Zwift and companion app won’t connect
I am using a Mac with zwift app. Then I have companion app on an apple iPhone. It used to work until I had a prompt on the Mac asking if I wanted to allow zwift to discover devices on my network and I answered no. Both apps run fine, but the companion app does not detect the session.Thoughts? Thanks in advance
Answering yes to the prompt to allow local network access is required for Companion to connect. It is connecting to the Mac so the Mac must allow that. If you download the Zwift installer and run it again, you should see that prompt again when you launch it for the first time after installing. You may also be able to find it in Settings → Privacy & Security → Local Network
6 days ago you asked the same…
