DA38-33C0-98C6-F015952568B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
   0x7fffaaf5b000 -     0x7fffaaf5ffff libGIF.dylib (1582) <B0435621-A64F-3E0E-AC03-35ED505A61B1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
   0x7fffaaf60000 -     0x7fffab051fff libJP2.dylib (1582) <396280DF-6E69-38A5-883D-1EEBAC80771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
   0x7fffab052000 -     0x7fffab075fff libJPEG.dylib (1582) <E2A44AAD-F6E0-3D74-80AE-BF2542AA6954> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
   0x7fffab076000 -     0x7fffab09cfff libPng.dylib (1582) <FB81BC9C-5BB7-373F-8464-C41A780F762A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
   0x7fffab09d000 -     0x7fffab09fff3 libRadiance.dylib (1582) <825BE3AF-BB9D-3B84-8EFF-8F5FE4C837B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
   0x7fffab0a0000 -     0x7fffab0f9fff libTIFF.dylib (1582) <8C24B061-762D-3EC8-AC64-4961C030D575> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
   0x7fffabcc9000 -     0x7fffabce2ff7 com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
   0x7fffabce3000 -     0x7fffabd19fff com.apple.LDAPFramework (2.4.28 - 194.5) <0F18D033-BBD8-3D88-A17C-EC7E796CA88F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
   0x7fffabf6f000 -     0x7fffabf75fff com.apple.MediaAccessibility (1.0 - 97.1.1) <1025DB59-18DE-39EA-9C04-35CE8D6103E5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
   0x7fffabf8b000 -     0x7fffac4dffff com.apple.MediaToolbox (1.0 - 1907.15.15) <22150DE7-8CD3-30DD-8C0F-3D06F865C186> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
   0x7fffac4e0000 -     0x7fffac538fff com.apple.Metal (86.18 - 86.18) <7DFE0437-25A8-3E87-8318-91573C895742> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
   0x7ffface0c000 -     0x7ffface14fff com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
   0x7fffacfc3000 -     0x7fffacfe8fff com.apple.audio.OpenAL (1.8 - 1.8) <3867A1C7-1D67-37EE-8DA1-520B75D3B234> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
   0x7fffacfe9000 -     0x7fffacff1ff7 libcldcpuengine.dylib (2.8.5) <341EBC48-CCF4-3292-9097-F61715AC573E> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
   0x7fffad1ba000 -     0x7fffad208ff3 com.apple.opencl (2.8.6 - 2.8.6) <553BFCCA-5ACB-3DB0-B958-4BF2DE91838F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
   0x7fffad209000 -     0x7fffad222ffb com.apple.CFOpenDirectory (10.12 - 194) <88E97774-6767-3A01-808B-C923F9310E20> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
   0x7fffad223000 -     0x7fffad22eff7 com.apple.OpenDirectory (10.12 - 194) <0E4E32DD-6592-3860-9793-BAED6915AE0D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
   0x7fffad22f000 -     0x7fffad231fff libCVMSPluginSupport.dylib (13.0.10) <43D037C3-9254-3601-9F5B-CD637D517758> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
   0x7fffad232000 -     0x7fffad235ff7 libCoreFSCache.dylib (151.1) <1910EF80-DE30-3817-8FDF-63F3C8B4BA37> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
   0x7fffad236000 -     0x7fffad239fff libCoreVMClient.dylib (151.1) <8C8E9295-1918-3763-A0B7-6397EB181EF4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
   0x7fffad23a000 -     0x7fffad242ffb libGFXShared.dylib (13.0.10) <52E92D3C-25EA-31F9-9885-DC0D886D9143> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
   0x7fffad243000 -     0x7fffad24efff libGL.dylib (13.0.10) <B40728B5-13D2-3423-9C39-885B1098698D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
   0x7fffad24f000 -     0x7fffad28bfe7 libGLImage.dylib (13.0.10) <3E856113-9217-3B13-98AD-4D0D356931B6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
   0x7fffad28c000 -     0x7fffad402ffb libGLProgrammability.dylib (13.0.10) <4C3FD24A-1C43-343E-8EBA-BE1FDCE3F74C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
   0x7fffad403000 -     0x7fffad443ff3 libGLU.dylib (13.0.10) <BBCAA457-BA34-3D13-8845-803C63960E08> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
   0x7fffaddab000 -     0x7fffaddb9fff com.apple.opengl (13.0.10 - 13.0.10) <B11A2E1B-4B1D-3ECD-BADA-3508BE5775BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
   0x7fffaddba000 -     0x7fffadf60fff GLEngine (13.0.10) <62CCEC13-1EB3-3A65-9224-3DCD2838E0C7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
   0x7fffadf61000 -     0x7fffadf8bffb GLRendererFloat (13.0.10) <E508ABC7-3E67-3845-989F-5B764D36FE12> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
   0x7fffaead6000 -     0x7fffaecd1ff7 com.apple.QuartzCore (1.11 - 449.41.15) <3CD775C0-683D-3B4E-8EC2-AB1DAC4C3AE9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
   0x7fffaf21f000 -     0x7fffaf236ff7 com.apple.ScriptingBridge (1.3.3 - 69) <D93D7916-CDFA-30A6-A349-63E57778EA19> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
   0x7fffaf237000 -     0x7fffaf556fff com.apple.security (7.0 - 57740.31.2) <A47D7BAE-0591-3184-8E44-FB2EB08A19C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
   0x7fffaf557000 -     0x7fffaf5cdff7 com.apple.securityfoundation (6.0 - 55132.20.1) <9407620B-B230-3320-B0B7-5AE59F1D135C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
   0x7fffaf5f7000 -     0x7fffaf5faff3 com.apple.xpc.ServiceManagement (1.0 - 1) <4E24C12E-6164-3A7A-8EB8-C2523492BAE8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
   0x7fffaf981000 -     0x7fffaf9f2ff7 com.apple.SystemConfiguration (1.14 - 1.14) <D9A57D90-E54F-3E1A-AA2F-F5A694BCE4BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
   0x7fffaf9f3000 -     0x7fffafda0fff com.apple.VideoToolbox (1.0 - 1907.15.15) <685B6CCD-3027-3D0F-8B31-2388A3CE1BDC> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
   0x7fffb18bc000 -     0x7fffb18c2ff7 com.apple.APFS (1.0 - 1) <7846BAA7-F9FD-3110-8DCB-C6DFAA86F7B0> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
   0x7fffb202c000 -     0x7fffb2047ff3 com.apple.AppContainer (4.0 - 307.30.3) <EF4C3C83-6F51-38F7-A3D2-2D46EE4560EB> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
   0x7fffb2048000 -     0x7fffb2055ff3 com.apple.AppSandbox (4.0 - 307.30.3) <D2C978EB-F4F1-3E79-9DB1-BEE2A92590CE> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
   0x7fffb2056000 -     0x7fffb2078ffb com.apple.framework.Apple80211 (12.0 - 1200.41) <360012DB-DAE7-3EEF-85F0-E5BE1DE3425D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
   0x7fffb2079000 -     0x7fffb2088fdb com.apple.AppleFSCompression (88 - 1.0) <B6E2148F-BFBF-3F1B-A7DF-0F39190B4C20> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
   0x7fffb2175000 -     0x7fffb220097f com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
   0x7fffb2230000 -     0x7fffb2238ffb com.apple.AppleSRP (5.0 - 1) <F105D2D2-8A12-3361-9C9D-E405668CAF75> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
   0x7fffb223d000 -     0x7fffb228ffff com.apple.AppleVAFramework (5.0.34 - 5.0.34) <2AA15DE0-9A7E-3CC0-988A-3BB080A8F603> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
   0x7fffb2625000 -     0x7fffb26a3fff com.apple.backup.framework (1.8.3 - 1.8.3) <B2E28A7A-1727-3052-AA73-CBC108286C07> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
   0x7fffb26cc000 -     0x7fffb2709ff7 com.apple.bom (14.0 - 193.8) <FAA5CE82-0A87-34C5-A606-81A179009930> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
   0x7fffb3329000 -     0x7fffb3350ffb com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
   0x7fffb3c79000 -     0x7fffb3c82ffb com.apple.CommonAuth (4.0 - 2.0) <830B940B-3523-38DE-996D-695739616D10> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
   0x7fffb3e06000 -     0x7fffb41e3fe7 com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
   0x7fffb41e4000 -     0x7fffb4214fff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
   0x7fffb428a000 -     0x7fffb4292ffb com.apple.frameworks.CoreDaemon (1.3 - 1.3) <212D3DB2-DC44-329F-B810-238DF156D1EE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
   0x7fffb43a2000 -     0x7fffb43b2fff com.apple.CoreEmoji (1.0 - 39.1) <0A46D6BF-22F3-39AD-B3DC-DE1EE5C442CC> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
   0x7fffb4695000 -     0x7fffb46c5ff3 com.apple.CoreServicesInternal (276.2 - 276.2) <7D8DEF04-72F1-39F4-BBFB-09E65D7B8C10> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
   0x7fffb4955000 -     0x7fffb49dffff com.apple.CoreSymbolication (61050) <F4B7C798-F7B7-3977-AA08-59A03F00308E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
   0x7fffb49e0000 -     0x7fffb4b1efd7 com.apple.coreui (2.1 - 430.6) <99D08D71-3E9D-300C-9EB2-A73F1B5E228C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
   0x7fffb4b1f000 -     0x7fffb4bcfff3 com.apple.CoreUtils (5.0 - 500.9) <5567181B-721C-339E-A3DC-579E36D92341> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
   0x7fffb4c1f000 -     0x7fffb4c84ff3 com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <BEFA276C-D284-3160-8641-7DD47E38C9D7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
   0x7fffb4c85000 -     0x7fffb4c92ff7 com.apple.CrashReporterSupport (10.12 - 817) <CB5251B1-5BE5-308B-B30B-0050065E04CC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
   0x7fffb4d04000 -     0x7fffb4d0eff7 com.apple.framework.DFRFoundation (1.0 - 104.14) <258B6CFE-FD64-31C5-9973-2FD80597ECDA> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
   0x7fffb4d44000 -     0x7fffb4dbbff7 com.apple.datadetectorscore (7.0 - 539.1) <E9892E38-3D5F-36CF-BDC5-E4E3C5516B55> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
   0x7fffb4df8000 -     0x7fffb4e37fff com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
   0x7fffb4e38000 -     0x7fffb4f49fff com.apple.desktopservices (1.11.3 - 1.11.3) <CCE689AA-85F3-3587-AE12-1231E8ED127E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
   0x7fffb4f4e000 -     0x7fffb5024ff7 com.apple.DiskImagesFramework (444.41.1 - 444.41.1) <DEE2D0A1-D1E6-333F-AF76-DEEA48426760> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
   0x7fffb50d8000 -     0x7fffb50daffb com.apple.EFILogin (2.0 - 2) <E03C6225-7650-3498-906B-C248A93F55B5> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
   0x7fffb522d000 -     0x7fffb565eff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
   0x7fffb5a5e000 -     0x7fffb69b2fa7 libLLVMContainer.dylib (12) <0035C17F-EC2C-33F4-8FB8-DBCF8CA35C49> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/A/Libraries/libLLVMContainer.dylib
   0x7fffb69b3000 -     0x7fffb69b3fff libmetal_timestamp.dylib (600.0.48.32) <31DF1B9E-0BBF-308B-B78D-11CCE72DAA68> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
   0x7fffb69c0000 -     0x7fffb69cbff3 libGPUSupportMercury.dylib (13.0.10) <7CC5CEF8-D132-3234-A078-6D080DFC599F> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
   0x7fffb6c7f000 -     0x7fffb6c9bff3 com.apple.GenerationalStorage (2.0 - 259.2) <00BF8427-967F-3693-A86F-DA0F29B49BF3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
   0x7fffb7399000 -    0x7fffb740ffff com.apple.Heimdal (4.0 - 2.0) <00F00E7E-7EF4-3254-86D3-ADA4F67938CF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
   0x7fffb7a32000 -     0x7fffb7a39ffb com.apple.IOAccelerator (289.32 - 289.32) <6395ACEE-5AD7-3536-AF12-FD6565415D94> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
   0x7fffb7a3b000 -     0x7fffb7a4fff3 com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
   0x7fffb7a50000 -     0x7fffb7a72fff com.apple.IconServices (74.3 - 74.3) <3F0BD358-D019-3083-82F2-69CCAD5E5D66> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
   0x7fffb7b0e000 -     0x7fffb7b1eff3 com.apple.IntlPreferences (2.0 - 216) <589A5D92-6809-3F3C-900E-DBC60A07A101> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
   0x7fffb7b55000 -     0x7fffb7d0bfff com.apple.LanguageModeling (1.0 - 123.2.4) <FEB98F96-A9BB-3E6C-85B4-B466825B8C92> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
   0x7fffb8365000 -     0x7fffb8368fff com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
   0x7fffb8440000 -     0x7fffb8474ff3 com.apple.MediaKit (16 - 840) <2035FF47-C7E6-3F73-A335-AC0BFBB1DB36> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
   0x7fffb85cf000 -     0x7fffb8648ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <6A759DBA-B7DF-363B-9827-AB1D1129BB34> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
   0x7fffb865a000 -     0x7fffb87adfc7 com.apple.mobiledevice (905.1.2.3.1 - 905.1.2.3.1) <0BC2BDA7-BC9A-3535-9F7A-368E0AA1994B> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
   0x7fffb87ca000 -     0x7fffb87f2fff com.apple.MultitouchSupport.framework (368.7 - 368.7) <A29E6031-E9A6-353A-BDE5-D8DF20FD393C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
   0x7fffb88a1000 -     0x7fffb88abfff com.apple.NetAuth (6.0 - 6.0) <1E7765FC-4580-3CE4-A0F1-CAA22006AE43> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
   0x7fffb9127000 -     0x7fffb9168ff7 com.apple.PerformanceAnalysis (1.145 - 145) <12640C1F-433D-3CD9-B2A8-048D57B8B56D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
   0x7fffb97df000 -     0x7fffb980affb com.apple.ProtectedCloudStorage (1.0 - 1) <4B38E6F6-AD64-3345-B51D-38E9DD518666> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
   0x7fffb980b000 -     0x7fffb9825fff com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
   0x7fffb983f000 -     0x7fffb9862ff3 com.apple.RemoteViewServices (2.0 - 124) <4765DC2E-CF05-38CF-9564-1FBACB7E167C> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
   0x7fffba4ce000 -     0x7fffba4d1fff com.apple.SecCodeWrapper (4.0 - 307.30.3) <1B0B2122-C230-3E3F-8A81-EBD58818586B> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
   0x7fffba560000 -     0x7fffba5ddff7 com.apple.Sharing (696.1.22 - 696.1.22) <D0A5C682-8996-3851-B332-AD05301E6FA3> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
   0x7fffba5fe000 -     0x7fffba86cfff com.apple.SkyLight (1.600.0 - 122.8) <C65A18FE-3021-38F2-9AA1-9527B0ADD4A2> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
   0x7fffbaa4d000 -     0x7fffbaa59ff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <F9F0FCED-3A72-3639-91F2-B7EF248ED1B9> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
   0x7fffbb142000 -     0x7fffbb1aeff3 com.apple.Symbolication (61080.2) <27A57DC2-FEB7-3D23-AEB5-E3E76C5AAE79> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
   0x7fffbb5a8000 -     0x7fffbb5aeff7 com.apple.TCC (1.0 - 1) <956F7C1A-D457-3FE0-9CFE-3F1719F0865C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
   0x7fffbb63d000 -     0x7fffbb805ff7 com.apple.TextureIO (1.41 - 1.41) <3A9D9FD9-8997-3BD1-8046-76D0BF709806> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
   0x7fffbb879000 -     0x7fffbb87afff com.apple.TrustEvaluationAgent (2.0 - 28) <07C1F711-A1E0-3BAC-8F4D-977516D50925> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
   0x7fffbb87b000 -     0x7fffbba0bff3 com.apple.UIFoundation (1.0 - 490.7) <047781ED-9E79-361F-8E04-71FF90C650F3> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
   0x7fffbc467000 -     0x7fffbc52aff7 com.apple.ViewBridge (280 - 280) <6D4F6019-5ECC-377B-AF7D-9796E96841CB> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
   0x7fffbc954000 -     0x7fffbc95afff com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
   0x7fffbca2b000 -     0x7fffbca2dffb com.apple.loginsupport (1.0 - 1) <4449ACBA-27A8-3311-BD92-CB7E63583FC6> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
   0x7fffbca82000 -     0x7fffbca9dff7 libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
   0x7fffbca9e000 -     0x7fffbcaa9fff libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
   0x7fffbcaaa000 -     0x7fffbcb3aff7 libCoreStorage.dylib (540.30.1) <127A0A91-4E62-39A7-B18F-A3E166304505> /usr/lib/libCoreStorage.dylib
   0x7fffbcb3b000 -     0x7fffbcb3cff3 libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
   0x7fffbcb3d000 -     0x7fffbcd50fff libFosl_dynamic.dylib (16.38) <8232FA8A-F16A-3DC0-AE68-B61EFCD5F4A4> /usr/lib/libFosl_dynamic.dylib
 0x7fffbcd6c000 -     0x7fffbcd73fff libMatch.1.dylib (27) <5D52A207-E2AF-3E05-8C51-91C1D82FCEE8> /usr/lib/libMatch.1.dylib
   0x7fffbcd74000 -     0x7fffbcd74fff libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
   0x7fffbcd75000 -     0x7fffbcd79ff3 libScreenReader.dylib (477.20.6) <8158E263-B7DF-3B0C-BABE-4FE94A53DFE5> /usr/lib/libScreenReader.dylib
   0x7fffbcd7a000 -     0x7fffbcd7bff3 libSystem.B.dylib (1238) <9CB018AF-54E9-300F-82BE-81FE553C9154> /usr/lib/libSystem.B.dylib
   0x7fffbcde7000 -     0x7fffbce12ffb libarchive.2.dylib (41.41.1) <D53F0A5C-7FAA-3FCF-8A27-B7DF032C4221> /usr/lib/libarchive.2.dylib
   0x7fffbce13000 -     0x7fffbcf08fef libate.dylib (1.12.13) <DD046A96-07D9-3066-8BD6-D0E27FE9E1D3> /usr/lib/libate.dylib
   0x7fffbcf0c000 -     0x7fffbcf0cff3 libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
   0x7fffbcf0d000 -     0x7fffbcf1dff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
   0x7fffbcf1e000 -     0x7fffbcf2cff7 libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
   0x7fffbcf2d000 -     0x7fffbcf83ff7 libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
   0x7fffbcf84000 -     0x7fffbcfaefff libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
   0x7fffbcfaf000 -     0x7fffbcfbfffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
   0x7fffbcfc0000 -     0x7fffbcfd5ffb libcompression.dylib (34) <AEF908E6-C0FE-3884-BD45-FB37A035545D> /usr/lib/libcompression.dylib
   0x7fffbcfd6000 -     0x7fffbcfd6ff7 libcoretls.dylib (121.31.1) <BCC32537-4831-3E9F-876E-8C9F4CF52FD3> /usr/lib/libcoretls.dylib
   0x7fffbcfd7000 -     0x7fffbcfd8ff3 libcoretls_cfhelpers.dylib (121.31.1) <6F37C5AD-7999-3D31-A52F-7AEED935F32D> /usr/lib/libcoretls_cfhelpers.dylib
   0x7fffbd092000 -     0x7fffbd177ff7 libcrypto.0.9.8.dylib (64.30.2) <D41E1901-06DD-3860-BB4F-B3ACE0284C01> /usr/lib/libcrypto.0.9.8.dylib
   0x7fffbd309000 -     0x7fffbd314fff libcsfde.dylib (540.30.1) <8E7FAE94-37E0-3181-B2C4-9878FFF63851> /usr/lib/libcsfde.dylib
   0x7fffbd315000 -     0x7fffbd368ff7 libcups.2.dylib (450) <78243BA4-43AB-3364-8111-8D54D3382621> /usr/lib/libcups.2.dylib
   0x7fffbd369000 -     0x7fffbd3b9ffb libcurl.4.dylib (95.31.1) <F078ABAE-B13D-3436-A3B8-0B3DFFCF090F> /usr/lib/libcurl.4.dylib
   0x7fffbd3ba000 -     0x7fffbd3c1ff3 libdscsym.dylib (145.1) <E121E3BC-D2B7-37C3-86A8-5DFC3ECF94D6> /usr/lib/libdscsym.dylib
   0x7fffbd3e3000 -     0x7fffbd3e3fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
   0x7fffbd3f1000 -     0x7fffbd3f2fff libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
   0x7fffbd3f3000 -     0x7fffbd3f8ff7 libheimdal-asn1.dylib (498.30.1) <4ED9F6E3-83BC-3302-B004-C25399DA0333> /usr/lib/libheimdal-asn1.dylib
   0x7fffbd3f9000 -     0x7fffbd4ebff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
   0x7fffbd4ec000 -     0x7fffbd711ffb libicucore.A.dylib (57149.0.1) <6B5FDA93-AA88-318F-9608-C2A33D602EC7> /usr/lib/libicucore.A.dylib
   0x7fffbd717000 -     0x7fffbd718fff liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
   0x7fffbd719000 -     0x7fffbd732ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
   0x7fffbd733000 -     0x7fffbd749ff7 libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
   0x7fffbd74a000 -     0x7fffbd9f1ff7 libmecabra.dylib (744.5) <EF046855-CB9C-32D8-B2F1-C85B526E386F> /usr/lib/libmecabra.dylib
   0x7fffbda24000 -     0x7fffbda9dff7 libnetwork.dylib (856.30.16) <66C6E4D6-B39C-3309-80C1-CBBE170DDD51> /usr/lib/libnetwork.dylib
   0x7fffbda9e000 -     0x7fffbde73127 libobjc.A.dylib (706) <47104A1B-13E8-369F-BC36-27FF465809FD> /usr/lib/libobjc.A.dylib
   0x7fffbde76000 -     0x7fffbde7afff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
   0x7fffbde7b000 -     0x7fffbdeabff7 libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
   0x7fffbdec9000 -     0x7fffbdee5ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
   0x7fffbdee6000 -     0x7fffbdf1ffff libsandbox.1.dylib (592.31.1) <0B3D5690-EF2C-39A6-B63C-CFB8CBAC0956> /usr/lib/libsandbox.1.dylib
   0x7fffbdf20000 -     0x7fffbdf32ffb libsasl2.2.dylib (209) <5A177BA8-362D-32DA-8D14-69AB191648B3> /usr/lib/libsasl2.2.dylib
   0x7fffbdf33000 -     0x7fffbdf34ff3 libspindump.dylib (230.3) <59FAC445-F8FB-3881-A69A-FD0E98100E19> /usr/lib/libspindump.dylib
   0x7fffbdf35000 -     0x7fffbe076fff libsqlite3.dylib (253) <AECBC92F-FF00-3369-8ECB-AE053B3578B8> /usr/lib/libsqlite3.dylib
   0x7fffbe099000 -     0x7fffbe0d1ff3 libssl.0.9.8.dylib (64.30.2) <6E690FB1-A581-3027-93B3-060D9D497A27> /usr/lib/libssl.0.9.8.dylib
   0x7fffbe0d2000 -     0x7fffbe122fff libstdc++.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc++.6.dylib
   0x7fffbe167000 -     0x7fffbe16aff7 libutil.dylib (47.30.1) <C29FFC2C-C7F0-39EA-9215-F5A2DCAF570A> /usr/lib/libutil.dylib
   0x7fffbe16b000 -     0x7fffbe178fff libxar.1.dylib (357) <58BFB84B-66FE-3299-AA3D-BBA178ADEE39> /usr/lib/libxar.1.dylib
   0x7fffbe17c000 -     0x7fffbe26bffb libxml2.2.dylib (30.11) <E12AF929-0FA5-3214-840F-C81E6AC9F36E> /usr/lib/libxml2.2.dylib
   0x7fffbe26c000 -     0x7fffbe295fff libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
   0x7fffbe296000 -     0x7fffbe2a7ff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
   0x7fffbe2b6000 -     0x7fffbe2baff7 libcache.dylib (79) <0C8092D3-600F-3ADD-A036-F225B6CDCA43> /usr/lib/system/libcache.dylib
   0x7fffbe2bb000 -     0x7fffbe2c6ff7 libcommonCrypto.dylib (60092.30.2) <B16E29B6-EC8D-3A8F-9A89-DD9CF35F7C4B> /usr/lib/system/libcommonCrypto.dylib
   0x7fffbe2c7000 -     0x7fffbe2cefff libcompiler_rt.dylib (62) <E992E8D9-037C-3454-A366-A25E4D31D6BB> /usr/lib/system/libcompiler_rt.dylib
   0x7fffbe2cf000 -     0x7fffbe2d7fff libcopyfile.dylib (138) <64E285D9-5485-333B-AEE7-8B0C8FB9275F> /usr/lib/system/libcopyfile.dylib
   0x7fffbe2d8000 -     0x7fffbe35bfdf libcorecrypto.dylib (442.30.20) <2074B932-FD79-30A9-8E90-AF25C49F2AF1> /usr/lib/system/libcorecrypto.dylib
   0x7fffbe35c000 -     0x7fffbe38efff libdispatch.dylib (703.30.5) <EA0CC14E-D559-3802-B4B2-0E8C7579AAC4> /usr/lib/system/libdispatch.dylib
   0x7fffbe38f000 -     0x7fffbe394ff3 libdyld.dylib (421.2) <6F506653-FFF6-3DB8-84F1-109AE3C52F32> /usr/lib/system/libdyld.dylib
   0x7fffbe395000 -     0x7fffbe395ffb libkeymgr.dylib (28) <1A318923-1200-3B06-B432-5007D82F195D> /usr/lib/system/libkeymgr.dylib
   0x7fffbe396000 -     0x7fffbe3a2ffb libkxld.dylib (3789.41.3) <87550136-9353-348B-9CD9-C342B48C5AAF> /usr/lib/system/libkxld.dylib
   0x7fffbe3a3000 -     0x7fffbe3a3fff liblaunch.dylib (972.30.7) <15FACC21-079A-3BDF-9AFB-4253EFDEB587> /usr/lib/system/liblaunch.dylib
   0x7fffbe3a4000 -     0x7fffbe3a9fff libmacho.dylib (894) <A2F38EC1-C37C-3B93-B0E4-36B07C177F8C> /usr/lib/system/libmacho.dylib
   0x7fffbe3aa000 -     0x7fffbe3acff3 libquarantine.dylib (85) <C1D7749F-5F5F-3BB9-BEFC-1F0B9DA941FD> /usr/lib/system/libquarantine.dylib
   0x7fffbe3ad000 -     0x7fffbe3aeffb libremovefile.dylib (45) <CD42974E-BE0B-39FC-9BFC-8A7540A04DC6> /usr/lib/system/libremovefile.dylib
   0x7fffbe3af000 -     0x7fffbe3c7ff7 libsystem_asl.dylib (349.30.2) <EFAC72D7-CB13-3DF7-ADF3-EC6635C6F1EA> /usr/lib/system/libsystem_asl.dylib
   0x7fffbe3c8000 -     0x7fffbe3c8ff7 libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
   0x7fffbe3c9000 -     0x7fffbe456fef libsystem_c.dylib (1158.30.7) <2F881962-03CB-3B9D-A782-D98C1BBA4E3D> /usr/lib/system/libsystem_c.dylib
   0x7fffbe457000 -     0x7fffbe45affb libsystem_configuration.dylib (888.30.2) <4FE3983C-E4ED-3939-A578-03AD29C99788> /usr/lib/system/libsystem_configuration.dylib
   0x7fffbe45b000 -     0x7fffbe45efff libsystem_coreservices.dylib (41.4) <1A572B9E-0C47-320F-8C64-7990D0A5FB5A> /usr/lib/system/libsystem_coreservices.dylib
   0x7fffbe45f000 -     0x7fffbe477ff3 libsystem_coretls.dylib (121.31.1) <4676F06D-274D-31BE-B61C-4D7A4AEF4858> /usr/lib/system/libsystem_coretls.dylib
   0x7fffbe478000 -     0x7fffbe47efff libsystem_dnssd.dylib (765.30.11) <DC708D84-ED7D-3936-B996-A67C66B8DDAA> /usr/lib/system/libsystem_dnssd.dylib
   0x7fffbe47f000 -     0x7fffbe4a8ff7 libsystem_info.dylib (503.30.1) <9ED9121C-F111-3FAD-BC2F-C95DEE1C9362> /usr/lib/system/libsystem_info.dylib
   0x7fffbe4a9000 -     0x7fffbe4cbff7 libsystem_kernel.dylib (3789.41.3) <B75B128C-7D7A-3318-91CD-82B5A69C5329> /usr/lib/system/libsystem_kernel.dylib
   0x7fffbe4cc000 -     0x7fffbe513fe7 libsystem_m.dylib (3121.4) <266DB92B-A86F-3691-80FB-1B26AD73CFF3> /usr/lib/system/libsystem_m.dylib
   0x7fffbe514000 -     0x7fffbe532ff7 libsystem_malloc.dylib (116.30.3) <F40DEE3B-386A-3529-A3F7-98117ED55BF4> /usr/lib/system/libsystem_malloc.dylib
   0x7fffbe533000 -     0x7fffbe58affb libsystem_network.dylib (856.30.16) <4AE368E9-605D-379D-B04C-2AC7455B8250> /usr/lib/system/libsystem_network.dylib
   0x7fffbe58b000 -     0x7fffbe594ff3 libsystem_networkextension.dylib (563.30.15) <EB020B0C-7DF0-3EEF-8E3C-15DA3C01D687> /usr/lib/system/libsystem_networkextension.dylib
   0x7fffbe595000 -     0x7fffbe59eff3 libsystem_notify.dylib (165.20.1) <E7FD3A7C-DD07-36E2-9FA4-7561F9F114DA> /usr/lib/system/libsystem_notify.dylib
   0x7fffbe59f000 -     0x7fffbe5a7fe7 libsystem_platform.dylib (126.1.2) <3CA06D4E-C00A-36DE-AA65-3A390097D1F6> /usr/lib/system/libsystem_platform.dylib
   0x7fffbe5a8000 -     0x7fffbe5b2ff7 libsystem_pthread.dylib (218.30.1) <C869ED7C-BE29-3532-8E69-3A8DA1447EDC> /usr/lib/system/libsystem_pthread.dylib
   0x7fffbe5b3000 -     0x7fffbe5b6ff7 libsystem_sandbox.dylib (592.31.1) <7BBFDF96-293F-3DD9-B3A4-7C168280B441> /usr/lib/system/libsystem_sandbox.dylib
   0x7fffbe5b7000 -     0x7fffbe5b8fff libsystem_secinit.dylib (24) <5C1F1E47-0F7D-3E25-8DEB-D9DB1F902281> /usr/lib/system/libsystem_secinit.dylib
   0x7fffbe5b9000 -     0x7fffbe5c0fff libsystem_symptoms.dylib (532.30.6) <5D990CF5-B58F-39F7-B375-99B4EC62CFBD> /usr/lib/system/libsystem_symptoms.dylib
   0x7fffbe5c1000 -     0x7fffbe5e1ff7 libsystem_trace.dylib (518.30.7) <6D34D1EA-2A3C-3D2D-803E-A666E6AEEE52> /usr/lib/system/libsystem_trace.dylib
   0x7fffbe5e2000 -     0x7fffbe5e7ffb libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
   0x7fffbe5e8000 -     0x7fffbe611ff7 libxpc.dylib (972.30.7) <65E41BB6-EBD5-3D93-B0BE-B190CEE4DD93> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
   task_for_pid: 1
   thread_create: 0
   thread_set_state: 0
Calls made by this process:
   task_for_pid: 0
   thread_create: 0
   thread_set_state: 0
Calls made by all processes on this machine:
   task_for_pid: 1226
   thread_create: 0
   thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=325.2M resident=0K(0%) swapped_out_or_unallocated=325.2M(100%)
Writable regions: Total=1.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.1G(100%)
                               VIRTUAL   REGION
REGION TYPE                       SIZE   COUNT (non-coalesced)
Accelerate framework               384K       3
Activity Tracing                   256K       2
CG backing stores                 3444K       4
CG image                         1404K       12
CoreAnimation                       28K       4
CoreUI image data                 704K       9
CoreUI image file                 180K       5
Dispatch continuations           8192K       2
IOKit                             7940K       2
Image IO                         1036K       5
Kernel Alloc Once                   8K       2
MALLOC                          556.1M     125
MALLOC guard page                   48K       9
Memory Tag 242                     12K       2
OpenGL GLSL                       256K       4
STACK GUARD                       56.1M       16
Stack                            18.1M     563
Stack Guard                         4K       2
VM_ALLOCATE                     502.6M     260
VM_ALLOCATE (reserved)             36K       2         reserved VM address space (unallocated)
__DATA                            37.3M     272
__GLSLBUILTINS                   2588K       2
__IMAGE                           528K       2
__LINKEDIT                       117.3M       15
__TEXT                           207.9M     270
__UNICODE                        556K       2
mapped file                       43.2M       12
shared memory                     16.4M       16
TOTAL                             1.5G     1596
TOTAL, minus reserved VM space     1.5G     1596
Model: iMac13,1, BootROM IM131.010A.B0A, 4 processors, Intel Core i5, 2.9 GHz, 8 GB, SMC 2.9f5
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF4), Broadcom BCM43xx 1.0 (7.21.171.68.1a5)
Bluetooth: Version 5.0.3f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS541010A9E662, 1 TB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 2.0 Hub
USB Device: ANT USBStick2
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB 3.0 Bus
Thunderbolt Bus: iMac, Apple Inc., 23.4
Did it again today…
Process:               ZwiftApp [532]
Version:               ???
Responsible:           ZwiftApp [532]
User ID:               501
Date/Time:             2017-02-25 15:55:48.296 +0000
Report Version:       12
Time Awake Since Boot: 960 seconds
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000028
VM Regions Near 0x28:
   __TEXT                 0000000108e70000-000000010968f000 [8316K] r-x/rwx SM=COW /Users/USER/Library/Application Support/Zwift/*
0   com.apple.GeForceGLDriver        0x00007fff9572b8bd 0x7fff95409000 + 3287229
1   com.apple.GeForceGLDriver        0x00007fff9572b7dd 0x7fff95409000 + 3287005
2   com.apple.GeForceGLDriver        0x00007fff956f4ead 0x7fff95409000 + 3063469
3   com.apple.GeForceGLDriver        0x00007fff95738228 0x7fff95409000 + 3338792
4   com.apple.GeForceGLDriver        0x00007fff95738cb0 0x7fff95409000 + 3341488
5   com.apple.GeForceGLDriver        0x00007fff957395c0 0x7fff95409000 + 3343808
6   com.apple.GeForceGLDriver        0x00007fff956e6d04 0x7fff95409000 + 3005700
7   com.apple.GeForceGLDriver        0x00007fff956ddd24 0x7fff95409000 + 2968868
8   com.apple.GeForceGLDriver        0x00007fff9572a43b 0x7fff95409000 + 3281979
9   com.apple.GeForceGLDriver        0x00007fff95712b77 0x7fff95409000 + 3185527
10 com.apple.GeForceGLDriver     0x00007fff95713019 gldUpdateDispatch + 397
11 GLEngine                        0x00007fff9f0e5f5d gleDoDrawDispatchCore + 520
12 GLEngine                        0x00007fff9f0a72d8 glDrawRangeElements_ACC_Exec + 302
13 libGL.dylib                       0x00007fff9e465980 glDrawRangeElements + 45
14 ZwiftApp                         0x00000001093919ee GDEMESH_RenderTieMesh_Group(GDE_360_TIE_LOD const*, GDE_360_TIE_STRIPGROUP const*) + 462
15 ZwiftApp                         0x0000000109392138 GDE_RenderMesh(GDE_Header_360 const*, unsigned int, unsigned long long, bool, VEC4) + 648
16 ZwiftApp                         0x0000000108ebc5c4 RoadPropEntity::Render() + 868
17 ZwiftApp                         0x0000000108f98be0 EntityManager::Render() + 80
18 ZwiftApp                          0x0000000108feac5c drawNewWorld(float, float, float, float, float) + 13516
19 ZwiftApp                         0x0000000108fef626 Render(float) + 982
20 ZwiftApp                         0x0000000108ff0c44 doFrame() + 804
21 ZwiftApp                          0x0000000108ffff95 CODEmain(int, char const**) + 85
22 ZwiftApp                         0x0000000108fcf9a3 main + 595
23 ZwiftApp                         0x0000000108e723f4 start + 52
Thread 1:
0   libsystem_kernel.dylib                0x00007fffaf6e1fda __semwait_signal + 10
1   libsystem_c.dylib             0x00007fffaf668b72 nanosleep + 199
2   ZwiftApp                          0x0000000109386013 JM_Worker_Thread(void*) + 307
3   libsystem_pthread.dylib              0x00007fffaf7caaab _pthread_body + 180
4   libsystem_pthread.dylib              0x00007fffaf7ca9f7 _pthread_start + 286
5   libsystem_pthread.dylib              0x00007fffaf7ca1fd thread_start + 13
Thread 2:
0   libsystem_kernel.dylib                0x00007fffaf6e1c86 __psynch_cvwait + 10
1   libsystem_pthread.dylib              0x00007fffaf7cb96a _pthread_cond_wait + 712
2   ZwiftApp                          0x00000001094584fb AK::StreamMgr::CAkIOThread::IOSchedThread(void*) + 75
Thread 3:
0   libsystem_kernel.dylib                0x00007fffaf6da3c6 semaphore_wait_trap + 10
1   ZwiftApp                          0x000000010942a793 CAkThreadedBankMgr::BankThreadFunc(void*) + 51
2   libsystem_pthread.dylib              0x00007fffaf7caaab _pthread_body + 180
3   libsystem_pthread.dylib              0x00007fffaf7ca9f7 _pthread_start + 286
4   libsystem_pthread.dylib              0x00007fffaf7ca1fd thread_start + 13
Thread 4:
1   ZwiftApp                          0x000000010943016f CAkAudioThread::EventMgrThreadFunc(void*) + 63
Thread 5:
1   ZwiftApp                          0x00000001093e933b CAkOutputMgr::SuspendedThread(void*) + 59
0   libsystem_kernel.dylib                0x00007fffaf6da38a mach_msg_trap + 10
1   libsystem_kernel.dylib                0x00007fffaf6d97d7 mach_msg + 55
2   com.apple.audio.CoreAudio        0x00007fff99b3ff26 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 122
3   com.apple.audio.CoreAudio        0x00007fff99b3fe9c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4   com.apple.audio.CoreAudio        0x00007fff99b3ccee HALC_ProxyIOContext::IOWorkLoop() + 1198
5   com.apple.audio.CoreAudio        0x00007fff99b3c667 HALC_ProxyIOContext::IOThreadEntry(void*) + 131
6   com.apple.audio.CoreAudio        0x00007fff99b3c38b HALB_IOThread::Entry(void*) + 75
7   libsystem_pthread.dylib              0x00007fffaf7caaab _pthread_body + 180
8   libsystem_pthread.dylib              0x00007fffaf7ca9f7 _pthread_start + 286
9   libsystem_pthread.dylib              0x00007fffaf7ca1fd thread_start + 13
2   com.apple.CoreFoundation        0x00007fff99fb7e84 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation        0x00007fff99fb7301 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation        0x00007fff99fb6b54 CFRunLoopRunSpecific + 420
5   com.apple.AppKit                        0x00007fff97c34a62 _NSEventThread + 205
6   libsystem_pthread.dylib              0x00007fffaf7caaab _pthread_body + 180
7   libsystem_pthread.dylib              0x00007fffaf7ca9f7 _pthread_start + 286
8   libsystem_pthread.dylib              0x00007fffaf7ca1fd thread_start + 13
Thread 8:
5   com.apple.CoreFoundation        0x00007fff99ff6631 CFRunLoopRun + 97
6   libant.dylib                      0x0000000109dbb641 IOKitDeviceHandle::EventThread() + 265
7   libant.dylib                      0x0000000109dba7b3 IOKitDeviceHandle::EventThreadStart(void*) + 9
8   libsystem_pthread.dylib              0x00007fffaf7caaab _pthread_body + 180
9   libsystem_pthread.dylib              0x00007fffaf7ca9f7 _pthread_start + 286
10 libsystem_pthread.dylib            0x00007fffaf7ca1fd thread_start + 13
Thread 9:
0   libsystem_kernel.dylib                0x00007fffaf6e3232 poll + 10
1   libant.dylib                      0x0000000109db83c4 IOKitTransfer::Receive() + 126
2   libant.dylib                      0x0000000109dbb45e IOKitDeviceHandle::SendSyncBulkTransfer(unsigned char, unsigned char*, int, unsigned int, int&) + 182
3   libant.dylib                      0x0000000109dbc080 USBDeviceHandleIOKit::ReceiveThread() + 178
4   libant.dylib                      0x0000000109dbbed7 USBDeviceHandleIOKit::ProcessThread(void*) + 9
5   libsystem_pthread.dylib              0x00007fffaf7caaab _pthread_body + 180
6   libsystem_pthread.dylib              0x00007fffaf7ca9f7 _pthread_start + 286
7   libsystem_pthread.dylib              0x00007fffaf7ca1fd thread_start + 13
Thread 10:
2   libant.dylib                      0x0000000109dc0955 DSIThread_CondTimedWait + 136
3   libant.dylib                      0x0000000109dbe122 TSQueue<char, std::deque<char, std::allocator<char> > >::PopArray(char*, unsigned int, unsigned int) + 74
4   libant.dylib                      0x0000000109dbbfb9 USBDeviceHandleIOKit::Read(void*, unsigned int, unsigned int&, unsigned int) + 35
5   libant.dylib                      0x0000000109dc0656 DSISerialGeneric::ReceiveThread() + 96
6   libant.dylib                      0x0000000109dc04e1 DSISerialGeneric::ProcessThread(void*) + 9
Thread 11:
3   libant.dylib                      0x0000000109dc22c1 DSIFramerANT::WaitForMessage(unsigned int) + 87
4   libant.dylib                      0x0000000109db6077 MessageThread(void*) + 632
Thread 12:
0   libsystem_kernel.dylib                0x00007fffaf6e2e2a kevent + 10
1   ZwiftApp                          0x0000000109221061 asio::detail::kqueue_reactor::run(bool, asio::detail::op_queue<asio::detail::task_io_service_operation>&) + 265
2   ZwiftApp                          0x0000000109220d95 asio::detail::task_io_service::do_run_one(asio::detail::scoped_lock<asio::detail::posix_mutex>&, asio::detail::task_io_service_thread_info&, std::__1::error_code const&) + 267
3   ZwiftApp                          0x0000000109220a7e asio::detail::task_io_service::run(std::__1::error_code&) + 416
4   ZwiftApp                          0x000000010918d247 asio::io_service::run() + 43
5   ZwiftApp                          0x000000010922555c asio_detail_posix_thread_function + 19
Thread 13:
Thread 14:
0   libsystem_kernel.dylib                0x00007fffaf6e24e2 __workq_kernreturn + 10
1   libsystem_pthread.dylib              0x00007fffaf7ca5fe _pthread_wqthread + 1023
2   libsystem_pthread.dylib              0x00007fffaf7ca1ed start_wqthread + 13
Thread 15:
3   libant.dylib                      0x0000000109dbfd0c DSITimer::TimerThread() + 94
4   libant.dylib                      0x0000000109dbfbcd DSITimer::TimerThreadStart(void*) + 9
rax: 0x0000000000000000 rbx: 0x00007ff8ccf39b20 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x00007fff56d8d060 rbp: 0x00007fff56d8d050 rsp: 0x00007fff56d8d020
   r8: 0x0000000000010035   r9: 0x0000000000080000 r10: 0x0000000000001000 r11: 0x0000000000001000
r12: 0x0000000000000001 r13: 0x0000000000001000 r14: 0x00007ff8cd14ca00 r15: 0x00007ff8ccf39b01
rip: 0x00007fff9572b8bd rfl: 0x0000000000010202 cr2: 0x0000000000000028
Logical CPU:     1
Trap Number:     14
Binary Images:
       0x108e70000 -       0x10968efef +ZwiftApp (???) <27789409-B461-3FD1-B047-B883720C3D89> /Users/USER/Library/Application Support/Zwift/ZwiftApp
       0x109d12000 -       0x109d6eff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <5440B95E-0391-32BA-8C2B-6568553F72E7> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
       0x109db5000 -       0x109dd2fff +libant.dylib (0) <69DB8DF7-7E3F-33EE-9472-45DD36CFD413> /Users/USER/Library/Application Support/Zwift/libant.dylib
       0x109dfd000 -       0x109e3cffb com.apple.glut (3.6.8 - GLUT-3.6.8) <B773A6AC-B274-3E39-A81B-342060F72B54> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
       0x109eb1000 -       0x109eefff7 com.apple.audio.midi.CoreMIDI (1.10 - 88) <05B584BA-1FEA-3D34-8ABB-7C8C37952CB0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x109f19000 -       0x10a045ff7 com.apple.AudioVideoBridging (500.19 - 500.19) <107C2945-A1C6-3DF2-9914-C41909C99EE1> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
       0x10a0fe000 -       0x10a117ffb libexpat.1.dylib (15) <617B8B7A-A0AB-37D6-AFCA-F90F7F14E455> /usr/lib/libexpat.1.dylib
       0x10a124000 -       0x10a138ff3 com.apple.AudioServerApplication (1.0 - 200.9) <F3A5C381-B7D2-3BE1-AB30-3426922C3938> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
       0x10a14c000 -       0x10a15bfff com.apple.TimeSync (1.0 - 500.27) <962394AB-8359-31B4-8671-AAF2C535A8E8> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
     0x10ae82000 -       0x10ae86fff com.apple.audio.AppleHDAHALPlugIn (278.56 - 278.56) <CDA14261-23B7-30CD-B27B-1459F5C70F9D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x10ff8e000 -       0x1100f8fff com.apple.audio.units.Components (1.14 - 1.14) <12D3C1ED-30A2-3270-B1B7-E5E64E245959> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
       0x1141d0000 -       0x11420d267 dyld (421.2) <947FC440-80F9-32F7-A773-6FC418FE1AB7> /usr/lib/dyld
       0x126d95000 -       0x126d9dff7 com.apple.iokit.IOUSBLib (900.4.1 - 900.4.1) <910CA10A-FAED-32D2-B900-BA7B84E82C41> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
   0x7fff94acc000 -     0x7fff94e05fff com.apple.RawCamera.bundle (7.01 - 889) <155ED09B-673E-3726-8302-E54AADAC5B63> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
   0x7fff94f33000 -     0x7fff95408fff com.apple.GeForceAIRPlugin (10.14.20 - 10.1.4) <06838AF2-9837-38D3-AE45-8AD61DB52B4C> /System/Library/Extensions/GeForceAIRPlugin.bundle/Contents/MacOS/GeForceAIRPlugin
   0x7fff95409000 -     0x7fff95c55fff com.apple.GeForceGLDriver (10.14.20 - 10.1.4) <E96D52FC-436A-304B-9C89-81DF0923A16D> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
   0x7fff95c56000 -     0x7fff96524ff3 libclh.dylib (4.0.3 - 4.0.3) <17D1CEB7-CFC3-356B-92B3-CE3E4E9A4618> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
   0x7fff96525000 -     0x7fff96635ff7 com.apple.GeForceMTLDriver (10.14.20 - 10.1.4) <F2438C2D-0DF4-35D6-BD4D-5A8551038779> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
   0x7fff96636000 -     0x7fff967f5ffb com.apple.avfoundation (2.0 - 1187.11.13) <0D0BB4A4-F987-381B-885E-88A81F50FD50> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
   0x7fff967f6000 -     0x7fff96899fff com.apple.audio.AVFAudio (1.0 - ???) <E3CDC215-9272-3F94-8093-865CA181F728> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
   0x7fff96962000 -     0x7fff96962fff com.apple.Accelerate (1.11 - Accelerate 1.11) <BDDB2053-BB24-34E4-A452-50D1260BF672> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
   0x7fff96963000 -     0x7fff9697aff3 libCGInterfaces.dylib (331.5) <4E2DCEFA-F243-3FAE-8BFC-0B349973DD14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
   0x7fff9697b000 -     0x7fff96fbbfe3 com.apple.vImage (8.1 - ???) <77F96C96-725E-31E5-8072-D09C6BD988A2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
   0x7fff96fbc000 -     0x7fff97183fef libBLAS.dylib (1185) <0D55CF73-6DBD-3D15-B500-189479638551> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
   0x7fff97184000 -     0x7fff9719bfff libBNNS.dylib (14) <43A9B06E-3C21-3CE6-B0C1-99DA172DEEB0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
   0x7fff9719c000 -     0x7fff975a7fff libLAPACK.dylib (1185) <E7AE9C48-6E42-3EB7-A257-D48E0CB48D00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
   0x7fff975a8000 -     0x7fff975befff libLinearAlgebra.dylib (1185) <08F00EFB-B477-3421-906E-3D364E607E6A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
   0x7fff975bf000 -     0x7fff975c5fff libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
   0x7fff975c6000 -     0x7fff975d9ff7 libSparseBLAS.dylib (1185) <912E3D25-27C0-3245-B64C-3CAD43A5D633> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
   0x7fff975da000 -     0x7fff97727ff7 libvDSP.dylib (600) <87EF1D0A-1F85-31DD-AD8F-AB31E7D8E73B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
   0x7fff97728000 -     0x7fff977dffff libvMisc.dylib (600) <F6EA539E-0A90-3F8A-9ECA-001E46394E29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
   0x7fff977e0000 -     0x7fff977e0fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <B4B785D8-CB43-3E5D-AE81-1F27885AA112> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
   0x7fff97aa0000 -     0x7fff98872ff3 com.apple.AppKit (6.9 - 1504.81.100) <0CCB2E18-076E-3D8A-A777-A6E57EF2570A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
   0x7fff98884000 -     0x7fff98884fff com.apple.ApplicationServices (48 - 48) <237200C2-28A6-3C19-B34B-53C953F8AE42> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
   0x7fff98885000 -     0x7fff988f3ff7 com.apple.ApplicationServices.ATS (377 - 422.2) <3680281F-DB99-3CA2-9C76-CABFC8DBC980> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
   0x7fff9898d000 -     0x7fff98abcfff libFontParser.dylib (194.6) <F3DF2CF7-B25D-30BB-9EE6-1EA9F3B8A066> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
   0x7fff98abd000 -     0x7fff98b07fff libFontRegistry.dylib (196.3) <855AF921-EAE0-3D07-B161-5EF09806B643> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
   0x7fff98b64000 -     0x7fff98b97ff7 libTrueTypeScaler.dylib (194.6) <D0D7DA50-DF52-3D24-AFD2-03B336AA1929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
   0x7fff98c03000 -     0x7fff98cadff7 com.apple.ColorSync (4.12.0 - 502.1) <5F244DE3-A6E8-335F-AE3B-25F0E407DD62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
   0x7fff98cae000 -     0x7fff98cfeff7 com.apple.HIServices (1.22 - 591) <34C950CC-1084-354A-BCE6-9396EDB29DF8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
   0x7fff98cff000 -     0x7fff98d0eff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
   0x7fff98d0f000 -     0x7fff98d5cfff com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
   0x7fff98d5d000 -     0x7fff98d98fff com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
   0x7fff98d99000 -     0x7fff98da4ff7 com.apple.speech.synthesis.framework (6.3.3 - 6.3.3) <629831B1-B13C-30F5-AE16-6BB9037E3753> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
   0x7fff98da5000 -     0x7fff98fb5fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <A1B98513-C19E-376F-8DAF-71BB2F263C5F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
   0x7fff98fb6000 -    0x7fff98fb6fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <55C6A958-D52B-3D81-B230-EB949212B5D9> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
   0x7fff9911f000 -     0x7fff994f2ff7 com.apple.CFNetwork (807.2.14 - 807.2.14) <9702C8B9-2984-3DD9-9C59-A83499C2DBC4> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
   0x7fff9950c000 -     0x7fff9950cfff com.apple.Carbon (154 - 157) <1BF9C0EB-45A0-3584-85DC-F64A9914F40D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
   0x7fff9950d000 -     0x7fff99510fff com.apple.CommonPanels (1.2.6 - 98) <6A71E8CB-3BF7-3A49-A5F7-0579BAE1219D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
   0x7fff99511000 -     0x7fff99819ff7 com.apple.HIToolbox (2.1.1 - 856.13) <98D5D2A7-55A6-31A7-9056-CC48EBB16654> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
   0x7fff9981a000 -     0x7fff9981dff7 com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
   0x7fff9981e000 -     0x7fff99823fff com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
   0x7fff99824000 -     0x7fff998bbff3 com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
   0x7fff998bc000 -     0x7fff998d6fff com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
   0x7fff998d7000 -     0x7fff998d8ff3 com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
   0x7fff998d9000 -     0x7fff998dbff7 com.apple.securityhi (9.0 - 55006) <ACD20DC1-FBDE-3E1B-91BF-867FE7849CBC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
   0x7fff998dc000 -     0x7fff998e2ff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
   0x7fff999c1000 -     0x7fff999c1fff com.apple.Cocoa (6.11 - 22) <CF1AD0E9-2257-35FE-B719-760B58E405C9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
   0x7fff99b01000 -     0x7fff99b91ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <A38A11A5-130B-39CE-BEBA-F5427F6801DC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
   0x7fff99b92000 -     0x7fff99ba5fff com.apple.CoreBluetooth (1.0 - 1) <76AFC4B4-A9FD-3434-B168-90087E71F5C4> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
   0x7fff99ba6000 -     0x7fff99ea4fff com.apple.CoreData (120 - 752.8) <694F9EA9-A785-3F84-8EB1-DAF76E3BDF9B> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
   0x7fff99ea5000 -     0x7fff99f31fff com.apple.CoreDisplay (1.0 - 1) <48B568C0-1E12-34F4-943D-EAB447FBA1BE> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
   0x7fff99f32000 -     0x7fff9a3c6ff7 com.apple.CoreFoundation (6.9 - 1348.28) <0F1FAA52-1C06-327E-A170-382B48B1846D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   0x7fff9a3c7000 -     0x7fff9aa6aff7 com.apple.CoreGraphics (2.0 - 1070.13.2) <ACB5545C-FE91-36C9-8F02-87DF6904A911> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
   0x7fff9aa6b000 -     0x7fff9acadfff com.apple.CoreImage (12.2.0 - 451.3.1) <CDAD60F3-74F6-3EA5-A8B5-B42476E350FD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
   0x7fff9ad15000 -     0x7fff9adc5fff com.apple.CoreMedia (1.0 - 1907.15.15) <B5B8C128-C1C2-3585-9B43-41141B2C6332> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
   0x7fff9adc6000 -     0x7fff9ae11ff7 com.apple.CoreMediaIO (804.0 - 4929) <54CF2AD2-4928-3A41-9F7D-F135A8A616D1> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
   0x7fff9ae12000 -     0x7fff9ae12fff com.apple.CoreServices (775.9.7 - 775.9.7) <A5C444F3-408B-3062-AF4B-BF8CD919F221> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
   0x7fff9ae13000 -     0x7fff9ae64fff com.apple.AE (712.2 - 712.2) <342A13C0-4A6A-3947-B66B-0F624A4A7B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
   0x7fff9ae65000 -     0x7fff9b140ff7 com.apple.CoreServices.CarbonCore (1159.5 - 1159.5) <11CC2194-0C9C-397A-B7F9-CDAB9B68D87D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
   0x7fff9b141000 -     0x7fff9b174fff com.apple.DictionaryServices (1.2 - 274) <864F3808-FFDD-3C4B-A5B7-F1A6C4668A86> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
   0x7fff9b175000 -     0x7fff9b17dffb com.apple.CoreServices.FSEvents (1230 - 1230) <13A2FC17-8F8C-35BF-9584-59FDFB738E2B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
   0x7fff9b17e000 -     0x7fff9b2eaff7 com.apple.LaunchServices (775.9.7 - 775.9.7) <E350E4F6-822A-3F04-B59B-468A39AF5C64> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
   0x7fff9b2eb000 -     0x7fff9b39bfff com.apple.Metadata (10.7.0 - 1075.28) <DBB524CD-6938-3623-99C2-4B1EC1E1BE58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
   0x7fff9b39c000 -     0x7fff9b3fbfff com.apple.CoreServices.OSServices (775.9.7 - 775.9.7) <E9625B0B-9AE7-3024-9FEF-FEE0A1876D9D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
   0x7fff9b3fc000 -     0x7fff9b46cfff com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
   0x7fff9b46d000 -     0x7fff9b4b3ff7 com.apple.coreservices.SharedFileList (38 - 38) <E1400999-1F08-35A1-9D07-27D80A2AF89A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
   0x7fff9b540000 -     0x7fff9b68cff7 com.apple.CoreText (352.0 - 544.5) <E90EA1D8-3491-3014-9043-9928C4E4349C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
   0x7fff9b68d000 -     0x7fff9b6c2fff com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
   0x7fff9b6c3000 -     0x7fff9b734ffb com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <BEBE9C03-3B9A-3948-99E3-CC8148FA2AB5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
   0x7fff9b774000 -     0x7fff9b832ff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <4A3165EA-9CC2-3B06-84FF-953C3FE9D812> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
   0x7fff9b833000 -     0x7fff9b838fff com.apple.DiskArbitration (2.7 - 2.7) <16EA6D93-A2EC-31DB-BF52-C4764E7B1630> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
   0x7fff9b9c7000 -     0x7fff9bd6eff3 com.apple.Foundation (6.9 - 1349.25) <D820A498-2E62-367D-BC72-5845B14C06E3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
   0x7fff9bd9a000 -     0x7fff9bdcbfff com.apple.GSS (4.0 - 2.0) <95FAD1F9-1610-3428-B9B4-D32F67C26574> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
   0x7fff9be8b000 -     0x7fff9bf2effb com.apple.Bluetooth (5.0.3 - 5.0.3f1) <CCB4E097-1ED0-3439-8450-2B6EFFBC4608> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
   0x7fff9bf2f000 -     0x7fff9bfc4ff7 com.apple.framework.IOKit (2.0.2 - 1324.30.13) <163BE7FA-B29A-348F-8B5F-E301F2E8C964> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
   0x7fff9bfc5000 -     0x7fff9bfcbffb com.apple.IOSurface (153.3 - 153.3) <3DD3BF22-0800-31F2-B179-87F87D6F0548> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
   0x7fff9c01d000 -     0x7fff9c179ff7 com.apple.ImageIO.framework (3.3.0 - 1582) <A9A63D25-DA38-33C0-98C6-F015952568B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
   0x7fff9c17a000 -     0x7fff9c17efff libGIF.dylib (1582) <B0435621-A64F-3E0E-AC03-35ED505A61B1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
   0x7fff9c17f000 -     0x7fff9c270fff libJP2.dylib (1582) <396280DF-6E69-38A5-883D-1EEBAC80771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
   0x7fff9c271000 -     0x7fff9c294fff libJPEG.dylib (1582) <E2A44AAD-F6E0-3D74-80AE-BF2542AA6954> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
   0x7fff9c295000 -     0x7fff9c2bbfff libPng.dylib (1582) <FB81BC9C-5BB7-373F-8464-C41A780F762A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
   0x7fff9c2bc000 -     0x7fff9c2beff3 libRadiance.dylib (1582) <825BE3AF-BB9D-3B84-8EFF-8F5FE4C837B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
   0x7fff9c2bf000 -     0x7fff9c318fff libTIFF.dylib (1582) <8C24B061-762D-3EC8-AC64-4961C030D575> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
   0x7fff9cee8000 -     0x7fff9cf01ff7 com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
   0x7fff9cf02000 -     0x7fff9cf38fff com.apple.LDAPFramework (2.4.28 - 194.5) <0F18D033-BBD8-3D88-A17C-EC7E796CA88F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
   0x7fff9d18e000 -     0x7fff9d194fff com.apple.MediaAccessibility (1.0 - 97.1.1) <1025DB59-18DE-39EA-9C04-35CE8D6103E5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
   0x7fff9d1aa000 -     0x7fff9d6fefff com.apple.MediaToolbox (1.0 - 1907.15.15) <22150DE7-8CD3-30DD-8C0F-3D06F865C186> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
   0x7fff9d6ff000 -     0x7fff9d757fff com.apple.Metal (86.18 - 86.18) <7DFE0437-25A8-3E87-8318-91573C895742> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
   0x7fff9e02b000 -     0x7fff9e033fff com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
   0x7fff9e1e2000 -     0x7fff9e207fff com.apple.audio.OpenAL (1.8 - 1.8) <3867A1C7-1D67-37EE-8DA1-520B75D3B234> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
   0x7fff9e208000 -     0x7fff9e210ff7 libcldcpuengine.dylib (2.8.5) <341EBC48-CCF4-3292-9097-F61715AC573E> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
   0x7fff9e3d9000 -     0x7fff9e427ff3 com.apple.opencl (2.8.6 - 2.8.6) <553BFCCA-5ACB-3DB0-B958-4BF2DE91838F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
   0x7fff9e428000 -     0x7fff9e441ffb com.apple.CFOpenDirectory (10.12 - 194) <88E97774-6767-3A01-808B-C923F9310E20> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
   0x7fff9e442000 -     0x7fff9e44dff7 com.apple.OpenDirectory (10.12 - 194) <0E4E32DD-6592-3860-9793-BAED6915AE0D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
   0x7fff9e44e000 -     0x7fff9e450fff libCVMSPluginSupport.dylib (13.0.10) <43D037C3-9254-3601-9F5B-CD637D517758> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
   0x7fff9e451000 -     0x7fff9e454ff7 libCoreFSCache.dylib (151.1) <1910EF80-DE30-3817-8FDF-63F3C8B4BA37> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
   0x7fff9e455000 -     0x7fff9e458fff libCoreVMClient.dylib (151.1) <8C8E9295-1918-3763-A0B7-6397EB181EF4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
   0x7fff9e459000 -     0x7fff9e461ffb libGFXShared.dylib (13.0.10) <52E92D3C-25EA-31F9-9885-DC0D886D9143> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
   0x7fff9e462000 -     0x7fff9e46dfff libGL.dylib (13.0.10) <B40728B5-13D2-3423-9C39-885B1098698D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
   0x7fff9e46e000 -     0x7fff9e4aafe7 libGLImage.dylib (13.0.10) <3E856113-9217-3B13-98AD-4D0D356931B6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
   0x7fff9e4ab000 -     0x7fff9e621ffb libGLProgrammability.dylib (13.0.10) <4C3FD24A-1C43-343E-8EBA-BE1FDCE3F74C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
   0x7fff9e622000 -     0x7fff9e662ff3 libGLU.dylib (13.0.10) <BBCAA457-BA34-3D13-8845-803C63960E08> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
   0x7fff9efca000 -     0x7fff9efd8fff com.apple.opengl (13.0.10 - 13.0.10) <B11A2E1B-4B1D-3ECD-BADA-3508BE5775BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
   0x7fff9efd9000 -     0x7fff9f17ffff GLEngine (13.0.10) <62CCEC13-1EB3-3A65-9224-3DCD2838E0C7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
   0x7fff9f180000 -     0x7fff9f1aaffb GLRendererFloat (13.0.10) <E508ABC7-3E67-3845-989F-5B764D36FE12> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
   0x7fff9fcf5000 -     0x7fff9fef0ff7 com.apple.QuartzCore (1.11 - 449.41.15) <3CD775C0-683D-3B4E-8EC2-AB1DAC4C3AE9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
   0x7fffa043e000 -     0x7fffa0455ff7 com.apple.ScriptingBridge (1.3.3 - 69) <D93D7916-CDFA-30A6-A349-63E57778EA19> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
   0x7fffa0456000 -     0x7fffa0775fff com.apple.security (7.0 - 57740.31.2) <A47D7BAE-0591-3184-8E44-FB2EB08A19C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
   0x7fffa0776000 -     0x7fffa07ecff7 com.apple.securityfoundation (6.0 - 55132.20.1) <9407620B-B230-3320-B0B7-5AE59F1D135C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
   0x7fffa0816000 -     0x7fffa0819ff3 com.apple.xpc.ServiceManagement (1.0 - 1) <4E24C12E-6164-3A7A-8EB8-C2523492BAE8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
   0x7fffa0ba0000 -     0x7fffa0c11ff7 com.apple.SystemConfiguration (1.14 - 1.14) <D9A57D90-E54F-3E1A-AA2F-F5A694BCE4BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
   0x7fffa0c12000 -     0x7fffa0fbffff com.apple.VideoToolbox (1.0 - 1907.15.15) <685B6CCD-3027-3D0F-8B31-2388A3CE1BDC> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
   0x7fffa2adb000 -     0x7fffa2ae1ff7 com.apple.APFS (1.0 - 1) <7846BAA7-F9FD-3110-8DCB-C6DFAA86F7B0> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
   0x7fffa324b000 -     0x7fffa3266ff3 com.apple.AppContainer (4.0 - 307.30.3) <EF4C3C83-6F51-38F7-A3D2-2D46EE4560EB> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
   0x7fffa3267000 -     0x7fffa3274ff3 com.apple.AppSandbox (4.0 - 307.30.3) <D2C978EB-F4F1-3E79-9DB1-BEE2A92590CE> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
   0x7fffa3275000 -     0x7fffa3297ffb com.apple.framework.Apple80211 (12.0 - 1200.41) <360012DB-DAE7-3EEF-85F0-E5BE1DE3425D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
   0x7fffa3298000 -     0x7fffa32a7fdb com.apple.AppleFSCompression (88 - 1.0) <B6E2148F-BFBF-3F1B-A7DF-0F39190B4C20> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
   0x7fffa3394000 -     0x7fffa341f97f com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
   0x7fffa344f000 -     0x7fffa3457ffb com.apple.AppleSRP (5.0 - 1) <F105D2D2-8A12-3361-9C9D-E405668CAF75> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
   0x7fffa345c000 -     0x7fffa34aefff com.apple.AppleVAFramework (5.0.34 - 5.0.34) <2AA15DE0-9A7E-3CC0-988A-3BB080A8F603> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
   0x7fffa3844000 -     0x7fffa38c2fff com.apple.backup.framework (1.8.3 - 1.8.3) <B2E28A7A-1727-3052-AA73-CBC108286C07> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
   0x7fffa38eb000 -     0x7fffa3928ff7 com.apple.bom (14.0 - 193.8) <FAA5CE82-0A87-34C5-A606-81A179009930> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
   0x7fffa4548000 -     0x7fffa456fffb com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
   0x7fffa4e98000 -     0x7fffa4ea1ffb com.apple.CommonAuth (4.0 - 2.0) <830B940B-3523-38DE-996D-695739616D10> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
   0x7fffa5025000 -     0x7fffa5402fe7 com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
   0x7fffa5403000 -     0x7fffa5433fff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
   0x7fffa54a9000 -     0x7fffa54b1ffb com.apple.frameworks.CoreDaemon (1.3 - 1.3) <212D3DB2-DC44-329F-B810-238DF156D1EE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
   0x7fffa55c1000 -     0x7fffa55d1fff com.apple.CoreEmoji (1.0 - 39.1) <0A46D6BF-22F3-39AD-B3DC-DE1EE5C442CC> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
   0x7fffa58b4000 -     0x7fffa58e4ff3 com.apple.CoreServicesInternal (276.2 - 276.2) <7D8DEF04-72F1-39F4-BBFB-09E65D7B8C10> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
   0x7fffa5b74000 -     0x7fffa5bfefff com.apple.CoreSymbolication (61050) <F4B7C798-F7B7-3977-AA08-59A03F00308E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
   0x7fffa5bff000 -     0x7fffa5d3dfd7 com.apple.coreui (2.1 - 430.6) <99D08D71-3E9D-300C-9EB2-A73F1B5E228C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
   0x7fffa5d3e000 -     0x7fffa5deeff3 com.apple.CoreUtils (5.0 - 500.9) <5567181B-721C-339E-A3DC-579E36D92341> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
   0x7fffa5e3e000 -     0x7fffa5ea3ff3 com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <BEFA276C-D284-3160-8641-7DD47E38C9D7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
   0x7fffa5ea4000 -     0x7fffa5eb1ff7 com.apple.CrashReporterSupport (10.12 - 817) <CB5251B1-5BE5-308B-B30B-0050065E04CC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
   0x7fffa5f23000 -     0x7fffa5f2dff7 com.apple.framework.DFRFoundation (1.0 - 104.14) <258B6CFE-FD64-31C5-9973-2FD80597ECDA> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
   0x7fffa5f63000 -     0x7fffa5fdaff7 com.apple.datadetectorscore (7.0 - 539.1) <E9892E38-3D5F-36CF-BDC5-E4E3C5516B55> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
   0x7fffa6017000 -     0x7fffa6056fff com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
   0x7fffa6057000 -     0x7fffa6168fff com.apple.desktopservices (1.11.3 - 1.11.3) <CCE689AA-85F3-3587-AE12-1231E8ED127E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
   0x7fffa616d000 -     0x7fffa6243ff7 com.apple.DiskImagesFramework (444.41.1 - 444.41.1) <DEE2D0A1-D1E6-333F-AF76-DEEA48426760> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
   0x7fffa62f7000 -     0x7fffa62f9ffb com.apple.EFILogin (2.0 - 2) <E03C6225-7650-3498-906B-C248A93F55B5> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
   0x7fffa644c000 -     0x7fffa687dff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
   0x7fffa6c7d000 -     0x7fffa7bd1fa7 libLLVMContainer.dylib (12) <0035C17F-EC2C-33F4-8FB8-DBCF8CA35C49> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/A/Libraries/libLLVMContainer.dylib
   0x7fffa7bd2000 -     0x7fffa7bd2fff libmetal_timestamp.dylib (600.0.48.32) <31DF1B9E-0BBF-308B-B78D-11CCE72DAA68> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
   0x7fffa7bdf000 -     0x7fffa7beaff3 libGPUSupportMercury.dylib (13.0.10) <7CC5CEF8-D132-3234-A078-6D080DFC599F> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
   0x7fffa7e9e000 -     0x7fffa7ebaff3 com.apple.GenerationalStorage (2.0 - 259.2) <00BF8427-967F-3693-A86F-DA0F29B49BF3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
   0x7fffa85b8000 -     0x7fffa862efff com.apple.Heimdal (4.0 - 2.0) <00F00E7E-7EF4-3254-86D3-ADA4F67938CF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
   0x7fffa8c51000 -     0x7fffa8c58ffb com.apple.IOAccelerator (289.32 - 289.32) <6395ACEE-5AD7-3536-AF12-FD6565415D94> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
   0x7fffa8c5a000 -     0x7fffa8c6eff3 com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
   0x7fffa8c6f000 -     0x7fffa8c91fff com.apple.IconServices (74.3 - 74.3) <3F0BD358-D019-3083-82F2-69CCAD5E5D66> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
   0x7fffa8d2d000 -     0x7fffa8d3dff3 com.apple.IntlPreferences (2.0 - 216) <589A5D92-6809-3F3C-900E-DBC60A07A101> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
   0x7fffa8d74000 -     0x7fffa8f2afff com.apple.LanguageModeling (1.0 - 123.2.4) <FEB98F96-A9BB-3E6C-85B4-B466825B8C92> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
   0x7fffa9584000 -     0x7fffa9587fff com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
   0x7fffa965f000 -     0x7fffa9693ff3 com.apple.MediaKit (16 - 840) <2035FF47-C7E6-3F73-A335-AC0BFBB1DB36> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
   0x7fffa97ee000 -     0x7fffa9867ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <6A759DBA-B7DF-363B-9827-AB1D1129BB34> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
   0x7fffa9879000 -     0x7fffa99ccfc7 com.apple.mobiledevice (905.1.2.3.1 - 905.1.2.3.1) <0BC2BDA7-BC9A-3535-9F7A-368E0AA1994B> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
   0x7fffa99e9000 -     0x7fffa9a11fff com.apple.MultitouchSupport.framework (368.7 - 368.7) <A29E6031-E9A6-353A-BDE5-D8DF20FD393C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
   0x7fffa9ac0000 -     0x7fffa9acafff com.apple.NetAuth (6.0 - 6.0) <1E7765FC-4580-3CE4-A0F1-CAA22006AE43> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
   0x7fffaa346000 -     0x7fffaa387ff7 com.apple.PerformanceAnalysis (1.145 - 145) <12640C1F-433D-3CD9-B2A8-048D57B8B56D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
   0x7fffaa9fe000 -     0x7fffaaa29ffb com.apple.ProtectedCloudStorage (1.0 - 1) <4B38E6F6-AD64-3345-B51D-38E9DD518666> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
   0x7fffaaa2a000 -     0x7fffaaa44fff com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
   0x7fffaaa5e000 -     0x7fffaaa81ff3 com.apple.RemoteViewServices (2.0 - 124) <4765DC2E-CF05-38CF-9564-1FBACB7E167C> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
   0x7fffab6ed000 -     0x7fffab6f0fff com.apple.SecCodeWrapper (4.0 - 307.30.3) <1B0B2122-C230-3E3F-8A81-EBD58818586B> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
   0x7fffab77f000 -     0x7fffab7fcff7 com.apple.Sharing (696.1.22 - 696.1.22) <D0A5C682-8996-3851-B332-AD05301E6FA3> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
   0x7fffab81d000 -     0x7fffaba8bfff com.apple.SkyLight (1.600.0 - 122.8) <C65A18FE-3021-38F2-9AA1-9527B0ADD4A2> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
   0x7fffabc6c000 -     0x7fffabc78ff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <F9F0FCED-3A72-3639-91F2-B7EF248ED1B9> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
   0x7fffac361000 -    0x7fffac3cdff3 com.apple.Symbolication (61080.2) <27A57DC2-FEB7-3D23-AEB5-E3E76C5AAE79> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
   0x7fffac7c7000 -     0x7fffac7cdff7 com.apple.TCC (1.0 - 1) <956F7C1A-D457-3FE0-9CFE-3F1719F0865C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
   0x7fffac85c000 -     0x7fffaca24ff7 com.apple.TextureIO (1.41 - 1.41) <3A9D9FD9-8997-3BD1-8046-76D0BF709806> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
   0x7fffaca98000 -     0x7fffaca99fff com.apple.TrustEvaluationAgent (2.0 - 28) <07C1F711-A1E0-3BAC-8F4D-977516D50925> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
   0x7fffaca9a000 -     0x7fffacc2aff3 com.apple.UIFoundation (1.0 - 490.7) <047781ED-9E79-361F-8E04-71FF90C650F3> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
   0x7fffad686000 -     0x7fffad749ff7 com.apple.ViewBridge (280 - 280) <6D4F6019-5ECC-377B-AF7D-9796E96841CB> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
   0x7fffadb73000 -     0x7fffadb79fff com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
   0x7fffadc4a000 -     0x7fffadc4cffb com.apple.loginsupport (1.0 - 1) <4449ACBA-27A8-3311-BD92-CB7E63583FC6> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
   0x7fffadca1000 -     0x7fffadcbcff7 libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
   0x7fffadcbd000 -     0x7fffadcc8fff libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
   0x7fffadcc9000 -     0x7fffadd59ff7 libCoreStorage.dylib (540.30.1) <127A0A91-4E62-39A7-B18F-A3E166304505> /usr/lib/libCoreStorage.dylib
   0x7fffadd5a000 -     0x7fffadd5bff3 libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
   0x7fffadd5c000 -     0x7fffadf6ffff libFosl_dynamic.dylib (16.38) <8232FA8A-F16A-3DC0-AE68-B61EFCD5F4A4> /usr/lib/libFosl_dynamic.dylib
   0x7fffadf8b000 -   0x7fffadf92fff libMatch.1.dylib (27) <5D52A207-E2AF-3E05-8C51-91C1D82FCEE8> /usr/lib/libMatch.1.dylib
   0x7fffadf93000 -     0x7fffadf93fff libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
   0x7fffadf94000 -     0x7fffadf98ff3 libScreenReader.dylib (477.20.6) <8158E263-B7DF-3B0C-BABE-4FE94A53DFE5> /usr/lib/libScreenReader.dylib
   0x7fffadf99000 -     0x7fffadf9aff3 libSystem.B.dylib (1238) <9CB018AF-54E9-300F-82BE-81FE553C9154> /usr/lib/libSystem.B.dylib
   0x7fffae006000 -     0x7fffae031ffb libarchive.2.dylib (41.41.1) <D53F0A5C-7FAA-3FCF-8A27-B7DF032C4221> /usr/lib/libarchive.2.dylib
   0x7fffae032000 -     0x7fffae127fef libate.dylib (1.12.13) <DD046A96-07D9-3066-8BD6-D0E27FE9E1D3> /usr/lib/libate.dylib
   0x7fffae12b000 -     0x7fffae12bff3 libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
   0x7fffae12c000 -     0x7fffae13cff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
   0x7fffae13d000 -     0x7fffae14bff7 libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
   0x7fffae14c000 -     0x7fffae1a2ff7 libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
   0x7fffae1a3000 -     0x7fffae1cdfff libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
   0x7fffae1ce000 -     0x7fffae1deffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
   0x7fffae1df000 -     0x7fffae1f4ffb libcompression.dylib (34) <AEF908E6-C0FE-3884-BD45-FB37A035545D> /usr/lib/libcompression.dylib
   0x7fffae1f5000 -     0x7fffae1f5ff7 libcoretls.dylib (121.31.1) <BCC32537-4831-3E9F-876E-8C9F4CF52FD3> /usr/lib/libcoretls.dylib
   0x7fffae1f6000 -     0x7fffae1f7ff3 libcoretls_cfhelpers.dylib (121.31.1) <6F37C5AD-7999-3D31-A52F-7AEED935F32D> /usr/lib/libcoretls_cfhelpers.dylib
   0x7fffae2b1000 -     0x7fffae396ff7 libcrypto.0.9.8.dylib (64.30.2) <D41E1901-06DD-3860-BB4F-B3ACE0284C01> /usr/lib/libcrypto.0.9.8.dylib
   0x7fffae528000 -     0x7fffae533fff libcsfde.dylib (540.30.1) <8E7FAE94-37E0-3181-B2C4-9878FFF63851> /usr/lib/libcsfde.dylib
   0x7fffae534000 -     0x7fffae587ff7 libcups.2.dylib (450) <78243BA4-43AB-3364-8111-8D54D3382621> /usr/lib/libcups.2.dylib
   0x7fffae588000 -     0x7fffae5d8ffb libcurl.4.dylib (95.31.1) <F078ABAE-B13D-3436-A3B8-0B3DFFCF090F> /usr/lib/libcurl.4.dylib
   0x7fffae5d9000 -     0x7fffae5e0ff3 libdscsym.dylib (145.1) <E121E3BC-D2B7-37C3-86A8-5DFC3ECF94D6> /usr/lib/libdscsym.dylib
   0x7fffae602000 -     0x7fffae602fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
   0x7fffae610000 -     0x7fffae611fff libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
   0x7fffae612000 -     0x7fffae617ff7 libheimdal-asn1.dylib (498.30.1) <4ED9F6E3-83BC-3302-B004-C25399DA0333> /usr/lib/libheimdal-asn1.dylib
   0x7fffae618000 -     0x7fffae70aff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
   0x7fffae70b000 -     0x7fffae930ffb libicucore.A.dylib (57149.0.1) <6B5FDA93-AA88-318F-9608-C2A33D602EC7> /usr/lib/libicucore.A.dylib
   0x7fffae936000 -     0x7fffae937fff liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
   0x7fffae938000 -     0x7fffae951ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
   0x7fffae952000 -     0x7fffae968ff7 libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
   0x7fffae969000 -     0x7fffaec10ff7 libmecabra.dylib (744.5) <EF046855-CB9C-32D8-B2F1-C85B526E386F> /usr/lib/libmecabra.dylib
   0x7fffaec43000 -     0x7fffaecbcff7 libnetwork.dylib (856.30.16) <66C6E4D6-B39C-3309-80C1-CBBE170DDD51> /usr/lib/libnetwork.dylib
   0x7fffaecbd000 -     0x7fffaf092127 libobjc.A.dylib (706) <47104A1B-13E8-369F-BC36-27FF465809FD> /usr/lib/libobjc.A.dylib
   0x7fffaf095000 -     0x7fffaf099fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
   0x7fffaf09a000 -     0x7fffaf0caff7 libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
   0x7fffaf0e8000 -     0x7fffaf104ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
   0x7fffaf105000 -     0x7fffaf13efff libsandbox.1.dylib (592.31.1) <0B3D5690-EF2C-39A6-B63C-CFB8CBAC0956> /usr/lib/libsandbox.1.dylib
   0x7fffaf13f000 -     0x7fffaf151ffb libsasl2.2.dylib (209) <5A177BA8-362D-32DA-8D14-69AB191648B3> /usr/lib/libsasl2.2.dylib
   0x7fffaf152000 -     0x7fffaf153ff3 libspindump.dylib (230.3) <59FAC445-F8FB-3881-A69A-FD0E98100E19> /usr/lib/libspindump.dylib
   0x7fffaf154000 -     0x7fffaf295fff libsqlite3.dylib (253) <AECBC92F-FF00-3369-8ECB-AE053B3578B8> /usr/lib/libsqlite3.dylib
   0x7fffaf2b8000 -     0x7fffaf2f0ff3 libssl.0.9.8.dylib (64.30.2) <6E690FB1-A581-3027-93B3-060D9D497A27> /usr/lib/libssl.0.9.8.dylib
   0x7fffaf2f1000 -     0x7fffaf341fff libstdc++.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc++.6.dylib
   0x7fffaf386000 -     0x7fffaf389ff7 libutil.dylib (47.30.1) <C29FFC2C-C7F0-39EA-9215-F5A2DCAF570A> /usr/lib/libutil.dylib
   0x7fffaf38a000 -     0x7fffaf397fff libxar.1.dylib (357) <58BFB84B-66FE-3299-AA3D-BBA178ADEE39> /usr/lib/libxar.1.dylib
   0x7fffaf39b000 -     0x7fffaf48affb libxml2.2.dylib (30.11) <E12AF929-0FA5-3214-840F-C81E6AC9F36E> /usr/lib/libxml2.2.dylib
   0x7fffaf48b000 -     0x7fffaf4b4fff libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
   0x7fffaf4b5000 -     0x7fffaf4c6ff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
   0x7fffaf4d5000 -     0x7fffaf4d9ff7 libcache.dylib (79) <0C8092D3-600F-3ADD-A036-F225B6CDCA43> /usr/lib/system/libcache.dylib
   0x7fffaf4da000 -     0x7fffaf4e5ff7 libcommonCrypto.dylib (60092.30.2) <B16E29B6-EC8D-3A8F-9A89-DD9CF35F7C4B> /usr/lib/system/libcommonCrypto.dylib
   0x7fffaf4e6000 -     0x7fffaf4edfff libcompiler_rt.dylib (62) <E992E8D9-037C-3454-A366-A25E4D31D6BB> /usr/lib/system/libcompiler_rt.dylib
   0x7fffaf4ee000 -     0x7fffaf4f6fff libcopyfile.dylib (138) <64E285D9-5485-333B-AEE7-8B0C8FB9275F> /usr/lib/system/libcopyfile.dylib
   0x7fffaf4f7000 -     0x7fffaf57afdf libcorecrypto.dylib (442.30.20) <2074B932-FD79-30A9-8E90-AF25C49F2AF1> /usr/lib/system/libcorecrypto.dylib
   0x7fffaf57b000 -     0x7fffaf5adfff libdispatch.dylib (703.30.5) <EA0CC14E-D559-3802-B4B2-0E8C7579AAC4> /usr/lib/system/libdispatch.dylib
   0x7fffaf5ae000 -     0x7fffaf5b3ff3 libdyld.dylib (421.2) <6F506653-FFF6-3DB8-84F1-109AE3C52F32> /usr/lib/system/libdyld.dylib
   0x7fffaf5b4000 -     0x7fffaf5b4ffb libkeymgr.dylib (28) <1A318923-1200-3B06-B432-5007D82F195D> /usr/lib/system/libkeymgr.dylib
   0x7fffaf5b5000 -     0x7fffaf5c1ffb libkxld.dylib (3789.41.3) <87550136-9353-348B-9CD9-C342B48C5AAF> /usr/lib/system/libkxld.dylib
   0x7fffaf5c2000 -     0x7fffaf5c2fff liblaunch.dylib (972.30.7) <15FACC21-079A-3BDF-9AFB-4253EFDEB587> /usr/lib/system/liblaunch.dylib
   0x7fffaf5c3000 -     0x7fffaf5c8fff libmacho.dylib (894) <A2F38EC1-C37C-3B93-B0E4-36B07C177F8C> /usr/lib/system/libmacho.dylib
   0x7fffaf5c9000 -     0x7fffaf5cbff3 libquarantine.dylib (85) <C1D7749F-5F5F-3BB9-BEFC-1F0B9DA941FD> /usr/lib/system/libquarantine.dylib
   0x7fffaf5cc000 -     0x7fffaf5cdffb libremovefile.dylib (45) <CD42974E-BE0B-39FC-9BFC-8A7540A04DC6> /usr/lib/system/libremovefile.dylib
   0x7fffaf5ce000 -     0x7fffaf5e6ff7 libsystem_asl.dylib (349.30.2) <EFAC72D7-CB13-3DF7-ADF3-EC6635C6F1EA> /usr/lib/system/libsystem_asl.dylib
   0x7fffaf5e7000 -     0x7fffaf5e7ff7 libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
   0x7fffaf5e8000 -     0x7fffaf675fef libsystem_c.dylib (1158.30.7) <2F881962-03CB-3B9D-A782-D98C1BBA4E3D> /usr/lib/system/libsystem_c.dylib
   0x7fffaf676000 -     0x7fffaf679ffb libsystem_configuration.dylib (888.30.2) <4FE3983C-E4ED-3939-A578-03AD29C99788> /usr/lib/system/libsystem_configuration.dylib
   0x7fffaf67a000 -     0x7fffaf67dfff libsystem_coreservices.dylib (41.4) <1A572B9E-0C47-320F-8C64-7990D0A5FB5A> /usr/lib/system/libsystem_coreservices.dylib
   0x7fffaf67e000 -     0x7fffaf696ff3 libsystem_coretls.dylib (121.31.1) <4676F06D-274D-31BE-B61C-4D7A4AEF4858> /usr/lib/system/libsystem_coretls.dylib
   0x7fffaf697000 -     0x7fffaf69dfff libsystem_dnssd.dylib (765.30.11) <DC708D84-ED7D-3936-B996-A67C66B8DDAA> /usr/lib/system/libsystem_dnssd.dylib
   0x7fffaf69e000 -     0x7fffaf6c7ff7 libsystem_info.dylib (503.30.1) <9ED9121C-F111-3FAD-BC2F-C95DEE1C9362> /usr/lib/system/libsystem_info.dylib
   0x7fffaf6c8000 -     0x7fffaf6eaff7 libsystem_kernel.dylib (3789.41.3) <B75B128C-7D7A-3318-91CD-82B5A69C5329> /usr/lib/system/libsystem_kernel.dylib
   0x7fffaf6eb000 -     0x7fffaf732fe7 libsystem_m.dylib (3121.4) <266DB92B-A86F-3691-80FB-1B26AD73CFF3> /usr/lib/system/libsystem_m.dylib
   0x7fffaf733000 -     0x7fffaf751ff7 libsystem_malloc.dylib (116.30.3) <F40DEE3B-386A-3529-A3F7-98117ED55BF4> /usr/lib/system/libsystem_malloc.dylib
   0x7fffaf752000 -     0x7fffaf7a9ffb libsystem_network.dylib (856.30.16) <4AE368E9-605D-379D-B04C-2AC7455B8250> /usr/lib/system/libsystem_network.dylib
   0x7fffaf7aa000 -     0x7fffaf7b3ff3 libsystem_networkextension.dylib (563.30.15) <EB020B0C-7DF0-3EEF-8E3C-15DA3C01D687> /usr/lib/system/libsystem_networkextension.dylib
   0x7fffaf7b4000 -     0x7fffaf7bdff3 libsystem_notify.dylib (165.20.1) <E7FD3A7C-DD07-36E2-9FA4-7561F9F114DA> /usr/lib/system/libsystem_notify.dylib
   0x7fffaf7be000 -     0x7fffaf7c6fe7 libsystem_platform.dylib (126.1.2) <3CA06D4E-C00A-36DE-AA65-3A390097D1F6> /usr/lib/system/libsystem_platform.dylib
   0x7fffaf7c7000 -     0x7fffaf7d1ff7 libsystem_pthread.dylib (218.30.1) <C869ED7C-BE29-3532-8E69-3A8DA1447EDC> /usr/lib/system/libsystem_pthread.dylib
   0x7fffaf7d2000 -     0x7fffaf7d5ff7 libsystem_sandbox.dylib (592.31.1) <7BBFDF96-293F-3DD9-B3A4-7C168280B441> /usr/lib/system/libsystem_sandbox.dylib
   0x7fffaf7d6000 -     0x7fffaf7d7fff libsystem_secinit.dylib (24) <5C1F1E47-0F7D-3E25-8DEB-D9DB1F902281> /usr/lib/system/libsystem_secinit.dylib
   0x7fffaf7d8000 -     0x7fffaf7dffff libsystem_symptoms.dylib (532.30.6) <5D990CF5-B58F-39F7-B375-99B4EC62CFBD> /usr/lib/system/libsystem_symptoms.dylib
   0x7fffaf7e0000 -     0x7fffaf800ff7 libsystem_trace.dylib (518.30.7) <6D34D1EA-2A3C-3D2D-803E-A666E6AEEE52> /usr/lib/system/libsystem_trace.dylib
   0x7fffaf801000 -     0x7fffaf806ffb libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
   0x7fffaf807000 -     0x7fffaf830ff7 libxpc.dylib (972.30.7) <65E41BB6-EBD5-3D93-B0BE-B190CEE4DD93> /usr/lib/system/libxpc.dylib
   task_for_pid: 1
   thread_create: 0
   thread_set_state: 0
   task_for_pid: 0
   thread_create: 0
   thread_set_state: 0
   task_for_pid: 347
   thread_create: 0
   thread_set_state: 0
VM Region Summary:
Writable regions: Total=1.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.0G(100%)
                               VIRTUAL   REGION
CG image                         1404K       11
CoreAnimation                       28K        4
IOKit                             7940K       2
Image IO                         1036K       4
MALLOC                           481.7M     124
OpenGL GLSL                       256K       4
Stack                             16.5M     364
Stack Guard                         4K       2
VM_ALLOCATE                     502.6M     257
__DATA                           37.3M     272
__IMAGE                           528K       2
__TEXT                           207.9M     270
__UNICODE                         556K       2
mapped file                       43.4M       12
shared memory                     16.4M       13
TOTAL                             1.5G     1388
TOTAL, minus reserved VM space     1.5G     1388
USB Device: Hub
USB Device: Hub
USB Device: Hub
This is probably the NVIDIA/Apple crash (you should have received a pop-up in game notifying you about this as a possibility prior to riding). See this article for more information, and a link to the newer drivers.
