Hello,
Probably an obvious question but not found a definitive answer so far. I have zwift installed on a laptop if I adjust all the settings ie the HUD section will this change cascade onto my other windows PC that I use for my smart bike?
I’m pretty sure that this is an in-game setting for your profile, like the bike you are riding and kit you’re wearing, and Trainer Difficulty, so it should be the same on any device you use. You could always do a quick rest to confirm, though.
I haven’t tested that particular setting, but most settings are kept local and my guess that is probably one of them. People use different trainers, different displays, different controls, etc. on different setups. It would be problematic to sync those across systems. Garage and profile data are not local.
FWIW: I’d be more inclined to believe what @Paul_Southworth said than what I said.
Probably still worth a test on your different Zwift devices, though, just to confirm.
Hi all,
Just tested it and yes if I set it on one device it remains the setting for other devices.
It’s far easier to set up on my laptop than the pc I use for zwift as this a limited keyboard and mouse facility.
