Hi, I’m testing Zwift in a MacBook Pro 4 days ago and everyday I have used it I faced at least one crash per day…losing my ride data… I though that the issue could be related with the Graphic Card and I have changed the configuration to lowest resolution… but it crashes again with lowest resolution.
I would like to fix this issue asap to avoid change to another app…
I will put the last log report that have just happened some minutes ago. Hope you can help me to fix this issue:
Process: ZwiftApp [519]
Path: /Users/USER/Library/Application Support/Zwift/ZwiftApp
Identifier: ZwiftApp
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: ZwiftApp [519]
User ID: 501
Date/Time: 2017-03-28 20:55:32.245 +0200
OS Version: Mac OS X 10.11.6 (15G1217)
Report Version: 11
Anonymous UUID: 3183C290-9EB7-D7F0-7BC3-3E7E06C7E5B7
Time Awake Since Boot: 5000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000000e8
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0xe8:
__TEXT 0000000104293000-0000000104ac7000 [8400K] r-x/rwx SM=COW /Users/USER/Library/Application Support/Zwift/*
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.GeForceGLDriver 0x00007fff9e02095c 0x7fff9dcf8000 + 3311964
1 com.apple.GeForceGLDriver 0x00007fff9df1a697 gldGetQueryInfo + 38
2 GLEngine 0x00007fff9583378a glGetQueryObject_Core + 254
3 GLEngine 0x00007fff9583389a glGetQueryObjectuiv_Exec + 37
4 ZwiftApp 0x0000000104474f00 Sky::Render_PostFX(VEC3, float, bool) + 160
5 ZwiftApp 0x0000000104417af6 drawNewWorld(float, float, float, float, float) + 17014
6 ZwiftApp 0x000000010441b7f6 Render(float) + 982
7 ZwiftApp 0x000000010441cdc4 doFrame() + 804
8 ZwiftApp 0x000000010442c195 CODEmain(int, char const**) + 85
9 ZwiftApp 0x00000001043fb843 main + 595
10 ZwiftApp 0x00000001042950b4 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8b6b3efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff99d84165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff99d83dcd _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff8b6b310a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff957b0d0f nanosleep + 199
2 ZwiftApp 0x00000001047b48d3 JM_Worker_Thread(void*) + 307
3 libsystem_pthread.dylib 0x00007fff8c25d99d _pthread_body + 131
4 libsystem_pthread.dylib 0x00007fff8c25d91a _pthread_start + 168
5 libsystem_pthread.dylib 0x00007fff8c25b351 thread_start + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff8b6b2db6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff8c25e728 _pthread_cond_wait + 767
2 ZwiftApp 0x000000010488c93b AK::StreamMgr::CAkIOThread::IOSchedThread(void*) + 75
Thread 4:
0 libsystem_kernel.dylib 0x00007fff8b6acfae semaphore_wait_trap + 10
1 ZwiftApp 0x000000010485e213 CAkThreadedBankMgr::BankThreadFunc(void*) + 51
2 libsystem_pthread.dylib 0x00007fff8c25d99d _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff8c25d91a _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff8c25b351 thread_start + 13
Thread 5:
1 ZwiftApp 0x0000000104863daf CAkAudioThread::EventMgrThreadFunc(void*) + 63
Thread 6:
1 ZwiftApp 0x000000010481db4b CAkOutputMgr::SuspendedThread(void*) + 59
Thread 7:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff8b6acf72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8b6ac3b3 mach_msg + 55
2 com.apple.audio.CoreAudio 0x00007fff9070e35e HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
3 com.apple.audio.CoreAudio 0x00007fff9070e2ec HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fff9070c6a9 HALC_ProxyIOContext::IOWorkLoop() + 1149
5 com.apple.audio.CoreAudio 0x00007fff9070c15e HALC_ProxyIOContext::IOThreadEntry(void*) + 88
6 com.apple.audio.CoreAudio 0x00007fff9070c033 HALB_IOThread::Entry(void*) + 75
7 libsystem_pthread.dylib 0x00007fff8c25d99d _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff8c25d91a _pthread_start + 168
9 libsystem_pthread.dylib 0x00007fff8c25b351 thread_start + 13
Thread 8:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff914bd124 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff914bc5ec __CFRunLoopRun + 1356
4 com.apple.CoreFoundation 0x00007fff914bbe38 CFRunLoopRunSpecific + 296
5 com.apple.AppKit 0x00007fff9303fd95 _NSEventThread + 149
6 libsystem_pthread.dylib 0x00007fff8c25d99d _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff8c25d91a _pthread_start + 168
8 libsystem_pthread.dylib 0x00007fff8c25b351 thread_start + 13
Thread 9:
0 libsystem_kernel.dylib 0x00007fff8b6b3eca kevent + 10
1 ZwiftApp 0x000000010464f3e1 asio::detail::kqueue_reactor::run(bool, asio::detail::op_queue<asio::detail::task_io_service_operation>&) + 265
2 ZwiftApp 0x000000010464f115 asio::detail::task_io_service::do_run_one(asio::detail::scoped_lock<asio::detail::posix_mutex>&, asio::detail::task_io_service_thread_info&, std::__1::error_code const&) + 267
3 ZwiftApp 0x000000010464edfe asio::detail::task_io_service::run(std::__1::error_code&) + 416
4 ZwiftApp 0x00000001045bb5c7 asio::io_service::run() + 43
5 ZwiftApp 0x00000001046538dc asio_detail_posix_thread_function + 19
Thread 10:
Thread 11:
5 com.apple.CoreFoundation 0x00007fff914fd911 CFRunLoopRun + 97
6 libant.dylib 0x00000001051db641 IOKitDeviceHandle::EventThread() + 265
7 libant.dylib 0x00000001051da7b3 IOKitDeviceHandle::EventThreadStart(void*) + 9
8 libsystem_pthread.dylib 0x00007fff8c25d99d _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff8c25d91a _pthread_start + 168
10 libsystem_pthread.dylib 0x00007fff8c25b351 thread_start + 13
Thread 12:
0 libsystem_kernel.dylib 0x00007fff8b6b42a2 poll + 10
1 libant.dylib 0x00000001051d83c4 IOKitTransfer::Receive() + 126
2 libant.dylib 0x00000001051db45e IOKitDeviceHandle::SendSyncBulkTransfer(unsigned char, unsigned char*, int, unsigned int, int&) + 182
3 libant.dylib 0x00000001051dc080 USBDeviceHandleIOKit::ReceiveThread() + 178
4 libant.dylib 0x00000001051dbed7 USBDeviceHandleIOKit::ProcessThread(void*) + 9
5 libsystem_pthread.dylib 0x00007fff8c25d99d _pthread_body + 131
6 libsystem_pthread.dylib 0x00007fff8c25d91a _pthread_start + 168
7 libsystem_pthread.dylib 0x00007fff8c25b351 thread_start + 13
Thread 13:
2 libant.dylib 0x00000001051e0955 DSIThread_CondTimedWait + 136
3 libant.dylib 0x00000001051de122 TSQueue<char, std::deque<char, std::allocator<char> > >::PopArray(char*, unsigned int, unsigned int) + 74
4 libant.dylib 0x00000001051dbfb9 USBDeviceHandleIOKit::Read(void*, unsigned int, unsigned int&, unsigned int) + 35
5 libant.dylib 0x00000001051e0656 DSISerialGeneric::ReceiveThread() + 96
6 libant.dylib 0x00000001051e04e1 DSISerialGeneric::ProcessThread(void*) + 9
Thread 14:
3 libant.dylib 0x00000001051e22c1 DSIFramerANT::WaitForMessage(unsigned int) + 87
4 libant.dylib 0x00000001051d6077 MessageThread(void*) + 632
Thread 15:
0 libsystem_kernel.dylib 0x00007fff8b6b35e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff8c25d578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff8c25b341 start_wqthread + 13
Thread 16:
Thread 17:
3 libant.dylib 0x00000001051dfd0c DSITimer::TimerThread() + 94
4 libant.dylib 0x00000001051dfbcd DSITimer::TimerThreadStart(void*) + 9
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000000007f81a rbx: 0x00000000000000c0 rcx: 0x00007fff5b96a840 rdx: 0x0000000000008866
rdi: 0x000000010fa84000 rsi: 0x00007fff7b7f5000 rbp: 0x00007fff5b96a810 rsp: 0x00007fff5b96a7e0
r8: 0x00007fff9e020a89 r9: 0x00007fff9e020d70 r10: 0x00000000000000f9 r11: 0x0000000000000000
r12: 0x000000010fa84000 r13: 0x0000000000008866 r14: 0x00007fd961d38190 r15: 0x000000010883f000
rip: 0x00007fff9e02095c rfl: 0x0000000000010206 cr2: 0x00000000000000e8
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x104293000 - 0x104ac6ff7 +ZwiftApp (???) <B0E67C5E-2EB0-30C4-8BBA-ECFA50F6722F> /Users/USER/Library/Application Support/Zwift/ZwiftApp
0x105154000 - 0x10519bff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <725265D0-1869-30A1-B27A-55CFA8FBF5A4> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x1051d5000 - 0x1051f2fff +libant.dylib (0) <69DB8DF7-7E3F-33EE-9472-45DD36CFD413> /Users/USER/Library/Application Support/Zwift/libant.dylib
0x105218000 - 0x105258fff com.apple.glut (3.6.3 - GLUT-3.6.3) <D22877F2-9D97-3902-AC5D-9B27D5581F47> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x1052cd000 - 0x1052f3ff7 com.apple.audio.OpenAL (1.8 - 1.8) <9C322240-9854-3114-98ED-6CAABD436EEB> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x10530b000 - 0x10545efc7 com.apple.mobiledevice (905.1.2.3.1 - 905.1.2.3.1) <0BC2BDA7-BC9A-3535-9F7A-368E0AA1994B> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x1054df000 - 0x105516fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x105544000 - 0x105653fff com.apple.AudioVideoBridging (403.4 - 403.4) <647EC44F-BC92-367C-AA25-E52085CC3EC6> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x105706000 - 0x10571ffff libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
0x10572a000 - 0x105730fff com.apple.TimeSync (1.0 - 403.4) <4E3FCB52-7F47-39A2-9C29-11CFE4823CC4> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x10bec0000 - 0x10bec4fff com.apple.audio.AppleHDAHALPlugIn (274.12 - 274.12) <F5E4849C-6A2D-3D2C-AB3F-F608C0E49FD5> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x10beca000 - 0x10bffaffb com.apple.audio.units.Components (1.13 - 1.13) <69FC51F9-E779-3940-AA27-8F97A9849D51> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x10f212000 - 0x10f701fff com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.14.73 - 10.1.4) <E3F0BB8C-2633-39E5-B8A5-645016341CAE> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
0x129d76000 - 0x129d7eff7 com.apple.iokit.IOUSBLib (900.4.1 - 900.4.1) <0CB0E8A6-D032-3B55-881B-FC1AC8A1BEF0> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x15e1e0000 - 0x15e2e3fff com.apple.GeForceMTLDriver (10.10.14 - 10.1.0) <FE279E95-A398-3F09-97F8-6307F958C294> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
0x15e32c000 - 0x15e38ffff com.apple.driver.AppleIntelHD4000GraphicsMTLDriver (10.14.73 - 10.1.4) <17903EF1-BCF8-3553-B1CD-C876346D5A40> /System/Library/Extensions/AppleIntelHD4000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsMTLDriver
0x15ed69000 - 0x15ed69fe7 +cl_kernels (???) <A63FD85F-3C4C-42C2-9793-66A48D455C75> cl_kernels
0x7fff6b973000 - 0x7fff6b9aaa47 dyld (360.22) <884763FC-CC0F-31CC-ACC4-75A805CE401D> /usr/lib/dyld
0x7fff8b69c000 - 0x7fff8b6baff7 libsystem_kernel.dylib (3248.60.11.2.1) <19B06617-EDC1-3925-8A09-BC775F3D6A08> /usr/lib/system/libsystem_kernel.dylib
0x7fff8b6ff000 - 0x7fff8b73dff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff8b743000 - 0x7fff8b74efff libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
0x7fff8b76d000 - 0x7fff8b76dfff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff8b76e000 - 0x7fff8b844ffb com.apple.DiskImagesFramework (10.11.4 - 417.4) <B9525D22-6F0D-39C5-BA9B-9DF195FE1968> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff8b845000 - 0x7fff8b874ff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff8b8c2000 - 0x7fff8b8c4fff com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8b8c5000 - 0x7fff8b8f4ffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff8bef1000 - 0x7fff8bf1afff com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff8c052000 - 0x7fff8c080ff7 com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff8c081000 - 0x7fff8c086fff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff8c087000 - 0x7fff8c127fff com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff8c145000 - 0x7fff8c178ff7 com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8c179000 - 0x7fff8c181fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff8c225000 - 0x7fff8c225fff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8c25a000 - 0x7fff8c263ff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff8c29b000 - 0x7fff8c2a0fff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff8c2a1000 - 0x7fff8c4acfff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff8c52b000 - 0x7fff8c5a2feb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff8c5a3000 - 0x7fff8c5abffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff8c5ac000 - 0x7fff8c5e0ff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff8c5e1000 - 0x7fff8c630ff7 com.apple.opencl (2.7.0 - 2.7.0) <07FB8F36-A00C-3BFD-BC38-9E4EC484907E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8c67c000 - 0x7fff8c971fff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff8c972000 - 0x7fff8c9afff3 com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff8c9b0000 - 0x7fff8c9b2ff7 com.apple.securityhi (9.0 - 55006) <1E7BE52B-97EA-371A-AECA-1EE2AD246D8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8ca4f000 - 0x7fff8caadfff com.apple.CoreServices.OSServices (728.13 - 728.13) <27C12B92-7845-38DD-B82D-DC5B678352D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff8caef000 - 0x7fff8caf5fff com.apple.IOAccelerator (205.11 - 205.11) <C51BF724-F8E8-3B9F-806E-A00C65056445> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff8cb24000 - 0x7fff8cb37fff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff8cb38000 - 0x7fff8cba3ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff8cc6a000 - 0x7fff8ccf3ff7 com.apple.PerformanceAnalysis (1.0 - 1) <07DC8D32-56AF-3AD3-83D8-9DC413BA8C2F> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff8ccfb000 - 0x7fff8cd40ff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff8cd41000 - 0x7fff8cd45fff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8cd46000 - 0x7fff8cd48ff7 com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff8cd49000 - 0x7fff8d121fef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff8d150000 - 0x7fff8d3e2ffb com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff8d3fe000 - 0x7fff8d41afff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8d637000 - 0x7fff8d637fff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8d638000 - 0x7fff8d63afff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff8d63b000 - 0x7fff8d63dff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff8d65a000 - 0x7fff8d662fff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff8d6e8000 - 0x7fff8d6e9fff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff8e0dd000 - 0x7fff8e172fff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8e173000 - 0x7fff8e1c1fff libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
0x7fff8e1ce000 - 0x7fff8f434ff3 com.apple.CoreGraphics (1.600.0 - 960.7) <61850A83-03A8-33D0-8A9B-3DC57177DFB3> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8f798000 - 0x7fff8f79fff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff8f93f000 - 0x7fff8f963fff com.apple.MultitouchSupport.framework (304.12 - 304.12) <25FA270C-361D-3732-ABF5-A291240AD6A4> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8f9b7000 - 0x7fff8f9d9fff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8fa68000 - 0x7fff8fa68fff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff8fa69000 - 0x7fff8fa6afff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff8fa77000 - 0x7fff8fa7ffff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff8faad000 - 0x7fff8fd92ffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff8fd93000 - 0x7fff8fdacfe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff8fe1c000 - 0x7fff8fe1cfff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8fe1d000 - 0x7fff8fe46ff7 libxslt.1.dylib (14.4) <72CD1CA4-1FBD-3672-ADCE-A89AB741689A> /usr/lib/libxslt.1.dylib
0x7fff901e6000 - 0x7fff901f7fff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff901f8000 - 0x7fff90576ff3 com.apple.VideoToolbox (1.0 - 1731.15.207) <6C7C261F-CB65-3AF1-92E7-16ACAD371EF4> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff905d2000 - 0x7fff906c4ff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff906d4000 - 0x7fff906d6fff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff906d7000 - 0x7fff906d7fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff906d8000 - 0x7fff906e3ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff906e4000 - 0x7fff90735fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff9108a000 - 0x7fff911b7ff3 com.apple.CoreText (352.0 - 494.12) <ADBE8355-D4F5-3316-A6C4-D641D615CEC4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff911c9000 - 0x7fff91256dd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff91433000 - 0x7fff918a9ff7 com.apple.CoreFoundation (6.9 - 1259) <51D1F34F-9FEC-3EF2-8382-2D13D75F845A> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff918aa000 - 0x7fff918affff com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff91944000 - 0x7fff91a6bfff com.apple.LaunchServices (728.13 - 728.13) <DF9A69C3-06AD-3062-A40A-50ED12CA18CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff91a78000 - 0x7fff91aa1ff7 libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
0x7fff92dfd000 - 0x7fff92e05fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff92e27000 - 0x7fff92e33ff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff92ea1000 - 0x7fff93acaff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff93acb000 - 0x7fff93d65ff3 com.apple.security (7.0 - 57337.60.2) <E2E553E7-28C4-3296-B3B6-BB1B3CA73943> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff93d8c000 - 0x7fff93d91ff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff93f5c000 - 0x7fff93f78ff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff93f79000 - 0x7fff93f8aff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff93fa3000 - 0x7fff93fa4fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff93fa5000 - 0x7fff93fbcff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff93fbd000 - 0x7fff94253fff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff94ce9000 - 0x7fff94f0aff7 com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff94f65000 - 0x7fff95054ff7 libxml2.2.dylib (29.11) <DBAD6C6D-DF50-32E0-A621-F556DFD12A71> /usr/lib/libxml2.2.dylib
0x7fff95055000 - 0x7fff95055fff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff952e0000 - 0x7fff952e2fff libCVMSPluginSupport.dylib (12.1) <C503A29A-D3AE-3935-8E0D-69C575684B60> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff95376000 - 0x7fff955fdfff com.apple.CFNetwork (760.6.3 - 760.6.3) <8CB9CB2E-D0FB-31D4-A1AE-2A5FE028AD6B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff955fe000 - 0x7fff95672ff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff95731000 - 0x7fff957befef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff957c5000 - 0x7fff957c7ff7 libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
0x7fff957c8000 - 0x7fff95973ffb GLEngine (12.1) <F7DBE3F9-3187-33D6-A3F4-BDF99CE9D425> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff9599c000 - 0x7fff95aaaff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff95f07000 - 0x7fff95f41fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff95f4b000 - 0x7fff95f53fff libGFXShared.dylib (12.1) <FFB3BBDE-0AE4-3570-B9F4-1BC093F8777A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff95f54000 - 0x7fff95f70ff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff95f71000 - 0x7fff95f74ffb libdyld.dylib (360.22) <F103B2FB-D383-38CB-992A-E16BDCB00A03> /usr/lib/system/libdyld.dylib
0x7fff95f75000 - 0x7fff95f79fff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff95f7a000 - 0x7fff95f7fff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff95f80000 - 0x7fff95fa2ff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff96057000 - 0x7fff96059ff7 libRadiance.dylib (1460) <FE5180D2-115B-3B7C-8F90-CF352BCC38F3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff9605a000 - 0x7fff960a6fff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff960fe000 - 0x7fff9610cfff com.apple.opengl (12.1.0 - 12.1.0) <62997B59-BCD2-3A71-BD16-DE75DBAFA7C2> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff96274000 - 0x7fff9628bfff com.apple.ScriptingBridge (1.3.3 - 68) <13D01EBC-D01E-3054-8C3C-3989BCF6370A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff96295000 - 0x7fff963dfff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff963ed000 - 0x7fff96c7dff7 libclh.dylib (4.0.3 - 4.0.3) <7E2A5EEF-3235-395D-B146-CDD88C61F563> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x7fff96c7e000 - 0x7fff96c87fff com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff96c88000 - 0x7fff96cd8ff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff96d5a000 - 0x7fff96ed8fff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff96f24000 - 0x7fff96f27fff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff96f28000 - 0x7fff9700efef unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff970fb000 - 0x7fff970fefff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff970ff000 - 0x7fff972a5ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff97468000 - 0x7fff97491fff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fff9857c000 - 0x7fff9857efff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff985cf000 - 0x7fff9893a657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff9893b000 - 0x7fff98afbffb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff98b04000 - 0x7fff98b28ff7 libJPEG.dylib (1460) <82AF76D7-B3E6-39AA-947E-C34A280FD1CF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff98b52000 - 0x7fff98b68ff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff98e0e000 - 0x7fff98e33ff7 libPng.dylib (1460) <2A9174D0-445A-3AD9-8141-D602E9A1D735> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff98e37000 - 0x7fff98e39ffb libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
0x7fff98e3a000 - 0x7fff98ed0fff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff98ed1000 - 0x7fff98eebfff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff98f02000 - 0x7fff98ffeff7 libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff99003000 - 0x7fff9900cff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff9907e000 - 0x7fff9907ffff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff990b2000 - 0x7fff990ccff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff9927e000 - 0x7fff99297fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff997b1000 - 0x7fff997b4fff libspindump.dylib (197.1) <0977578F-0FA1-3F44-B16E-37DFD2C52CC8> /usr/lib/libspindump.dylib
0x7fff99856000 - 0x7fff99856ff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff99857000 - 0x7fff99a20ff7 com.apple.ImageIO.framework (3.3.0 - 1460) <A436D5E1-64E3-33A1-9403-DC63E7809285> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff99a21000 - 0x7fff99a36fff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff99a37000 - 0x7fff99a82ff7 com.apple.CoreMediaIO (703.0 - 4791) <57D92CFE-E717-38FE-AEE8-0A4D9769679F> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff99af3000 - 0x7fff99d00fff libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
0x7fff99d7c000 - 0x7fff99da9fff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff99daa000 - 0x7fff99dc9ff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff99dd1000 - 0x7fff99e40fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff99e9d000 - 0x7fff99ea8fff libGPUSupportMercury.dylib (12.1) <28957CBD-2E85-3D1E-9750-757F2A893FCA> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff9a597000 - 0x7fff9a8ebfff com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff9a921000 - 0x7fff9a967ff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff9a968000 - 0x7fff9a968fff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff9a9fa000 - 0x7fff9aa06fff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff9aa07000 - 0x7fff9aa12ff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff9aa13000 - 0x7fff9aa4aff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff9aa4b000 - 0x7fff9aa4bfff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff9aa4c000 - 0x7fff9acf2ff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff9acf3000 - 0x7fff9acf3fff com.apple.CoreServices (728.13 - 728.13) <E3DFECD2-ECEA-3242-972D-95B9646B57B8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff9ad0b000 - 0x7fff9ad93fff com.apple.CoreSymbolication (3.1 - 58048.1) <1A6BF14E-55F3-324E-81DB-BB22B9C288AE> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff9ad94000 - 0x7fff9ad95ff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff9b060000 - 0x7fff9b06ffe7 com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff9b0c8000 - 0x7fff9b254ff7 libGLProgrammability.dylib (12.1) <CAE9E2B5-7E37-337C-8C84-4F449C237494> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff9b4c3000 - 0x7fff9b518fff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff9b51b000 - 0x7fff9b949fff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff9b94a000 - 0x7fff9b952fff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff9b953000 - 0x7fff9b964ff7 libsystem_trace.dylib (201.10.3) <E9311C03-9E61-3B13-AF3F-A64956FFF269> /usr/lib/system/libsystem_trace.dylib
0x7fff9ba24000 - 0x7fff9ba29fff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff9bc44000 - 0x7fff9bc47ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff9bc48000 - 0x7fff9bc48ff7 liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
0x7fff9c37c000 - 0x7fff9c77efff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff9c780000 - 0x7fff9c786fff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff9c787000 - 0x7fff9c788fff libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
0x7fff9c789000 - 0x7fff9c789ff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff9c9b3000 - 0x7fff9c9e4fff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff9c9e5000 - 0x7fff9ca43fff com.apple.SystemConfiguration (1.14 - 1.14) <8886E043-B668-3A49-BCA5-F89FB0ECB6EC> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff9cc07000 - 0x7fff9cdb3ff7 com.apple.avfoundation (2.0 - 1046.9.12) <41BDD03F-5545-3B9F-8DD7-7106485BAE8B> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff9cdff000 - 0x7fff9ce29ff7 libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
0x7fff9cee4000 - 0x7fff9cf35ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff9cfc9000 - 0x7fff9cfccff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff9cfcd000 - 0x7fff9d019ffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff9d01c000 - 0x7fff9d090ff3 com.apple.securityfoundation (6.0 - 55126) <DAA4FDD0-7F84-30AA-BE6F-96BB9F871F07> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff9d091000 - 0x7fff9d0ffff7 com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff9d121000 - 0x7fff9d1dbfff com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff9d1dc000 - 0x7fff9d295ff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff9d29c000 - 0x7fff9d34cfff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff9d34d000 - 0x7fff9d43fff7 libJP2.dylib (1460) <7FD6231B-EDB9-377F-87F0-ED1C6EDC6F21> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff9d440000 - 0x7fff9d4affff com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff9d4b0000 - 0x7fff9d4befff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff9d642000 - 0x7fff9d754fef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff9d755000 - 0x7fff9d767fff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff9d77c000 - 0x7fff9d784fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff9d785000 - 0x7fff9d7e8fff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff9d7e9000 - 0x7fff9d800ff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff9d801000 - 0x7fff9d8e7ff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff9d8e8000 - 0x7fff9d9c1fff com.apple.CoreMedia (1.0 - 1731.15.207) <70CAD4A7-3F8B-3767-A420-98BE1062C230> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff9d9c2000 - 0x7fff9d9dbfff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff9d9dc000 - 0x7fff9da37ff7 libTIFF.dylib (1460) <37D499DA-A4A6-3CC8-8F60-F374F992C304> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff9dba1000 - 0x7fff9dba4fff libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib
0x7fff9dbe6000 - 0x7fff9dc8afff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <4072EA3E-F2DD-32C1-9B19-9339C7087051> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff9dc8b000 - 0x7fff9dca2fff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff9dcf8000 - 0x7fff9e556fff com.apple.GeForceGLDriver (10.10.14 - 10.1.0) <40A15F51-EDD9-398D-9497-C698ED65848A> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fff9e558000 - 0x7fff9e726ff3 com.apple.QuartzCore (1.11 - 410.14) <3CEA7616-63A9-3B69-B6A8-476BF6D3F58B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff9e743000 - 0x7fff9e771ff7 libsandbox.1.dylib (460.60.2) <99132331-202E-35CC-A94D-48CD16B6F588> /usr/lib/libsandbox.1.dylib
0x7fff9e7c6000 - 0x7fff9ed04ff7 com.apple.MediaToolbox (1.0 - 1731.15.207) <63AD3FB7-BAD3-3040-8A99-843033F24CF6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff9ed05000 - 0x7fff9ed08fff com.apple.IOSurface (108.2.3 - 108.2.3) <52E51D16-42E9-3DDB-A16C-48225EF262C4> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff9ed1a000 - 0x7fff9edbafff com.apple.Metadata (10.7.0 - 972.34) <5F407CB0-3244-3A15-8000-82DDB0420244> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff9ef25000 - 0x7fff9ef35fff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff9ef36000 - 0x7fff9ef5dfff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff9ef65000 - 0x7fff9ef66ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff9ef69000 - 0x7fff9efdefff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff9efe7000 - 0x7fff9f01dfff libssl.0.9.8.dylib (59.60.1) <C047F10D-A929-36C8-83DE-E8BB7183A158> /usr/lib/libssl.0.9.8.dylib
0x7fff9f10b000 - 0x7fff9f110ff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff9f166000 - 0x7fff9f16cff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff9f1d7000 - 0x7fff9f1f4ff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <7B26B7D9-AEB3-3DEC-B4AD-B49BC0FD1082> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff9f1f5000 - 0x7fff9f21effb libRIP.A.dylib (960.7) <6C9E6C2C-62FD-32E6-AEB8-564A3510B17A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff9f242000 - 0x7fff9f24dfff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff9f256000 - 0x7fff9f257ffb libSystem.B.dylib (1226.10.1) <012548CD-614D-3AF0-B3B1-676F427D2CD6> /usr/lib/libSystem.B.dylib
0x7fff9f258000 - 0x7fff9f2abff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff9f369000 - 0x7fff9f373fff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff9f374000 - 0x7fff9f384fff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff9f38b000 - 0x7fff9f393fff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff9f394000 - 0x7fff9f3e6fff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <B177135E-C16A-3296-99C9-CDA0E8E2A855> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff9f49c000 - 0x7fff9f4a8fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff9f7f3000 - 0x7fff9f82dff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff9f82e000 - 0x7fff9f839fff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff9fb2e000 - 0x7fff9fbd5fff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff9fbd6000 - 0x7fff9fbd9ffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff9fbda000 - 0x7fff9fc12ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff9fc18000 - 0x7fff9fc1cfff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff9fc4d000 - 0x7fffa010bfcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffa010c000 - 0x7fffa0173fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffa01de000 - 0x7fffa01dffff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fffa039a000 - 0x7fffa03b5ff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fffa03be000 - 0x7fffa03c6fef libcldcpuengine.dylib (2.7.3) <6A6B8893-5A77-3014-9780-D3681DC0A08B> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fffa0441000 - 0x7fffa0486ff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fffa0524000 - 0x7fffa0533ffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fffa053f000 - 0x7fffa065cfff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fffa0699000 - 0x7fffa06dbff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fffa06dc000 - 0x7fffa0707ffb libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
0x7fffa070d000 - 0x7fffa074eff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fffa105f000 - 0x7fffa10c5ff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fffa10c6000 - 0x7fffa1155ff7 libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
0x7fffa1156000 - 0x7fffa1164ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fffa1168000 - 0x7fffa1184ff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fffa119c000 - 0x7fffa11eaff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fffa11eb000 - 0x7fffa11f6fff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fffa19dd000 - 0x7fffa19e8fff libkxld.dylib (3248.60.11.2.1) <9DFD804D-B16C-379C-8986-2D8781DFAEAE> /usr/lib/system/libkxld.dylib
0x7fffa19ef000 - 0x7fffa19f1fff libCGXType.A.dylib (960.7) <F52CB9D5-B366-3A93-B1E6-81B583675B19> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fffa1a03000 - 0x7fffa1a0bfff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffa1a0c000 - 0x7fffa1a15ff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffa1d33000 - 0x7fffa1d5dff7 GLRendererFloat (12.1) <15894300-8350-343F-942D-6D168BFFDB13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fffa1d5e000 - 0x7fffa1e3eff7 unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x7fffa1f64000 - 0x7fffa1f79ff3 libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fffa1f7a000 - 0x7fffa1faaff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fffa200a000 - 0x7fffa200efff libGIF.dylib (1460) <DEF81CFC-35F0-3BE3-9D53-F269B72AA619> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 4
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1733
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=286.2M resident=0K(0%) swapped_out_or_unallocated=286.2M(100%)
Writable regions: Total=1.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.1G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate.framework 128K 2
Activity Tracing 2048K 2
CG backing stores 5160K 4
CG image 1440K 16
CG shared images 304K 8
CoreAnimation 92K 18
CoreUI image data 840K 11
CoreUI image file 320K 5
Dispatch continuations 16.0M 2
Foundation 4K 2
IOKit 15.5M 2
Image IO 1024K 2
Kernel Alloc Once 8K 3
MALLOC 537.0M 121
MALLOC guard page 32K 7
Memory Tag 242 12K 2
OpenCL 8K 2
OpenGL GLSL 256K 4
Process Corpse Info 2048K 2
STACK GUARD 56.1M 18
Stack 20.8M 848
Stack Guard 4K 2
VM_ALLOCATE 502.6M 249
VM_ALLOCATE (reserved) 36K 2 reserved VM address space (unallocated)
__DATA 33.9M 260
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 99.0M 21
__TEXT 187.2M 257
__UNICODE 552K 2
mapped file 44.9M 11
shared memory 16.4M 11
TOTAL 1.5G 1868
TOTAL, minus reserved VM space 1.5G 1868
Model: MacBookPro9,1, BootROM MBP91.00D3.B0E, 4 processors, Intel Core i7, 2,3 GHz, 4 GB, SMC 2.1f175
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333235533643465238432D50422020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333235533643465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: TOSHIBA MK5065GSXF, 500,11 GB
Serial ATA Device: HL-DT-ST DVDRW GS31N
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
USB Device: ANT USB-m Stick
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
Thank you very much in advance,
Kind regards.
