I have a bug to report relating to Zwift Run.
Expected behavior: In Zwift Run: You can choose your shorts in the shorts menu. Your choice of shirt does not change your shorts. You can mix and match shirts and shorts as you desire.
Seen behavior: Your shirt choice also changes your shorts, in a similar fashion to jersey choices in Zwift cycling. Selecting different shorts in the shorts menu changes nothing. You cannot mix and match shirts and shorts as your avatar is locked to wearing the shorts that are linked with the shirt your avatar is wearing.
Zwift version: 1.0.85684
Specs: Windows 11 Pro x64 OS Build 22494.1000, Intel i5-6600K, Nvidia GeForce RTX 3080.
