1.80 Richmond, windows crash
Updated to 1.80, loaded “libby hill after party” route. Zwift crashes and has to be restarted. Running on windows 11, other routes are working.
Please post details of your setup, including the specs of what you’re running Zwift on.
Hi Steve, have you tested to load the same route on your setup?
No, I’m just a regular Zwifter like you, and I don’t run Zwift on a PC.
When crashing/freezing problems occur it’s helpful to know PC specs, because then we can see whether it looks like an existing known problem (e.g. AMD CPU with integrated graphics) or something else.
I rode it a few days ago. No problems. Windows 10 on i5 12400F with Nvidia GTX 970.
If you have a Ryzen based system with integrated graphics, there is a bug for that. If it’s something else, there may be something you can do if you post the details.
I have an Nvidia GTX 1080 also. Did you run it with 1.80? Looks like the problem started with this version.
Core i5-4590 CPU @ 3.30GHz - NVIDIA GeForce GTX 1080
Yes I was on 1.80 for that ride
I’m using an Nvidia driver released in August but the one that comes by default from Microsoft is known to be stable and there should be no benefit to running anything newer.
My Zwift just crashes with the following message in the logs:
[18:07:45] [ActionBarV2] Teleport: Publication Started.
[18:07:45] [ActionBarV2] Active Actions have changed.
[18:07:45] GL error GL_INVALID_OPERATION
[18:07:45] ASSERT: "RouteProgressInfo(): Calling new player tracking behavior when route is null", file=D:\git\zwift-game-client\Projects\ZwiftApp\CODE\RouteProgressInfo.cpp, line=621
[18:07:45] ERROR: ZwiftApp Crashed
Can you share detailed specs for your PC?
I removed my Zwift folder, and when starting with a new folder, it worked. A hassle to do some settings again, but rather minor.
