Add crazy fans alongside the road on Alpe du Zwift, especially on Dutch corner and from turn 1 to the summit. Cheering, waving Zwift flags, offering water bottles, etc. Even have a few that start running along side of you as you climb that you have to use your bell on “ring-ring”.
That would be another good reason for me to avoid the Alpe du Zwift if that was to ever be implemented.
I like all the stuff written on the roads - and thumbs ups, which from far away look like another body part that’s often drawn on the ground. Spectators overall could be improved - but I put this lower on the priority list. Interactions with them would be cool. Like, if you get a sprint PR, they go crazy. Or if you go slow they boo you.
Cool idea! This should only happen during races to make them special.
Basically nice idea, but I’m afraid in my case they will BOO me all the time
you are comically glum, alpe du zwift is very sterile and should be revamped to capture the feel of the real thing. WTF is the summit all about?
