Go ahead - This is from the last crash
Process: ZwiftApp [16569]
Path: /Users/USER/Library/Application Support/Zwift/ZwiftApp
Identifier: ZwiftApp
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: ZwiftApp [16569]
User ID: 501
Date/Time: 2016-10-16 10:12:47.889 +0200
OS Version: Mac OS X 10.12 (16A323)
Report Version: 12
Anonymous UUID: 5F248D54-669B-E5EB-892E-F83373E7E99F
Sleep/Wake UUID: A403A72C-50C2-43A9-9BAD-CA18C0EA4C09
Time Awake Since Boot: 360000 seconds
Time Since Wake: 8300 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x00007fff98136b92 strlen + 18
1 ZwiftApp 0x00000001097d095f CFont2D::RenderParagraph(float, float, float, float, char const*, unsigned int, int, float, bool, float, float) + 159
2 ZwiftApp 0x00000001097d1f2f GUI_DropDownBox::Render() + 335
3 ZwiftApp 0x00000001097d3479 GUI_Render() + 169
4 ZwiftApp 0x0000000109469460 RenderUIPass(float) + 1152
5 ZwiftApp 0x000000010946ab59 Render(float) + 5321
6 ZwiftApp 0x000000010946b044 doFrame() + 804
7 ZwiftApp 0x0000000109478c75 CODEmain(int, char const**) + 85
8 ZwiftApp 0x000000010944a9f3 main + 595
9 ZwiftApp 0x00000001093148b4 start + 52
Thread 1:
0 libsystem_kernel.dylib 0x00007fff9822efde __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff981b5b92 nanosleep + 199
2 ZwiftApp 0x00000001097e9a23 JM_Worker_Thread(void*) + 307
3 libsystem_pthread.dylib 0x00007fff98316abb _pthread_body + 180
4 libsystem_pthread.dylib 0x00007fff98316a07 _pthread_start + 286
5 libsystem_pthread.dylib 0x00007fff98316231 thread_start + 13
Thread 2:
0 libsystem_kernel.dylib 0x00007fff9822ec8a __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff9831797a _pthread_cond_wait + 712
2 ZwiftApp 0x000000010989ed8b AK::StreamMgr::CAkIOThread::IOSchedThread(void*) + 75
Thread 3:
0 libsystem_kernel.dylib 0x00007fff98227456 semaphore_wait_trap + 10
1 ZwiftApp 0x0000000109873cd3 CAkThreadedBankMgr::BankThreadFunc(void*) + 51
2 libsystem_pthread.dylib 0x00007fff98316abb _pthread_body + 180
3 libsystem_pthread.dylib 0x00007fff98316a07 _pthread_start + 286
4 libsystem_pthread.dylib 0x00007fff98316231 thread_start + 13
Thread 4:
1 ZwiftApp 0x000000010987867f CAkAudioThread::EventMgrThreadFunc(void*) + 63
Thread 5:: com.apple.audio.IOThread.client
0 libsystem_platform.dylib 0x00007fff98310ca3 _platform_bzero$VARIANT$Base + 51
1 com.apple.audio.CoreAudio 0x00007fff82bbc068 CAAudioBufferList::Clear(AudioBufferList&) + 48
2 com.apple.audio.CoreAudio 0x00007fff82bb9396 HALC_ProxyIOContext::IOWorkLoop() + 2902
3 com.apple.audio.CoreAudio 0x00007fff82bb8667 HALC_ProxyIOContext::IOThreadEntry(void*) + 131
4 com.apple.audio.CoreAudio 0x00007fff82bb838b HALB_IOThread::Entry(void*) + 75
5 libsystem_pthread.dylib 0x00007fff98316abb _pthread_body + 180
6 libsystem_pthread.dylib 0x00007fff98316a07 _pthread_start + 286
7 libsystem_pthread.dylib 0x00007fff98316231 thread_start + 13
Thread 6:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff9822741a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff98226867 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff8302fba4 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff8302f021 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fff8302e874 CFRunLoopRunSpecific + 420
5 com.apple.AppKit 0x00007fff80e11e9e _NSEventThread + 205
6 libsystem_pthread.dylib 0x00007fff98316abb _pthread_body + 180
7 libsystem_pthread.dylib 0x00007fff98316a07 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007fff98316231 thread_start + 13
Thread 7:
0 libsystem_kernel.dylib 0x00007fff9822fe2e kevent + 10
1 ZwiftApp 0x00000001096856c1 asio::detail::kqueue_reactor::run(bool, asio::detail::op_queue<asio::detail::task_io_service_operation>&) + 265
2 ZwiftApp 0x00000001096853f5 asio::detail::task_io_service::do_run_one(asio::detail::scoped_lock<asio::detail::posix_mutex>&, asio::detail::task_io_service_thread_info&, std::__1::error_code const&) + 267
3 ZwiftApp 0x00000001096850de asio::detail::task_io_service::run(std::__1::error_code&) + 416
4 ZwiftApp 0x00000001095f8337 asio::io_service::run() + 43
5 ZwiftApp 0x0000000109689b9c asio_detail_posix_thread_function + 19
Thread 8:
0 libsystem_kernel.dylib 0x00007fff9822f4e6 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff983167c5 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fff98316221 start_wqthread + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0xdabb7fd26a6a00d6 rbx: 0x0000000000000000 rcx: 0x696b702e0000007f rdx: 0x696b702e0000007f
rdi: 0x696b702e00000070 rsi: 0x696b702e0000007f rbp: 0x00007fff568ea790 rsp: 0x00007fff568ea790
r8: 0x0000000000000000 r9: 0x00007fa20682a800 r10: 0x00007fff9e12afa0 r11: 0x0000000100000000
r12: 0xdabb7fd26a6a00d6 r13: 0x696b702e0000007f r14: 0x0000000000000000 r15: 0x0000000109ba5bb0
rip: 0x00007fff98136b92 rfl: 0x0000000000010202 cr2: 0xffffff8034699000
Logical CPU: 2
Error Code: 0x00000000
Trap Number: 13
Binary Images:
0x109313000 - 0x109ac3fef +ZwiftApp (???) <DE3E0B6C-3CE4-39C2-8D67-E408808B91F0> /Users/USER/Library/Application Support/Zwift/ZwiftApp
0x10a138000 - 0x10a194ff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <E643EFD6-0D3A-3718-84F1-EECAED9A4FA2> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x10a1de000 - 0x10a1fbfff +libant.dylib (0) <69DB8DF7-7E3F-33EE-9472-45DD36CFD413> /Users/USER/Library/Application Support/Zwift/libant.dylib
0x10a228000 - 0x10a267ffb com.apple.glut (3.6.8 - GLUT-3.6.8) <1AC0AF69-CF2F-3325-A3C4-905E31360E29> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x10a2e3000 - 0x10a321fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <81393A2D-184B-3847-802A-B8BCF6D1080C> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10a34b000 - 0x10a477ff7 com.apple.AudioVideoBridging (500.19 - 500.19) <EC8F48BF-9B29-39DE-95B5-71324C081497> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x10a532000 - 0x10a54bffb libexpat.1.dylib (15) <617B8B7A-A0AB-37D6-AFCA-F90F7F14E455> /usr/lib/libexpat.1.dylib
0x10a55c000 - 0x10a570ff3 com.apple.AudioServerApplication (1.0 - 200.9) <F3A5C381-B7D2-3BE1-AB30-3426922C3938> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
0x10a587000 - 0x10a596fff com.apple.TimeSync (1.0 - 500.27) <962394AB-8359-31B4-8671-AAF2C535A8E8> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x10a7cf000 - 0x10a7d3fff com.apple.audio.AppleHDAHALPlugIn (276.26 - 276.26) <E792FB29-7228-39E4-AA4E-9739F3E54800> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x110059000 - 0x1101c1fff com.apple.audio.units.Components (1.14 - 1.14) <695D3410-4177-3CC3-A419-1127ECC911C4> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x11344e000 - 0x11373dff7 com.apple.driver.AppleIntelHD3000GraphicsGLDriver (10.2.8 - 10.0.2) <D392C817-C01A-33BC-8599-9A0917CA5120> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsGLDriver
0x11390a000 - 0x1139c4ff7 com.apple.AMDRadeonX3000GLDriver (1.44.68 - 1.4.4) <AE0C43E4-7246-3B1A-9DCE-52B1922F3E71> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLDriver
0x1139eb000 - 0x113bf1ffb ATIRadeonX3000SCLib.dylib (1.44.68) <A752E028-1EBA-3913-81C8-E8E8089A890A> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000SCLib.dylib
0x116486000 - 0x1164c31c7 dyld (421.1) <A525EAEA-AF86-30C2-B360-3D093B4F0828> /usr/lib/dyld
0x7fff7dcf9000 - 0x7fff7e031fff com.apple.RawCamera.bundle (7.00 - 874) <99AF1865-BCDD-3313-85BF-E246745201F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff7f84e000 - 0x7fff7fa0cfff com.apple.avfoundation (2.0 - 1183.3) <E6DCAB50-ECD4-3645-8A93-D14F14092DC4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff7fa0d000 - 0x7fff7fab0ff7 com.apple.audio.AVFAudio (1.0 - ???) <18E472FC-5AD7-33B8-8D46-49D5AC2DB13A> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff7fb43000 - 0x7fff7fb43fff com.apple.Accelerate (1.11 - Accelerate 1.11) <BDDB2053-BB24-34E4-A452-50D1260BF672> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff7fb44000 - 0x7fff7fb5bff3 libCGInterfaces.dylib (331.4) <2CD05A85-79AC-3C67-9ABE-00294CE1C82B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff7fb5c000 - 0x7fff8019cfe3 com.apple.vImage (8.1 - ???) <6CC22156-EC5C-3DC3-8132-41376F090B08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff8019d000 - 0x7fff80364fef libBLAS.dylib (1185) <0D55CF73-6DBD-3D15-B500-189479638551> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff80365000 - 0x7fff8037cfff libBNNS.dylib (14) <43A9B06E-3C21-3CE6-B0C1-99DA172DEEB0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff8037d000 - 0x7fff80788fff libLAPACK.dylib (1185) <E7AE9C48-6E42-3EB7-A257-D48E0CB48D00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff80789000 - 0x7fff8079ffff libLinearAlgebra.dylib (1185) <08F00EFB-B477-3421-906E-3D364E607E6A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff807a0000 - 0x7fff807a6fff libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff807a7000 - 0x7fff807baff7 libSparseBLAS.dylib (1185) <912E3D25-27C0-3245-B64C-3CAD43A5D633> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff807bb000 - 0x7fff80908ff7 libvDSP.dylib (600) <87EF1D0A-1F85-31DD-AD8F-AB31E7D8E73B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff80909000 - 0x7fff809c0fff libvMisc.dylib (600) <F6EA539E-0A90-3F8A-9ECA-001E46394E29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff809c1000 - 0x7fff809c1fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <B4B785D8-CB43-3E5D-AE81-1F27885AA112> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff80c7e000 - 0x7fff81955ff3 com.apple.AppKit (6.9 - 1504) <5524F97F-FB11-3556-8AC4-FF634C6CCCB7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff81967000 - 0x7fff81967fff com.apple.ApplicationServices (48 - 48) <3E1395EA-C661-3318-9B87-9857BB81021B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff81968000 - 0x7fff819d6ff7 com.apple.ApplicationServices.ATS (377 - 422) <521E41BF-D495-3233-B6BF-C0B83DD1A8C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff81a70000 - 0x7fff81b9efff libFontParser.dylib (194) <CDC6A0AA-E6AC-315B-AFBF-011F64548911> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff81b9f000 - 0x7fff81be9fff libFontRegistry.dylib (196) <3B8B0E78-2B30-3F18-B7D3-BE4E96F6BAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff81c46000 - 0x7fff81c78fff libTrueTypeScaler.dylib (194) <E8B9E8E7-1F7A-3700-895C-501C12EDD001> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff81ce4000 - 0x7fff81d8eff7 com.apple.ColorSync (4.12.0 - 502) <C86F8032-83DD-34EB-A4CB-87E96F25CF1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff81d8f000 - 0x7fff81ddffff com.apple.HIServices (1.22 - 589) <3167EF9C-F121-39EF-AAE2-7700E7128426> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff81de0000 - 0x7fff81defff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff81df0000 - 0x7fff81e3dfff com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff81e3e000 - 0x7fff81e79fff com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff81e7a000 - 0x7fff81e85ff7 com.apple.speech.synthesis.framework (6.0.15 - 6.0.15) <23EA6076-ECDF-3A50-81E7-3CE6451DC8C4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff81e86000 - 0x7fff82092fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <EDDC86C8-92F3-34C6-A5C1-A176ADA724C3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff82093000 - 0x7fff82093fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <AA9DB0D2-3B2F-3366-B451-DD9E89038F6F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff821fc000 - 0x7fff8257ffff com.apple.CFNetwork (807.0.4 - 807.0.4) <A338A213-4FFF-3317-B4DB-84735C63C507> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff82599000 - 0x7fff82599fff com.apple.Carbon (154 - 157) <AB71A31F-5B15-3BF5-8532-591EACD07B21> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8259a000 - 0x7fff8259dfff com.apple.CommonPanels (1.2.6 - 98) <DDA2DF0B-86E7-34B6-B688-D7371DBC8A63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8259e000 - 0x7fff828a1fff com.apple.HIToolbox (2.1.1 - 855) <AA4E2957-6B2D-3822-881C-0F64222F9578> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff828a2000 - 0x7fff828a5ff7 com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff828a6000 - 0x7fff828abfff com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff828ac000 - 0x7fff82943ff3 com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff82944000 - 0x7fff8295efff com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8295f000 - 0x7fff82960ff3 com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff82961000 - 0x7fff82963ff7 com.apple.securityhi (9.0 - 55006) <856F4FB9-AAF2-3FC2-BE19-E7AB494232CC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff82964000 - 0x7fff8296aff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff82a4a000 - 0x7fff82a4afff com.apple.Cocoa (6.11 - 22) <5EEB0A26-F1C2-3D57-8441-52C0B80C2A6A> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff82b7d000 - 0x7fff82c0dff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <0352D931-596B-3AFE-B5C6-5925CF9F870E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff82c0e000 - 0x7fff82c21ff3 com.apple.CoreBluetooth (1.0 - 1) <73A2B185-70E4-3535-A653-E1BC74584E55> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff82c22000 - 0x7fff82f1cfff com.apple.CoreData (120 - 752.2) <51AB540E-01AE-3207-8DE5-3E912FA9B5DF> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff82f1d000 - 0x7fff82fa9fff com.apple.CoreDisplay (1.0 - 1) <F10E2F1A-FA51-3256-BCCE-34FF30AB1E3A> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff82faa000 - 0x7fff8343dff7 com.apple.CoreFoundation (6.9 - 1348.1) <2A35BE4F-BA5B-3C22-BCF1-CFBBA2786081> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8343e000 - 0x7fff83adeff7 com.apple.CoreGraphics (2.0 - 1070) <765D6A92-48AE-3CBB-9967-61300D715F1F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff83adf000 - 0x7fff83d1eff7 com.apple.CoreImage (12.0.0 - 451) <84C71E9C-5231-342F-94B1-2BB6860E8AD3> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff83d7c000 - 0x7fff83e2cff7 com.apple.CoreMedia (1.0 - 1903.7) <5FE3B4CC-EC1A-38FE-96FA-FFD419229F3E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff83e2d000 - 0x7fff83e78ff7 com.apple.CoreMediaIO (801.0 - 4922) <2813BA18-E24C-3CFB-8B34-73575DFDF0BC> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff83e79000 - 0x7fff83e79fff com.apple.CoreServices (775.8 - 775.8) <C36F7F47-D585-32F2-8A6F-7711935CDFD6> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff83e7a000 - 0x7fff83ecbff7 com.apple.AE (712 - 712) <0EF17D7E-6BA4-3555-BC38-9BD0CC5B82A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff83ecc000 - 0x7fff841a7fff com.apple.CoreServices.CarbonCore (1159 - 1159) <837B7ECF-7E62-3210-988C-63D7AB4EAA88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff841a8000 - 0x7fff841dbfff com.apple.DictionaryServices (1.2 - 274) <302B8678-D057-3CF8-ACA7-7424A4A6A00A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff841dc000 - 0x7fff841e4ffb com.apple.CoreServices.FSEvents (1230 - 1230) <8836E7D0-844F-36F9-9601-B630BB82336B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff841e5000 - 0x7fff84350fff com.apple.LaunchServices (775.8 - 775.8) <6E7CE1DA-27A4-3B48-A8E3-F2AA868ADD7C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff84351000 - 0x7fff84401ffb com.apple.Metadata (10.7.0 - 1075) <9EDF10CF-1755-346A-A3C9-97642C443A58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff84402000 - 0x7fff84461fff com.apple.CoreServices.OSServices (775.8 - 775.8) <FCF1334F-D2D7-3C5A-A8FE-C173C5EDE586> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff84462000 - 0x7fff844d2fff com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff844d3000 - 0x7fff84519ff7 com.apple.coreservices.SharedFileList (38 - 38) <6C5A3FBB-9502-3725-AC3A-AE7B1528BBD4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff845a6000 - 0x7fff846f1ff7 com.apple.CoreText (352.0 - 544) <064B53E8-CD5A-3D1B-81DF-498A659FC20A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff846f2000 - 0x7fff84727fff com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff84728000 - 0x7fff84799ffb com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <F46EF4A2-C348-3F76-A1C2-B8A84C17FE2B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff847d5000 - 0x7fff84893ff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <EA175710-9775-3147-8AF9-7B20D2872723> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff84894000 - 0x7fff84899fff com.apple.DiskArbitration (2.7 - 2.7) <566D5C06-13E8-3638-B2EC-2B834D5F04F1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff84a28000 - 0x7fff84dcfffb com.apple.Foundation (6.9 - 1349) <08A463B1-296E-3AC1-B8D3-01A75B0785A8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff84dfb000 - 0x7fff84e2cff3 com.apple.GSS (4.0 - 2.0) <B30A0B99-AFDE-3BF8-A04F-761A75A6A3B1> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff84ee0000 - 0x7fff84f83ffb com.apple.Bluetooth (5.0.0 - 5.0.0f18) <00417775-D746-32C1-9598-CE8716DFBECD> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff84f84000 - 0x7fff85019fff com.apple.framework.IOKit (2.0.2 - 1324.1.7) <10BDCD1E-0463-3C53-BF11-C9A0919C1588> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8501a000 - 0x7fff85020ffb com.apple.IOSurface (152 - 152) <558D4451-2D9D-3D47-B3A5-E7C18DF53F1B> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff85074000 - 0x7fff851cdff7 com.apple.ImageIO.framework (3.3.0 - 1570.1) <6B0177F3-A7BE-30D7-B075-7117E2C28A5F> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff851ce000 - 0x7fff851d2fff libGIF.dylib (1570.1) <AE06146E-C4B3-3088-B6BC-569DDFCD8D77> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff851d3000 - 0x7fff852c4fff libJP2.dylib (1570.1) <6D268C9D-309B-3098-BBCF-8A1B98DBBEE9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff852c5000 - 0x7fff852e8fff libJPEG.dylib (1570.1) <7EFA7A91-06C8-329E-AA3D-CF6DB2220A5A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff852e9000 - 0x7fff8530ffff libPng.dylib (1570.1) <AF8292B6-2564-30D4-8860-6B0C9D0E1405> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff85310000 - 0x7fff85312ff3 libRadiance.dylib (1570.1) <B0256EB7-7F87-39FD-BD35-83577F4FE7EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff85313000 - 0x7fff8536cfff libTIFF.dylib (1570.1) <F1F0B7C6-388F-35E4-87CF-816CEE8B0E00> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff85f33000 - 0x7fff85f4cff7 com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff85f4d000 - 0x7fff85f83fff com.apple.LDAPFramework (2.4.28 - 194.5) <850BB4C5-2548-33A5-B00C-0600CA59EE59> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff861c6000 - 0x7fff861ccfff com.apple.MediaAccessibility (1.0 - 97.1.1) <EE1825C7-3B58-32F8-9F5F-B7172452BB01> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff861e2000 - 0x7fff8672ffff com.apple.MediaToolbox (1.0 - 1903.7) <37363406-481C-3DDD-A61F-9E2153A3660B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff86730000 - 0x7fff86787ff7 com.apple.Metal (85.82 - 85.82) <CDC847A6-F1F6-3661-8981-180F2A485092> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff86e9d000 - 0x7fff86ea5fff com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff87053000 - 0x7fff87078fff com.apple.audio.OpenAL (1.8 - 1.8) <3867A1C7-1D67-37EE-8DA1-520B75D3B234> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff87079000 - 0x7fff87081ff7 libcldcpuengine.dylib (2.8.4) <F15C17F0-3342-36BD-A28E-7AC44B87BF8C> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff8724a000 - 0x7fff87298ff3 com.apple.opencl (2.8.6 - 2.8.6) <DA3164B7-EB48-3F68-A40F-CD9B433E385F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff87299000 - 0x7fff872b2ffb com.apple.CFOpenDirectory (10.12 - 194) <BDD22B3E-4149-366A-A974-942280861DD4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff872b3000 - 0x7fff872beff7 com.apple.OpenDirectory (10.12 - 194) <E1125140-E42C-369C-8DC8-D0935767B275> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff872bf000 - 0x7fff872c1fff libCVMSPluginSupport.dylib (12.4.2.1) <5A7CBDC5-297E-30E0-8951-2F3DAFD0027E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff872c2000 - 0x7fff872c5ff7 libCoreFSCache.dylib (148) <3297ACE0-B9D8-3821-8685-2619B4234621> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff872c6000 - 0x7fff872c9fff libCoreVMClient.dylib (148) <B4299590-02BA-3130-98EA-A2D3A53852E1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff872ca000 - 0x7fff872d2ffb libGFXShared.dylib (12.4.2.1) <3CBE90E5-6472-3C4C-825D-7567A5652115> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff872d3000 - 0x7fff872defff libGL.dylib (12.4.2.1) <E68C6C85-3B98-3525-9279-3296977FBF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff872df000 - 0x7fff8731bff7 libGLImage.dylib (12.4.2.1) <50C7DE05-73CB-3D21-BB93-31C384EB6199> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff8731c000 - 0x7fff87492ffb libGLProgrammability.dylib (12.4.2.1) <2B17044B-CDB6-38F7-BA1F-9ED1A078481A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff87493000 - 0x7fff874d3ff3 libGLU.dylib (12.4.2.1) <D5DB68EC-751F-34D1-BCEB-2B86D560E243> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff87e3b000 - 0x7fff87e49fff com.apple.opengl (12.4.2 - 12.4.2) <06F5BF0B-BD03-361D-9D7B-626517E4F761> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff87e4a000 - 0x7fff87ff0fff GLEngine (12.4.2.1) <8FFA4B17-F02A-3D7A-ACA9-D156E4E43B4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff87ff1000 - 0x7fff8801bffb GLRendererFloat (12.4.2.1) <82826589-22A1-312C-9C4E-FA45F4D8D976> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff88b5a000 - 0x7fff88d54ff7 com.apple.QuartzCore (1.11 - 449.39) <B6BEEBAC-2923-3BA6-8DBD-621A2B0E51C1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff892a2000 - 0x7fff892b9ff7 com.apple.ScriptingBridge (1.3.3 - 69) <10EDB5EE-C7DD-39FF-840A-CCF41C00F3B6> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff892ba000 - 0x7fff895d5fff com.apple.security (7.0 - 57740.1.18) <AF5E42F1-B513-3410-A5BE-1EC9CBAF8452> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff895d6000 - 0x7fff8964cff7 com.apple.securityfoundation (6.0 - 55132.1.1) <259D4B70-0F8C-3818-99E7-3EBEAA18DE1B> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff89676000 - 0x7fff89679ff3 com.apple.xpc.ServiceManagement (1.0 - 1) <6A9EA339-BB6A-3DD9-BF08-00B8C0262839> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff899fe000 - 0x7fff89a6fff7 com.apple.SystemConfiguration (1.14 - 1.14) <C7F21776-2CCE-327B-B155-7A5948277BD6> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff89a70000 - 0x7fff89e1bff7 com.apple.VideoToolbox (1.0 - 1903.7) <C0044876-9800-3CCA-B7D3-50B92077EF4D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff8b91a000 - 0x7fff8b91fff7 com.apple.APFS (1.0 - 1) <F1BD89DF-D84F-3256-905D-6D72706474CF> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff8c07d000 - 0x7fff8c098ff3 com.apple.AppContainer (4.0 - 307.1.1) <05373DD5-5892-3542-B178-C140F1AB6886> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff8c099000 - 0x7fff8c0a6ff3 com.apple.AppSandbox (4.0 - 307.1.1) <20324EFC-70DC-389D-9C27-37DCAA7E07CC> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff8c0a7000 - 0x7fff8c0c9ffb com.apple.framework.Apple80211 (12.0 - 1200.33) <06F8EA45-5E43-3744-BF41-BA86B8BBB5CF> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8c0ca000 - 0x7fff8c0d9fdb com.apple.AppleFSCompression (88 - 1.0) <B6E2148F-BFBF-3F1B-A7DF-0F39190B4C20> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff8c1c1000 - 0x7fff8c24c97f com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff8c27c000 - 0x7fff8c284ffb com.apple.AppleSRP (5.0 - 1) <F105D2D2-8A12-3361-9C9D-E405668CAF75> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff8c289000 - 0x7fff8c2dbfff com.apple.AppleVAFramework (5.0.34 - 5.0.34) <193400A6-B326-3911-BB4F-6C49C1E5FA8F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff8c668000 - 0x7fff8c6e6ff7 com.apple.backup.framework (1.8 - 1.8) <E2888B63-F43C-367F-B23F-7D9F9BD64401> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff8c6f6000 - 0x7fff8c733ff7 com.apple.bom (14.0 - 193.8) <FAA5CE82-0A87-34C5-A606-81A179009930> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff8d300000 - 0x7fff8d327ffb com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff8dc47000 - 0x7fff8dc50ffb com.apple.CommonAuth (4.0 - 2.0) <D9958C57-9E97-33F5-A21C-B454FDB11548> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff8ddd1000 - 0x7fff8e1aefe7 com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff8e1af000 - 0x7fff8e1dffff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff8e254000 - 0x7fff8e25cffb com.apple.frameworks.CoreDaemon (1.3 - 1.3) <212D3DB2-DC44-329F-B810-238DF156D1EE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff8e36c000 - 0x7fff8e37dfff com.apple.CoreEmoji (1.0 - 40) <F3D73BF8-6D48-3B1F-BBE6-EE927E725E92> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff8e656000 - 0x7fff8e686ff3 com.apple.CoreServicesInternal (276 - 276) <CCB21255-89DC-3F53-A6D6-8FA8F693C837> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff8e90f000 - 0x7fff8e999fff com.apple.CoreSymbolication (61050) <BAC8D20F-4DC6-32EE-91FE-BF08E930420A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff8e99a000 - 0x7fff8ead4fef com.apple.coreui (2.1 - 424.1) <B9B92DB5-1C6C-306F-BD29-B1F82EC95283> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff8ead5000 - 0x7fff8eb74ffb com.apple.CoreUtils (4.3 - 430.70) <87BEB880-3D71-3251-B51E-FF0A42DFC065> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff8ebc4000 - 0x7fff8ec29ff3 com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <D7C870BE-55DE-34AF-8941-D42696D505B1> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff8ec2a000 - 0x7fff8ec35fff com.apple.CrashReporterSupport (10.12 - 815) <10C3797E-DD63-303B-B901-1C52A502D2F8> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8ecdb000 - 0x7fff8ed52ff3 com.apple.datadetectorscore (7.0 - 539) <C3F6F52B-A1AD-36FA-9BF9-C8D0E147F0A3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8ed8c000 - 0x7fff8edcbfff com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8edcc000 - 0x7fff8eeddff7 com.apple.desktopservices (1.11 - 1.11) <494E239D-706F-350B-9481-2A8ECEEDBD8B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff8eee2000 - 0x7fff8efb8ff7 com.apple.DiskImagesFramework (444 - 444) <F3F87D4C-CD77-3872-87BC-E3E44B1F76ED> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff8f06b000 - 0x7fff8f06dffb com.apple.EFILogin (2.0 - 2) <C53AC3A4-C684-3144-89A4-166549518C24> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8f1a8000 - 0x7fff8f5d9ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff90912000 - 0x7fff90912fff libmetal_timestamp.dylib (600.0.48.25) <348D32E6-AD49-36DC-A0DE-5A44B2699FFA> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff90913000 - 0x7fff9091efff libGPUSupport.dylib (12.4.2.1) <FF5E3C71-65E5-3A03-999B-EB50AAAA0777> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x7fff9091f000 - 0x7fff9092aff3 libGPUSupportMercury.dylib (12.4.2.1) <A720545E-40F3-3FE0-A8B3-067D49083417> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff90bdc000 - 0x7fff90bf8ff7 com.apple.GenerationalStorage (2.0 - 259) <43D40063-BD46-3008-8992-FF092B7C9A58> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff912ea000 - 0x7fff91360fff com.apple.Heimdal (4.0 - 2.0) <18C127D7-9C61-3C5B-8C6F-7953760D2674> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff91361000 - 0x7fff91372fff com.apple.HelpData (2.1.10 - 100) <BD5AC3F0-9619-3D1C-B96D-6BFCAD1C0245> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff91972000 - 0x7fff91979ffb com.apple.IOAccelerator (288.13 - 288.13) <F77E27C3-20DD-3CE5-9D0A-6C89A997080E> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff9197b000 - 0x7fff9198fff3 com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff91990000 - 0x7fff919b2ff7 com.apple.IconServices (74.1 - 74.1) <F7B83970-4A72-3186-BBB3-90FA86C3E263> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff91a4d000 - 0x7fff91a5dff3 com.apple.IntlPreferences (2.0 - 216) <43FFAB0C-4124-3231-B0CB-137CCB0A53AF> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff91a94000 - 0x7fff91c48fff com.apple.LanguageModeling (1.0 - 123) <10152D7F-C7C0-34AA-A295-D712D16C76E6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff9227f000 - 0x7fff92282fff com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff9235a000 - 0x7fff9238eff3 com.apple.MediaKit (16 - 840) <2035FF47-C7E6-3F73-A335-AC0BFBB1DB36> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff924de000 - 0x7fff92556fef com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <FAFA0DF5-4226-3867-A2E2-CAB889DC4490> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff92568000 - 0x7fff926bbff7 com.apple.mobiledevice (905.1.2 - 905.1.2) <CAAC5F03-1BD6-3676-A920-82BA7D29BDC3> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x7fff926d8000 - 0x7fff926fefff com.apple.MultitouchSupport.framework (367.6 - 367.6) <32D8588A-29BD-3A23-92B2-05C013DA5BC5> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff927ab000 - 0x7fff927b5fff com.apple.NetAuth (6.0 - 6.0) <D57D5888-0290-3295-A1C4-D673D4DCB497> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff92f56000 - 0x7fff92f97ff7 com.apple.PerformanceAnalysis (1.145 - 145) <9DF1FCCC-7EBF-3213-B77A-0C3D3B7CF7AF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff935fb000 - 0x7fff93626ffb com.apple.ProtectedCloudStorage (1.0 - 1) <A1219818-97B0-3A4D-825B-24ADF9B7C8B6> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff93627000 - 0x7fff93641fff com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff9365b000 - 0x7fff9367eff3 com.apple.RemoteViewServices (2.0 - 124) <280DB828-4613-3DF8-ACBA-C91989B64347> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff942ad000 - 0x7fff942b0ff7 com.apple.SecCodeWrapper (4.0 - 307.1.1) <64F951CB-A975-32F0-BC60-1E839E607FCB> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff9433e000 - 0x7fff943b9fff com.apple.Sharing (659.1.6 - 659.1.6) <C217107C-CD4B-311D-9FBA-7435B1F6186F> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff943ba000 - 0x7fff943d9ff7 com.apple.shortcut (2.16 - 98) <AC3AFB42-F3F7-3E71-8DAF-AA4ACF3021F7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff943da000 - 0x7fff9463bff3 com.apple.SkyLight (1.600.0 - 100) <F0B08B4C-8550-3241-8128-F7601E60BDEB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff94815000 - 0x7fff94821fff com.apple.SpeechRecognitionCore (3.0.15 - 3.0.15) <BE386037-4B61-341F-80E2-5D8B5B50C8BC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff94f04000 - 0x7fff94f70ff3 com.apple.Symbolication (61080.2) <0F183B36-0BCF-3330-8C68-4A521A142919> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff95367000 - 0x7fff9536dff7 com.apple.TCC (1.0 - 1) <CEE9F9F9-2A24-3F60-BE73-4703D85E307C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff953f9000 - 0x7fff955acff3 com.apple.TextureIO (1.31 - 1.31) <9E6E91C7-76DC-3C12-9629-494084792476> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff95620000 - 0x7fff95621fff com.apple.TrustEvaluationAgent (2.0 - 28) <6793B664-C4FC-3CD4-B0E7-25B9933391AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff95622000 - 0x7fff957b1ffb com.apple.UIFoundation (1.0 - 489) <0CD14719-FC52-3AC5-87EF-775437927990> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff9620c000 - 0x7fff962bbff7 com.apple.ViewBridge (265.1 - 265.1) <21855FE3-F19D-3E3F-9500-BFC811DA75C6> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff966e3000 - 0x7fff966e9fff com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff967ba000 - 0x7fff967bcffb com.apple.loginsupport (1.0 - 1) <03B57D6F-C210-32BC-B384-5B0E95660283> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff96811000 - 0x7fff9682cff7 libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
0x7fff9682d000 - 0x7fff96838fff libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
0x7fff96839000 - 0x7fff968c9ff7 libCoreStorage.dylib (540) <767EE749-FAD4-3557-ACC8-35EF8457B98D> /usr/lib/libCoreStorage.dylib
0x7fff968ca000 - 0x7fff968cbff3 libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff968cc000 - 0x7fff96adffff libFosl_dynamic.dylib (16.37) <3EA1C7EE-4A6C-3B09-BCA7-81A074B24013> /usr/lib/libFosl_dynamic.dylib
0x7fff96afb000 - 0x7fff96b02fff libMatch.1.dylib (27) <5D52A207-E2AF-3E05-8C51-91C1D82FCEE8> /usr/lib/libMatch.1.dylib
0x7fff96b03000 - 0x7fff96b03fff libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
0x7fff96b04000 - 0x7fff96b07ff7 libScreenReader.dylib (477.1.5) <88D484EC-7589-324B-890D-799F27DF0FB3> /usr/lib/libScreenReader.dylib
0x7fff96b08000 - 0x7fff96b09ff3 libSystem.B.dylib (1238) <168B3C56-081B-3998-9A44-681EB4C6828F> /usr/lib/libSystem.B.dylib
0x7fff96b75000 - 0x7fff96ba0ffb libarchive.2.dylib (41.1.1) <C4F76D18-8484-3779-AE80-14F27E57ABB5> /usr/lib/libarchive.2.dylib
0x7fff96ba1000 - 0x7fff96c7bfe7 libate.dylib (1.12.12) <1371D20C-3A80-37A5-AB94-09C4C4F67B01> /usr/lib/libate.dylib
0x7fff96c7f000 - 0x7fff96c7fff3 libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
0x7fff96c80000 - 0x7fff96c90ff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fff96c91000 - 0x7fff96c9fff7 libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
0x7fff96ca0000 - 0x7fff96cf6ff7 libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
0x7fff96cf7000 - 0x7fff96d21fff libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
0x7fff96d22000 - 0x7fff96d32ffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fff96d33000 - 0x7fff96d48ffb libcompression.dylib (34) <AEF908E6-C0FE-3884-BD45-FB37A035545D> /usr/lib/libcompression.dylib
0x7fff96d49000 - 0x7fff96d49ff7 libcoretls.dylib (121.1.1) <F3BAB54C-DA82-37C3-A218-46FEB179D555> /usr/lib/libcoretls.dylib
0x7fff96d4a000 - 0x7fff96d4bffb libcoretls_cfhelpers.dylib (121.1.1) <D12709F3-BBE3-3CF7-9070-C2A0803F5526> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff96e05000 - 0x7fff96ee9ff3 libcrypto.0.9.8.dylib (64) <4CB423CE-0B86-334A-9335-FEE75198024F> /usr/lib/libcrypto.0.9.8.dylib
0x7fff9707b000 - 0x7fff97086fff libcsfde.dylib (540) <0F49D756-17BF-3E69-AD3B-A9B993CD41EA> /usr/lib/libcsfde.dylib
0x7fff97087000 - 0x7fff970daff7 libcups.2.dylib (450) <04CA1F55-4B70-3D65-B4B1-62F6C271A9EF> /usr/lib/libcups.2.dylib
0x7fff970db000 - 0x7fff9712aff7 libcurl.4.dylib (95) <7FFE0024-36CD-3040-923F-1DE911FE5459> /usr/lib/libcurl.4.dylib
0x7fff9712b000 - 0x7fff97132ff3 libdscsym.dylib (145) <0972B577-B427-3A1C-A9E7-325B6B265135> /usr/lib/libdscsym.dylib
0x7fff97154000 - 0x7fff97154fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fff97162000 - 0x7fff97163fff libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
0x7fff97164000 - 0x7fff97169ff3 libheimdal-asn1.dylib (498) <8F3F1AE8-CE4A-355C-82E3-74DA46B5BB02> /usr/lib/libheimdal-asn1.dylib
0x7fff9716a000 - 0x7fff9725cff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fff9725d000 - 0x7fff97482fff libicucore.A.dylib (57131.0.1) <72594943-D25E-3F70-A4AC-8E9F9F442B7E> /usr/lib/libicucore.A.dylib
0x7fff97488000 - 0x7fff97489fff liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
0x7fff9748a000 - 0x7fff974a3ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fff974a4000 - 0x7fff974baff7 libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
0x7fff974bb000 - 0x7fff97764fff libmecabra.dylib (744) <545EDC2D-22BB-3E8F-BFD3-921447581D9F> /usr/lib/libmecabra.dylib
0x7fff97797000 - 0x7fff9780fffb libnetwork.dylib (856.1.8) <30FC3C60-CCA9-3E2B-80AA-DE53F5762374> /usr/lib/libnetwork.dylib
0x7fff97810000 - 0x7fff97be5127 libobjc.A.dylib (706) <47104A1B-13E8-369F-BC36-27FF465809FD> /usr/lib/libobjc.A.dylib
0x7fff97be8000 - 0x7fff97becfff libpam.2.dylib (21) <352F8FF6-2248-3594-B357-8D031DEFB06C> /usr/lib/libpam.2.dylib
0x7fff97bed000 - 0x7fff97c1dff7 libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
0x7fff97c3b000 - 0x7fff97c57ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fff97c58000 - 0x7fff97c91fff libsandbox.1.dylib (592.1.3) <0024D751-23D8-35DF-87CF-72E489DA2F9F> /usr/lib/libsandbox.1.dylib
0x7fff97c92000 - 0x7fff97ca4ffb libsasl2.2.dylib (209) <5A177BA8-362D-32DA-8D14-69AB191648B3> /usr/lib/libsasl2.2.dylib
0x7fff97ca5000 - 0x7fff97ca6ff3 libspindump.dylib (228) <F80FAB75-D656-3FDA-8753-D3D6771B17E6> /usr/lib/libspindump.dylib
0x7fff97ca7000 - 0x7fff97de8ffb libsqlite3.dylib (252) <A531C105-64D7-37C0-B999-9320047B71C5> /usr/lib/libsqlite3.dylib
0x7fff97e0b000 - 0x7fff97e43ff3 libssl.0.9.8.dylib (64) <CCE69718-2965-3E28-A886-41C79EB94C67> /usr/lib/libssl.0.9.8.dylib
0x7fff97e44000 - 0x7fff97e94fff libstdc++.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc++.6.dylib
0x7fff97ed6000 - 0x7fff97ed8ffb libutil.dylib (47) <2E56EB36-BF20-3261-9083-3D7AD06A96A2> /usr/lib/libutil.dylib
0x7fff97ed9000 - 0x7fff97ee6fff libxar.1.dylib (354) <AAFCF321-8100-3622-880B-9661DCA35D69> /usr/lib/libxar.1.dylib
0x7fff97eea000 - 0x7fff97fd9ffb libxml2.2.dylib (30.11) <26676155-64CE-323F-B73C-AD77AF5982E8> /usr/lib/libxml2.2.dylib
0x7fff97fda000 - 0x7fff98003fff libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
0x7fff98004000 - 0x7fff98015ff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fff98024000 - 0x7fff98028ff7 libcache.dylib (79) <84E55656-FDA9-3B29-9E4F-BE31B2C0AA3C> /usr/lib/system/libcache.dylib
0x7fff98029000 - 0x7fff98033fff libcommonCrypto.dylib (60092.1.2) <79F738D8-0AD7-3DEA-AF80-E0F8B90B74E3> /usr/lib/system/libcommonCrypto.dylib
0x7fff98034000 - 0x7fff9803bfff libcompiler_rt.dylib (62) <486BDE52-81B4-3446-BD72-23977CAE556F> /usr/lib/system/libcompiler_rt.dylib
0x7fff9803c000 - 0x7fff98044fff libcopyfile.dylib (138) <0DA49B77-56EC-362D-98FF-FA78CFD986D6> /usr/lib/system/libcopyfile.dylib
0x7fff98045000 - 0x7fff980c7ff3 libcorecrypto.dylib (442.1.3) <1CA8B679-810E-3C04-945A-4AC19372CDC7> /usr/lib/system/libcorecrypto.dylib
0x7fff980c8000 - 0x7fff980fafff libdispatch.dylib (703.1.4) <12B1D95B-283D-325D-85AB-29A2FFD36987> /usr/lib/system/libdispatch.dylib
0x7fff980fb000 - 0x7fff98100ff3 libdyld.dylib (421.1) <CDFBDC9C-418C-369D-B433-F64B0630E640> /usr/lib/system/libdyld.dylib
0x7fff98101000 - 0x7fff98101ffb libkeymgr.dylib (28) <09CD7CA6-46D2-3A9F-B9F1-7C4CA5CA0D68> /usr/lib/system/libkeymgr.dylib
0x7fff98102000 - 0x7fff9810effb libkxld.dylib (3789.1.32) <48BDBE7F-AAE6-3050-9017-6959051CF16A> /usr/lib/system/libkxld.dylib
0x7fff9810f000 - 0x7fff9810ffff liblaunch.dylib (972.1.5) <DC31FDEA-FD81-335E-BAA8-5A7395D20772> /usr/lib/system/liblaunch.dylib
0x7fff98110000 - 0x7fff98115fff libmacho.dylib (894) <1EAE5ADD-490C-3B1F-9F97-447BA8E0E90F> /usr/lib/system/libmacho.dylib
0x7fff98116000 - 0x7fff98118ff3 libquarantine.dylib (85) <78EF62D8-C890-3FC0-937A-C2FD8CEF8992> /usr/lib/system/libquarantine.dylib
0x7fff98119000 - 0x7fff9811affb libremovefile.dylib (45) <C4FC07FF-ED86-382E-B06F-33C34718080C> /usr/lib/system/libremovefile.dylib
0x7fff9811b000 - 0x7fff98133ff7 libsystem_asl.dylib (349.1.1) <F0987490-8427-367F-B302-A05A7D61FEBF> /usr/lib/system/libsystem_asl.dylib
0x7fff98134000 - 0x7fff98134ff7 libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
0x7fff98135000 - 0x7fff981c2fe7 libsystem_c.dylib (1158.1.2) <5F260836-48E4-3F57-8553-62D2DA228A1F> /usr/lib/system/libsystem_c.dylib
0x7fff981c3000 - 0x7fff981c6ffb libsystem_configuration.dylib (888.1.2) <67BB9D8B-2430-38AD-81A7-F0EC924B2590> /usr/lib/system/libsystem_configuration.dylib
0x7fff981c7000 - 0x7fff981cafff libsystem_coreservices.dylib (41.1) <11F22E6C-0DCB-3699-A4F0-C99E301E56E9> /usr/lib/system/libsystem_coreservices.dylib
0x7fff981cb000 - 0x7fff981e3ffb libsystem_coretls.dylib (121.1.1) <8F7E9B12-400D-3276-A9C5-4546B0258554> /usr/lib/system/libsystem_coretls.dylib
0x7fff981e4000 - 0x7fff981eafff libsystem_dnssd.dylib (765.1.2) <C5FF2025-C60B-39C6-B205-6BF1BC51D1B3> /usr/lib/system/libsystem_dnssd.dylib
0x7fff981eb000 - 0x7fff98214fff libsystem_info.dylib (503) <C686B834-5E7D-382C-AF6E-44AB78EE83E2> /usr/lib/system/libsystem_info.dylib
0x7fff98215000 - 0x7fff98237ff7 libsystem_kernel.dylib (3789.1.32) <5C68A0D7-C3C9-3E52-B983-EDE9A28AB6FC> /usr/lib/system/libsystem_kernel.dylib
0x7fff98238000 - 0x7fff9827ffe7 libsystem_m.dylib (3121.4) <E3370D16-EBAA-3C7F-AC56-2D6EAD7DB0A4> /usr/lib/system/libsystem_m.dylib
0x7fff98280000 - 0x7fff9829eff7 libsystem_malloc.dylib (116) <3DD17B88-B7A4-38B9-9E95-AB88E1C3B647> /usr/lib/system/libsystem_malloc.dylib
0x7fff9829f000 - 0x7fff982f5fff libsystem_network.dylib (856.1.8) <A8973360-956A-33BF-9971-14D59C84E0D1> /usr/lib/system/libsystem_network.dylib
0x7fff982f6000 - 0x7fff982ffff3 libsystem_networkextension.dylib (563.1.11) <1C551832-9360-36DD-A7BA-52B55A171720> /usr/lib/system/libsystem_networkextension.dylib
0x7fff98300000 - 0x7fff98309ffb libsystem_notify.dylib (165) <AF77D471-6B13-36BA-B144-7E7DDB9DBA9F> /usr/lib/system/libsystem_notify.dylib
0x7fff9830a000 - 0x7fff98312fe7 libsystem_platform.dylib (126.1.2) <884DDF42-3CAE-334A-82CE-965617130FB1> /usr/lib/system/libsystem_platform.dylib
0x7fff98313000 - 0x7fff9831dfff libsystem_pthread.dylib (218.1.3) <050AE77B-4F4B-334A-A5BA-CF0D10AF5304> /usr/lib/system/libsystem_pthread.dylib
0x7fff9831e000 - 0x7fff98321fff libsystem_sandbox.dylib (592.1.3) <90FEF628-316D-3F84-9EF4-F7F510A4FBBB> /usr/lib/system/libsystem_sandbox.dylib
0x7fff98322000 - 0x7fff98323fff libsystem_secinit.dylib (24) <A54B8FEF-E792-3C54-8E0B-E80A376662F2> /usr/lib/system/libsystem_secinit.dylib
0x7fff98324000 - 0x7fff9832bfff libsystem_symptoms.dylib (532.1.1) <B26F656E-94F9-3834-9B03-51C4FF11D1BF> /usr/lib/system/libsystem_symptoms.dylib
0x7fff9832c000 - 0x7fff9834cff7 libsystem_trace.dylib (518.1.16) <C3CDF7BC-CA3D-34F5-ADF8-46AAAB0B47F8> /usr/lib/system/libsystem_trace.dylib
0x7fff9834d000 - 0x7fff98352ffb libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
0x7fff98353000 - 0x7fff9837cff7 libxpc.dylib (972.1.5) <2A901937-48E1-3BF2-83F1-2431156D82B7> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 190856
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=291.6M resident=0K(0%) swapped_out_or_unallocated=291.6M(100%)
Writable regions: Total=989.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=989.8M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 3
Activity Tracing 256K 2
CG backing stores 9136K 4
CG image 1404K 10
CoreAnimation 28K 4
CoreUI image data 804K 10
CoreUI image file 156K 4
Dispatch continuations 16.0M 2
IOKit 15.5M 2
Image IO 1036K 5
Kernel Alloc Once 8K 2
MALLOC 617.4M 159
MALLOC guard page 48K 9
Memory Tag 242 12K 2
OpenGL GLSL 256K 4
STACK GUARD 56.0M 10
Stack 20.3M 1238
VM_ALLOCATE 304.7M 144
VM_ALLOCATE (reserved) 36K 2 reserved VM address space (unallocated)
__DATA 25.8M 270
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 118.5M 17
__TEXT 173.1M 269
__UNICODE 556K 2
mapped file 43.9M 11
shared memory 16.4M 14
TOTAL 1.4G 2176
TOTAL, minus reserved VM space 1.4G 2176
System Profile:
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 5.0.0f18, 3 services, 27 devices, 1 incoming serial ports
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0198, 0x393930353432382D3031322E4130304C4620
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0198, 0x393930353432382D3031322E4130304C4620
USB Device: USB 2.0 Bus
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Hub
USB Device: IR Receiver
Serial ATA Device: Samsung SSD 850 EVO 500GB, 500,11 GB
Serial ATA Device: MATSHITADVD-R UJ-898
Model: MacBookPro8,3, BootROM MBP81.0047.B2C, 4 processors, Intel Core i7, 2,2 GHz, 8 GB, SMC 1.70f6
Network Service: Wi-Fi, AirPort, en1
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In
Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
