I am new to Zwift. I am a triathlete using it for winter month training. I set it up with an old lap top. I did my first FTP workout yesterday and noticed the timer counting down way to fast. After doing some research, I found that my lap top falls woefully short of the minimum requirements. The FPS are way to slow and that causes problems with Zwift. I have found a tower with the following specs. Can anyone tell me if this will run Zwift ?
I ntel Core 2 Quad 2.66 ghz 4 core cpu , 4 gb ram, 250 gb hd 7200 rpm , Dvd-Cd Burner , Video Card : Ati Radeon HD 3600 , 1 x Dvi and 2 x HDMI outputs The motherboard has 2 pci-e slots
+1 for AppleTV since it will be are less expensive than the tower and the performance will be much better. Make sure you check out the limitation before you decide on it.
What about sensors. Mine are all ANT+. My understanding is you cannot use IOs or TVOs without blue tooth sensors. I do have the wahoo ANT+ for iPhone(see pic). Will this allow me to run it on my iPad or AppleTV?
If you have all ANT+ I would try and eliminate using any type of bridge to get ANT+ to AppleTV. I know CABLE works according to some beta feedback, but if you have all ANT+ why would you want a native BLE device.
I see your point…however, I have a lot of equipment already on hand. I am attempting to find a solution with equipment I already have. I may, in the end, just buy a gaming PC. Also I have 4 AppleTV’s in my house, I am a fan.
The CABLE, by the way, is a small device that receives your ANT+ signals and resends them as Bluetooth, usable by the Apple TV, etc. (It’s about 2.25" by 1.25")
If you have your trainer and your sensors already, and an Apple TV 4th generation or the latest Apple TV 4K, all you need to add is something like the CABLE ( C onnect A NT+ to B luetooth L ow E nergy).
I got everything set up on the iPad using the wahoo ant+ iOS sensor (pictured above) and it worked flawlessly. My next step will be Apple TV4. I already hav 4 of them. Thanks for the info on the cable. That was my next question. How do I hook to the Apple TV. One step at a time…
