Hi all, I am thinking about upgrading my current turbo to either the neo2t, kickr or the core. I have concerns about how easy it is to switch between turbo and outside riding. So does any one run an 8 speed cassette on any of the above turbo trainers and how easy do you find it going switching between the two?
confirm that you can run the 8 speed cassette on the trainer (there is another thread around here somewhere discussing it—I think it’s just a matter of using the appropriate number/amount of spacers behind the cassette on the trainer so that your derailleur is correctly aligned with the cassette).
If you want the on/off trainer transfer to be as easy as possible, make sure you get a second, matching cassette for the trainer (i.e. so that you have one permanently on the trainer and one on the bike).
At this point, getting your bike on/off the trainer is really nothing more than getting your rear wheel on/off the bike. You mount your bike’s rear dropouts on the trainer just like you would mount them onto the hub-ends of your rear wheel.
I have a neo 1 2017 version and it came with spacers that works for my 9 speed. You may want to contact Tacx directly and ask specifically if it is possible to use an 8-speed set up. As an aside, I have found that it works great for ERG mode but as I have become more fit and bit stronger, I have trouble finding the right gears when participating in events. The jumps are too large in some cases to get a comfortable cadence which makes me want to get a bike with 11 or 12 sprockets with a tighter gearing ratio.
I found I needed to file the spacer down where the 3 rivets that hold the cassette together sit to allow the largest gear to sit flat against the spacer. A few minutes with a small file did the job, and since then, no problems. As XN says, I have the same cassette on my trainer as on my rear wheel. The trainer is a Saris H3, but as we’re really just considering the freehub, it shouldn’t make much difference which trainer you’re talking about.
I have an 8 speed mountain bike on my neo currently. I think there is 1 spacer in there. I bought it and an extra cassette from my local bike store and they fitted the cassette onto it for me.
Hi
I also have a Claris 8 speed, I know the 1.85 spacer needs to be fitted but then do you reduce the cassette on the turbo trainer down to 8 or leave all 11 still on???
Kind regards
Dean
