Hi There, I have a single leg Powermeter. As you know, that means that is only the Watts of a SingleLeg.
For any Event, Race, I am not having the real Watts as if someone that has DualLeg PowerMeter.
What would be the propper thing to do as to reach my real w/kg?
Do you think that dividing my weight by 2?
Do you think that dividing my weight by 2+25% of the remaining weight?
Any help would be great.
Thanks !
Normally single leg power meters double the reading and transmit that anyway.
Have you done an FTP test? What is it?
What single leg power meter are you referring to? Make sure you calibrate the power meter with the manufactures app.
There should be no reason to alter your weight within Zwift.
Hi Ben ! How are you?
I did, and it was 260w FTP.
I am 1.95mt with 105kg.
I usually compare Power with my riding buddies, and they have similar Watts but my speed and times are considerable better. So I asume that I am not reading the real watts.
I Have a Pioneer R8000 Ultegra Dual LEg. but somehow, Left leg does not work.
Thanks very mucho for your help.
Hi Paul ! How are you?
I did calibrated the powermeter.
Thanks very much for your help.
Are you referring to your Zwift speed?
no, in the road. Real Speed.
Thanks!
